ES5DB
ES5DB
    MDD(辰达半导体)
    SMB(DO-214AA)
ES5DB 数据手册
ES5A THRU ES5J Reverse Voltage - 50 to 600 Volts Forward Current - 5.0 Ampere SURFACE MOUNT SUPER FAST RECOVERY RECTIFIER DO-214AA/SMB Features  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  For surface mounted applications  Low reverse leakage  Built-in strain relief,ideal for automated  placement High forward surge current capability  High temperature soldering guaranteed: 0.155(3.95) 0.130(3.30) 0.086 (2.20) 0.071 (1.80) 0.185(4.70) 0.160(4.05) 0.012(0.305) 0.006(0.152)  250°C/10 seconds at terminals Glass passivated chip junction 0.098(2.45) 0.080(2.00) 0.062(1.55) 0.030(0.75) Mechanical Data 0.008(0.203)MAX. 0.224(5.60) 0.196(4.90) Case : JEDEC DO-214AA/SMB Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.003 ounce, 0.093 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter ES5AB ES5BB ES5CB ES5DB ES5EB ES5GB ES5JB SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL=55℃ VRRM VRMS VDC I(AV) MDD MDD MDD MDD MDD MDD MDD ES5AB ES5BB ES5CB ES5DB ES5EB ES5GB ES5JB 50 35 50 100 70 100 150 105 150 200 140 200 300 210 300 400 280 400 600 420 600 UNITS V V V 5.0 A Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) IFSM 150 Maximum instantaneous forward voltage at 5.0A VF 1 Maximum DC reverse current at rated DCblocking voltage IR 10.0 100.0 μA trr 35 ns Maximum reverse recovery time TA=25℃ TA=125℃ (NOTE 1) 135 1.25 A 1.70 V CJ 95.0 pF Typical thermal resistance (NOTE 3) RJA 45.0 ℃/W Operating junction and storage temperature range TJ,TSTG -55 to +150 ℃ Typical junction capacitance (NOTE 2) Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas http://www.microdiode.com Rev:2024A2 Page :1 ES5A THRU ES5J Reverse Voltage - 50 to 600 Volts Forward Current - 5.0 Ampere Ratings And Characteristic Curves t rr 10 ohm Noninductive 50 ohm Noninductive +0.5 D.U.T + PULSE GENERATOR Note 2 25Vdc approx 0 - -0.25 1 ohm NonInductive OSCILLOSCOPE Note 1 -1.0 Note:1.Rise Time = 7ns, max. Input Impedance = 1megohm,22pF. 2. Ries Time =10ns, max. Source Impedance = 50 ohms. 10ns/div Set time Base for 10ns/div Fig.3 Typical Reverse Characteristics 300 6 5 I R - Reverse Current (μA) Average Forward Current (A) Fig.2 Maximum Average Forward Current Rating 4 3 2 1 Single phase half-wave 60 Hz resistive or inductive load 100 T J =125°C 10 T J =75°C 1.0 T J =25°C 0.1 0 25 50 75 100 125 150 175 20 0 40 Case Temperature (°C) Junction Capacitance (pF) Instaneous Forward Current (A) T J =25°C 1.0 ES5AB~ES5DB ES5EB/ES5GB 0.1 80 100 Fig.5 Typical Junction Capacitance Fig.4 Typical Forward Characteristics 10 60 % of PIV.VOLTS ES5JB 0.01 T J =25°C 100 10 T J=25°C f = 1.0MHz V sig = 50mV p-p 1 0.001 0 0.5 1.0 1.5 2.0 2.5 Instaneous Forward Voltage (V) 0.1 1.0 10 100 Reverse Voltage (V) Peak Forward Surge Current (A) Fig.6 Maximum Non-Repetitive Peak Forward Surge Current 140 120 100 80 60 40 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles The curve above is for reference only. http://www.microdiode.com Rev:2024A2 Page :2 ES5A THRU ES5J Reverse Voltage - 50 to 600 Volts Forward Current - 5.0 Ampere Packing information P0 P1 unit:mm d E Item F B A Symbol Tolerance SMB A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 3.81 5.41 2.42 1 5.0 330.00 50.00 13.00 1.75 5.55 8.00 4.00 2.00 0.30 12.00 12.30 W Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width P D2 T D1 C W1 D Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE SMB REEL SIZE REEL (pcs) COMPONENT SPACING (mm) 13" 3,000 4.0 INNER BOX (mm) REEL DIA, (mm) CARTON SIZE (mm) CARTON (pcs) 190*190*41 330 365*365*360 48,000 BOX (pcs) 6,000 APPROX. GROSS WEIGHT (kg) 14.0 Suggested Pad Layout Symbol A B C D E http://www.microdiode.com Unit (mm) 2.8 2.4 Unit (inch) 0.110 4.6 0.094 0.181 2.2 7.0 0.086 0.276 Rev:2024A2 Page :3
ES5DB 价格&库存
很抱歉,暂时无法提供与“ES5DB”相匹配的价格&库存,您可以联系我们找货
