MDD5N50D
500V N-Channel Enhancement Mode MOSFET
TO-252
VDS
500V
ID(Tc=25℃)
5A
RDS(on),max
1.6Ω@VGS=10V
Qg,typ
12.8nC
2
1
General Features
Low RDS(on)
Low gate charge
100% UIS tested
RoHS compliant
3
Equivalen t Circuit
Application
Electronic ballast
Switched mode power supplies.
UPS.
Absolute Maximum Ratings (TA=25℃unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
500
V
Gate-Source Voltage
VGS
±30
V
Continuous Drain Current
ID
5
A
Pulsed Drain Current(Note 1)
IDM
A
EAS
210
mJ
dv/dt
5
V/ns
Power Dissipation
PD
75
W
Junction Temperature
TJ
150
Storage Temperature
Tstg
-55 ~150
Avalanche Energy
Single Pulsed (Note 2)
Peak Diode Recovery dv/dt (Note 3)
Thermal Characteristics
Value
Parameter
Symbol
Thermal resistance, Junction-to-case
RθJC
1.67
°C/W
Thermal resistance, Junction-to-ambient
RθJA
110
°C/W
Notes:
TO-252
Unit
1. Pulse width limited by maximum junction temperature.
2. L=10mH, IAS = 6.5A, Starting Tj= 25°C.
3. ISD = 5A, di/dt≤100A/us, VDD≤BVDS, Starting Tj= 25°C.
1/7
V 1.0
MDD5N50D
Ta = 25℃ unless otherwise specified
Symbol
Parameter
Condition
Min
Typ
Max
Unit
VGS=0V, ID=250μA
500
V
Forward
VGS=30V, VDS=0V
100
nA
Reverse
VGS=-30V, VDS=0V
-100
nA
V(BR)DSS
Drain-Source Breakdown Voltage
IGSS
Gate-Source Leakage Current
IDSS
Drain-Source Leakage Current
VDS=500V, VGS=0V
1
uA
VGS(TH)
Gate Threshold Voltage
VDS=VGS, ID=250μA
2.0
4.0
V
RDS(ON)
Drain-Source On-State Resistance
VGS=10V, ID=2.5A
1.35
1.6
Ω
Min
Typ
Max
Unit
537.5
pF
80.3
pF
4
pF
12.8
nC
3.9
nC
4.6
nC
Min
Typ
Max
Unit
10.3
ns
ID=5A,
33.1
ns
RG=10Ω
29.4
ns
13.2
ns
Min
Typ
Max
Unit
Dynamic Electrical Characteristics
Symbol
Parameter
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Qg
Total Gate Charge
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
Condition
VDS=25V
VGS=0V
f=1MHz
VDS=400V,
VGS=10V,
ID=5A
(Note1,2)
Switching Characteristics
Symbol
Parameter
td(on)
Turn on Delay Time
tr
Turn on Rise Time
td(off)
Turn Off Delay Time
tf
Turn Off Fall Time
Condition
VDS=250V,
(Note1,2)
Source Drain Diode Characteristics
Symbol
Parameter
Condition
ISD
Source drain current(Body Diode)
5
A
ISM
Pulsed Current
A
VSD
Drain-Source Diode Forward Voltage
IS=5A, VGS=0V
1.5
V
trr
Body Diode Reverse Recovery Time
VR=250V
319.2
ns
Qrr
Body Diode Reverse Recovery Charge
1.6
uC
IF=5A,
-diF/dt =100A/µs
Notes:
1.Pulse test ; Pulse width≤300us, duty cycle≤2%.
2.Essentially independent of operating temperature.
2/7
V 1.0
MDD5N50D
Electrical Characteristics Diagrams
Figure 1. Typical Output Characteristics
Figure 2. Transfer Characteristics
VGS=10V
VGS=9V
VGS=6V
VGS=8V
Tc = 25°C
VGS=7V
VGS=5.5V
Tc = 150°C
VDS ,Drain−source voltage (V)
VGS ,Gate−source voltage (V)
Figure 3. On-Resistance Variation vs. Drain Current
Figure 4. Threshold Voltage vs. Temperature
VGS = 10 V
Tc = 25°C
Pulse test
IDS=0.25 mA
Pulse test
ID ,Drain current (A)
Tj ,Junction temperature (°C)
Figure 5. Breakdown Voltage vs. Temperature
Figure 6. On-Resistance vs. Temperature
VGS=10 V
IDS=2.5 A
Pulse test
VGS=0 V
IDS=0.25 mA
Pulse test
3/7
V 1.0
MDD5N50D
4/7
V 1.0
MDD5N50D
5/7
V 1.0
MDD5N50D
RL
VDS
RG
VGS
VDD
D.U.T.
10V
Pulse Width≤ 1μs
Duty Factor≤0.1%
Switching Test Circuit
12V
0.2µF
50kΩ
0.3µF
Switching Waveforms
Same
Type as
D.U.T.
VDS
VGS
DUT
3mA
Gate Charge Test Circuit
Gate Charge Waveform
Unclamped Inductive Switching Test Circuit
Unclamped Inductive Switching Waveforms
The curve above is for reference only.
6/7
V 1.0
MDD5N50D
Mechanical Dimensions for TO-252
SYMBOL
A
A1
A2
b
b3
c
D
D1
E
E1
e
H
L2
L3
L4
θ
MIN
2.20
0.00
0.97
0.68
5.20
0.43
5.98
6.40
4.63
9.40
0.88
0.50
0°
mm
NOM
2.30
1.07
0.78
5.33
0.53
6.10
5.30REF
6.60
2.286BSC
10.10
0.51BSC
MAX
2.38
0.20
1.17
0.90
5.46
0.61
6.22
6.73
10.50
1.28
1.00
8°
Package Marking and Ordering Information
Part Number
Marking
Package
MDD5N50D
5N50D
TO-252
7/7
Units/Tube
Units/Reel
2500
V 1.0
很抱歉,暂时无法提供与“MDD5N50D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.19546
- 50+0.94565
- 150+0.83862
- 500+0.70503
- 2500+0.64552
- 5000+0.60977
