MDD12N60F
MDD12N60F
    MDD(辰达半导体)
    TO-220F
    600V N通道增强模式MOSFET
MDD12N60F 数据手册
MDD12N60F 600V N-Channel Enhancement Mode MOSFET VDS 600 V ID(Tc=25℃) 12A RDS(on),max 0.75Ω@VGS=10V Qg,typ 40.8nC TO-220F-3L 1 General Features  Low RDS(on)  Low gate charge  100% UIS tested  RoHS compliant 2 3 Equivalen t Circuit Application  Power factor correction.  Switched mode power supplies.  LED driver. Absolute Maximum Ratings (TA=25℃unless otherwise noted) Parameter Symbol Value Unit Drain-Source Voltage VDS 600 V Gate-Source Voltage VGS ±30 V Continuous Drain Current ID 12 A Pulsed Drain Current(Note 1) IDM 48 A EAS 605 mJ IS 12 A Diode pulse current IS,pulse 48 A Peak Diode Recovery dv/dt (Note 3) dv/dt 5 V/ns Power Dissipation TO-220F PD 42 W Junction Temperature TJ 150 ℃ Storage Temperature Tstg -55 ~150 ℃ Avalanche Energy Single Pulsed (Note 2) Continuous diode forward current Thermal Characteristics Value Parameter Symbol Thermal resistance, Junction-to-case RθJC 2.98 °C/W Thermal resistance, Junction-to-ambient RθJA 110 °C/W Notes: TO-220F Unit 1. Pulse width limited by maximum junction temperature. 2. L=10mH, IAS = 11A, Starting Tj= 25°C. 3. ISD = 12A, di/dt≤100A/us, VDD≤BVDS, Starting Tj= 25°C. 1/7 V 1.0 MDD12N60F 600V N-Channel Enhancement Mode MOSFET Ta = 25℃ unless otherwise specified Symbol Parameter Condition Min Typ Max Unit VGS=0V, ID=250μA 600 -- -- V Forward VGS=30V, VDS=0V -- -- 100 nA Reverse VGS=-30V, VDS=0V -- -- -100 nA V(BR)DSS Drain-Source Breakdown Voltage IGSS Gate-Source Leakage Current IDSS Drain-Source Leakage Current VDS=600V, VGS=0V -- -- 1 uA VGS(TH) Gate Threshold Voltage VDS=VGS, ID=250μA 2.0 -- 4.0 V RDS(ON) Drain-Source On-State Resistance VGS=10V, ID=6A -- 0.53 0.75 Ω Min Typ Max Unit -- 1960 -- pF -- 163 -- pF -- 7.2 -- pF -- 40.8 -- nC -- 11.0 -- nC -- 15.6 -- nC Min Typ Max Unit -- -- 14.3 ns -- -- 37.6 ns -- -- 65.4 ns -- -- 14.2 ns Min Typ Max Unit Dynamic Electrical Characteristics Symbol Parameter Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance Qg Total Gate Charge Qgs Gate Source Charge Qgd Gate Drain Charge Condition VDS=25V VGS=0V f=1MHz VDS=480V, VGS=10V, ID=12A (Note1,2) Switching Characteristics Symbol Parameter td(on) Turn on Delay Time tr Turn on Rise Time td(off) Turn Off Delay Time tf Turn Off Fall Time Condition VDS=300V, ID=12A, RG=10Ω (Note1,2) Source Drain Diode Characteristics Symbol Parameter Condition ISD Source drain current(Body Diode) -- -- 12 A ISM Pulsed Current -- -- 48 A VSD Drain-Source Diode Forward Voltage IS=12A, VGS=0V -- -- 1.5 V trr Body Diode Reverse Recovery Time VR=300V -- 387.2 -- ns Qrr Body Diode Reverse Recovery Charge -- 3.87 -- uC IF=12A, -diF/dt =100A/µs Notes: 1.Pulse test ; Pulse width≤300us, duty cycle≤2%. 2.Essentially independent of operating temperature. 2/7 V 1.0 MDD12N60F 600V N-Channel Enhancement Mode MOSFET Electrical Characteristics Diagrams Figure 1. Typical Output Characteristics Figure 2. Transfer Characteristics VGS=10V VGS=9V Tc = 25°C VGS=8V VGS=7V VGS=5.5V VGS=6V Tc = 150°C VGS=4.5V VDS ,Drain−source voltage (V) VGS ,Gate−source voltage (V) Figure 3. On-Resistance Variation vs. Drain Current Figure 4. Threshold Voltage vs. Temperature VGS = 10 V Tc = 25°C Pulse test IDS=0.25 mA Pulse test ID ,Drain current (A) Tj ,Junction temperature (°C) Figure 5. Breakdown Voltage vs. Temperature Figure 6. On-Resistance vs. Temperature VGS=10 V IDS=6 A Pulse test VGS=0 V IDS=0.25 mA Pulse test Tj ,Junction temperature (°C) Tj ,Junction temperature (°C) 3/7 V 1.0 MDD12N60F 600V N-Channel Enhancement Mode MOSFET Figure 7. Capacitance Characteristics Figure 8. Gate Charge Characteristics Ciss VDS=480 Coss Notes:f = 1 MHz,VGS=0 V Ciss = Cgs + Cgd (Cds = shorted) Coss = Cds + Cgd Crss = Cgd ID = 12 A Crss VDS ,Drain-Source Voltage (V) QG ,Total Gate Charge (nC) Figure 9. Maximum Safe Operating Area Figure 10. Maximum Safe Operating Area TO-220F TO-220 100us 100us 10ms Limited by RDS(on) 1ms 10ms 1ms DC Limited by RDS(on) Notes: T = 25°C c Notes: T = 25°C j T = 150°C DC c T = 150°C j Single Pulse Single Pulse VDS ,Drain-Source Voltage (V) VDS ,Drain-Source Voltage (V) Figure 12. Power Dissipation vs. Figure 11. Power Dissipation vs. Temperature Temperature TO-220 TO-220F Tc ,Case temperature (°C) Tc ,Case temperature (°C) 4/7 V 1.0 MDD12N60F 600V N-Channel Enhancement Mode MOSFET Figure 13. Continuous Drain Current vs. Temperature Figure 14. Body Diode Transfer Characteristics Tc = 150° C Tc = 25°C VSD ,Source-Drain Voltage (V) Tc ,Case temperature (°C) Figure 15 Transient Thermal Impedance, Junction to Case, TO-220F P DM In descending order D= 0.5, 0.2, 0.1, 0.05, 0.02, 0.01, single pulse t Duty = t/T T Z (t)=2.98°C/W Max. θJC t ,Pulse Width (s) Figure 16. Transient Thermal Impedance, Junction to Case, TO-220 In descending order D= 0.5, 0.2, 0.1, 0.05, 0.02, 0.01, single pulse P DM t Duty = t/T Z (t)=0.83°C/W Max.T θJC t ,Pulse Width (s) 5/7 V V 1.0 1.0 MDD12N60F 600V N-Channel Enhancement Mode MOSFET RL VDS RG VGS VDD D.U.T. 10V Pulse Width≤ 1μs Duty Factor≤0.1% Switching Test Circuit 12V 0.2µF 50kΩ 0.3µF Switching Waveforms Same Type as D.U.T. VDS VGS DUT 3mA Gate Charge Test Circuit Gate Charge Waveform Unclamped Inductive Switching Test Circuit Unclamped Inductive Switching Waveforms The curve above is for reference only. 6/7 V 1.0 MDD12N60F 600V N-Channel Enhancement Mode MOSFET Mechanical Dimensions for TO-220F-3L SYMBOL E A A1 A4 c D H1 e L L1 ФP ФP3 F3 G3 b1 b2 MIN 9.96 4.50 2.34 2.56 0.40 15.57 12.68 2.88 3.03 3.15 3.15 1.25 1.18 0.70 mm NOM 10.16 4.70 2.54 2.76 0.50 15.87 6.70REF 2.54BSC 12.98 3.03 3.18 3.45 3.30 1.35 1.28 0.80 MAX 10.36 4.90 2.74 2.96 0.65 16.17 13.28 3.18 3.38 3.65 3.45 1.55 1.43 0.95 Package Marking and Ordering Information Part Number Marking Package Units/Tube MDD12N60F 12N60F TO-220F 50 7/7 Units/Reel V 1.0
MDD12N60F 价格&库存
很抱歉,暂时无法提供与“MDD12N60F”相匹配的价格&库存,您可以联系我们找货
