SK86B
SK86B
    MDD(辰达半导体)
    SMB(DO-214AA)
    反向电压-20至200伏,正向电流-8.0安培,表面贴装肖特基势垒整流器
SK86B 数据手册
SK82B THRU SK820B Reverse Voltage - 20 to 200 Volts Forward Current - 8.0 Ampere SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER Features DO-214AA/SMB  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0     For surface mounted applications Metal silicon junction,majority carrier conduction Low power loss,high efficiency Built-in strain relief,ideal for automated placement 0.155(3.95) 0.130(3.30) 0.086 (2.20) 0.071 (1.80) 0.185(4.70) 0.160(4.05)  High forward surge current capability  High temperature soldering guaranteed: 0.012(0.305) 0.006(0.152) 250 °C/10 seconds at terminals 0.098(2.45) 0.080(2.00) Mechanical Data 0.062(1.55) 0.030(0.75) Ca se : JEDEC DO-214AA/SMB molded plastic body Termina ls : Solderable per MIL-STD-750,Method 2026 Polarity : Color band denotes cathode end Moun ting Pos ition : Any Weigh t : 0.0034 ounce, 0.1grams 0.008(0.203)MAX. 0.224(5.60) 0.196(4.90) Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS Marking Code VRRM VRMS VDC I(AV) Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) IFSM Maximum instantaneous forward voltage at 8.0A VF Maximum DC reverse current at rated DCblocking voltage TA=25℃ TA=100℃ Typical junction capacitance (1) Typical thermal resistance (2) Operating junction temperature range Storage temperature range MDD MDD MDD MDD MDD MDD MDD SK82B SK84B SK86B SK810B SK812B SK815B SK820B 20 40 60 100 120 150 200 V 14 20 28 40 42 60 70 100 84 120 105 150 140 200 V V 0.45 0.55 TJ TSTG 8.0 A 150 A 0.70 0.85 1.0 50 IR CJ RθJA UNITS mA 700 400 V pF 50 ℃/W -55 to +125 ℃ ℃ -55 to +150 Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.P.C.B. mounted with 2.0x2.0”(5.0x5.0cm) copper pad areas http://www.microdiode.com Rev:2024A3 Page :1 SK82B THRU SK820B Forward Current - 8.0 Ampere Reverse Voltage - 20 to 200 Volts Typical Characterisitics Fig.2 Typical Reverse Characteristics Average Forward Current (A) 14 12 10 8 6 4 2 Single phase half-wave 60 Hz resistive or inductive load 0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve 10 4 10 1 T J =25°C 10 0 0 20 40 60 100 80 Percent of Rated Peak Reverse Voltage(%) Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic T J =25°C Junction Capacitance (pF) 20 10 1 SK82B SK84B SK86B SK810B~SS820B 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 500 100 SK82BF/SK84BF SK86B/SK820B 20 10 1 0.1 100 10 Instaneous Forward Voltage (V) Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 175 150 125 100 75 50 25 1000 1.8 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 Number of Cycles at 60Hz 100 Transient Thermal Impedance( °C / W) Instaneous Forward Current (A) T J =75°C 10 2 Case Temperature (°C) Peak Forward Surage Current (A) T J =100°C 10 3 200 100 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) The curve above is for reference only. http://www.microdiode.com Rev:2024A3 Page :2 SK82B THRU SK820B Forward Current - 8.0 Ampere Reverse Voltage - 20 to 200 Volts Packing information unit:mm P0 Item P1 Symbol Tolerance SMA A B C d D D1 D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 2.80 5.33 2.36 1.50 330.00 50.00 178.00 62.00 13.00 1.75 5.50 4.00 4.00 2.00 0.28 12.00 18.00 D1 d Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width E W1 F B A W P D2 T C D Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (mm) BOX (pcs) INNER BOX (mm) REEL DIA, (mm) SMB 13" 3,000 4.0 6,000 190*190*41 330 CARTON SIZE (mm) 365*365*360 CARTON (pcs) 48,000 APPROX. GROSS WEIGHT (kg) 14.0 Suggested Pad Layout http://www.microdiode.com Symbol A Unit (mm) 1.68 Unit (inch) 0.066 B 1.52 0.060 C 3.93 0.154 D 2.41 0.095 E 5.45 0.215 Rev:2024A3 Page :3
SK86B 价格&库存
很抱歉,暂时无法提供与“SK86B”相匹配的价格&库存,您可以联系我们找货
