BAV23C
BAV23C
    MDD(辰达半导体)
    SOT-23
    快速开关二极管
BAV23C 数据手册
BAV23A/C/S SOT-23 Plastic-Encapsulate Diodes BAV23A/BAV23C/BAV23S SWITCHING DIODE SOT-23 FEATURES z z z Fast Switching Speed For General Purpose Switching Applications High Conductance BAV23S BAV23A BAV23C MARKING:KT7 MARKING:KT6 MARKING:KL31 KT7 KT6 KL31 Maximum Ratings @Ta=25℃ Parameter Symbol Limit Unit Peak Repetitive Reverse Voltage VRRM 250 V Working Peak Reverse Voltage VRWM 250 V RMS Reverse Voltage VR(RMS) 175 V IO 225 mA IFSM 1.7 A PD 350 mW RθJA 357 ℃/W TJ 150 ℃ TSTG -55~+150 ℃ Forward Current Non-Repetitive Peak Forward Surge Current @t=8.3ms Power Dissipation Thermal Resistance Junction to Ambient Junction Temperature Storage Temperature range Electrical Characteristics @Ta=25℃ Parameter Symbol Test conditions Min Typ Max V Reverse voltage V(BR) IR=100μA Reverse current IR VR=250V 0.1 Forward voltage VF IF=100mA 1 IF=200mA 1.25 Total capacitance Ctot Reverse recovery time http://www.microdiode.com trr Unit 250 μA V VR=0V,f=1MHz 5 pF IF= IR=30mA, Irr=0.1×IR, RL=100Ω 50 ns Rev:2024A2 Page :1 BAV23A/C/S Typical Characteristics Forward Characteristics Reverse 1000 300 Pulsed Characteristics Pulsed (nA) (mA) 100 REVERSE CURRENT IR T= a 2 5℃ FORWARD CURRENT T= a 1 00 ℃ IF 10 1 0.1 0.01 0.2 Ta=100℃ 100 10 Ta=25℃ 1 0.4 0.6 0.8 FORWARD VOLTAGE 1.0 VF 1.2 0 50 (V) 100 150 REVERSE VOLTAGE 200 250 (V) VR Power Derating Curve Capacitance Characteristics 1.6 400 (mW) f=1MHz 350 300 PD 1.4 1.2 POWER DISSIPATION CAPACITANCE BETWEEN TERMINALS CT (pF) Ta=25℃ 1.0 0.8 0.6 250 200 150 100 50 0 0 4 8 12 REVERSE VOLTAGE http://www.microdiode.com 16 VR (V) 20 0 25 50 75 100 AMBIENT TEMPERATURE Rev:2024A2 125 Ta 150 (℃) Page :2 BAV23A/C/S Outlitne Drawing SOT-23 Package Outline Dimensions 1 e Suggested Pad Layout 0.037 0.95 0.037 0.95 L L1 E E1 Symbol A A1 b c D E E1 e L L1 θ Dimensions In Millimeters Min Typ Max 0.65 1.40 0.20 0.00 0.30 0.55 0.20 0.08 2.70 3.10 1.15 1.65 2.80 2.10 1.70 2.10 0.15 0.50 0.35 0° 0.70 12° Note: 1. Controlling dimension:in/millimeters. 2. General tolerance: ±0.05mm. 3. The pad layout is for reference purposes only. 0.079 2.0 0.035 0.9 0.031 0.8 http://www.microdiode.com inches mm Rev:2024A2 Page :3 BAV23A/C/S SOT-23 Tape and Reel Packaging Description: SOT-23 parts are shipped in tape. The carrier tape is made from a dissipative (carbon filled) polycarbonate resin. The cover tape is a multilayer film (Heat Activated Adhesive in nature) primarily composed of polyester film,adhesive laye,sealant, and anti-static sprayed agent.These reeled parts In standard option are shipped with 3,000 units per 7" or 17.8cm diameter reel. The reels are clear in color and is made of polystyrene plastic (anti-static coated). 3000 pcs http://www.microdiode.com 7 Inch 45,000 pcs 203×203×195 180,000 pcs 438×438×220 Rev:2024A2 Page :4
BAV23C 价格&库存
很抱歉,暂时无法提供与“BAV23C”相匹配的价格&库存,您可以联系我们找货
