MMBD7000
SOT-23 Plastic-Encapsulate Diodes
MMBD7000
SWITCHING DIODE
SOT-23
FEATURES
z Dual Swithching Diode
z Fast Switching Speed
z Surface Mount Package Ideally Suited for Automatic Insertion
z For General Purpose Switching Applications
MARKING:M5C
1: Anode 1
2: Cathode 2
3: Cathode1 / Anode 2
M5C
Maximum Ratings @Ta=25℃
Parameter
Symbol
Limits
Unit
100
V
75
V
VR(RMS)
53
V
IO
200
mA
Non-Repetitive Peak Forward Surge Current @ t =8.3ms
IFSM
2
A
Power Dissipation
PD
225
mW
RθJA
556
℃/W
Tj
150
TSTG
-55~+150
Non-Repetitive Peak Reverse Voltage
VRM
Peak Repetitive Reverse Voltage
VRRM
Working Peak Reverse Voltage
VRWM
RMS Reverse Voltage
Average Rectified Output Current
Thermal Resistance,Junction to Ambient
Junction temperature
Storage temperature range
Electrical Characteristics @Ta=25℃
Parameter
Reverse breakdown voltage
Reverse voltage leakage current
Forward voltage
Symbol
Test
V(BR)
IR=100μA
IR
VF
conditions
Min
Max
100
Unit
V
VR=50V
1.0
VR=100V
3.0
IF=1mA
0.55
0.7
IF=10mA
0.67
0.82
IF=100mA
0.75
1.1
μA
V
Diode capacitance
CT
VR= 0V,f =1.0MHz
2
pF
Reverse recovery time
t rr
IF=IR=10mA,
Irr=0.1 x IR,RL=100Ω
4
ns
http://www.microdiode.com
Rev:2024A2
Page :1
MMBD7000
Typical Characteristics
Reverse
Forward Characteristics
Characteristics
1000
200
100
(nA)
30
REVERSE CURRENT IR
10
T=
a 2
5℃
T=
a 1
00
FORWARD CURRENT
Ta=100℃
100
IF
(mA)
300
3
1
30
10
Ta=25℃
3
0.3
0.1
0.0
1
0.4
0.8
FORWARD VOLTAGE
1.2
VF
1.6
(V)
40
REVERSE VOLTAGE
60
VR
80
(V)
Power Derating Curve
Capacitance Characteristics
250
1.4
Ta=25℃
(mW)
200
PD
1.3
150
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
f=1MHz
1.2
1.1
100
50
10
REVERSE VOLTAGE
15
VR
(V)
50
75
AMBIENT TEMPERATURE
Rev:2024A2
100
Ta
125
Page :2
150
MMBD7000
Outlitne Drawing
SOT-23 Package Outline Dimensions
1
e
Suggested Pad Layout
0.037
0.95
0.037
0.95
L
L1
E
E1
Symbol
A
A1
b
c
D
E
E1
e
L
L1
θ
Dimensions In Millimeters
Min
Typ
Max
0.65
1.40
0.20
0.00
0.30
0.55
0.20
0.08
2.70
3.10
1.15
1.65
2.80
2.10
1.70
2.10
0.15
0.50
0.35
0°
0.70
12°
Note:
1. Controlling dimension:in/millimeters.
2. General tolerance: ±0.05mm.
3. The pad layout is for reference purposes only.
0.079
2.0
0.035
0.9
0.031
0.8
inches
mm
Rev:2024A2
Page :3
MMBD7000
SOT-23 Tape and Reel
Packaging Description:
SOT-23 parts are shipped in tape. The carrier
tape is made from a dissipative (carbon filled)
polycarbonate resin. The cover tape is a multilayer
film (Heat Activated Adhesive in nature) primarily
composed of polyester film,adhesive laye,sealant,
and anti-static sprayed agent.These reeled parts In
standard option are shipped with 3,000 units per 7"
or 17.8cm diameter reel. The reels are clear in color
and is made of polystyrene plastic (anti-static
coated).
3000 pcs
7 Inch
45,000 pcs
203×203×195
180,000 pcs
438×438×220
Rev:2024A2
Page :4
很抱歉,暂时无法提供与“MMBD7000”相匹配的价格&库存,您可以联系我们找货
