MURF1020DCT
MURF1020DCT
    MDD(辰达半导体)
    TO-220AB
    ITO-220AB塑料封装超快恢复整流二极管
MURF1020DCT 数据手册
MURF1020DCT THRU MURF1060DCT Reverse Voltage - 200 - 600 Volts Forward Current - 10.0 Ampere Ultra-Fast Recovery Diodes Features ITO-220AB  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  Construction utilizes void-free molded plastic technique  Low reverse leakage  High forward surge current capability  High temperature soldering guaranteed: 250°C,0.25”(6.35mm) from case for 10 seconds PIN1 PIN2 Mechanical Data Case : JEDEC ITO-220AB Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.080 ounce, 2.24 grams PIN3 PIN1 PIN2 PIN3 Maximum Ratings And Electrical Characteristics Ratings at 25°C ambient temperature unlss otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS MDD MURF1020DCT MDD MURF1040DCT MDD MURF1060DCT UNITS Maximum repetitive peak reverse voltage VRRM 200 400 600 V Maximum RMS voltage VRMS 140 280 420 V Maximum DC blocking voltage VDC 200 400 600 V Maximum average forward rectified current at T C=110 C I(AV) 10.0 5.0 A Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load IFSM 50.0 A Maximum instantaneous forward voltage per diode at 5.0A VF Maximum DC reverse current at rated DC blocking voltage Maximum reverse recovery time Typical thermal resistance Operating junction temperature range Storage temperature range per device per diode T A =25 C T A=125 C 1.0 1.3 1.6 V IR 10 500 uA Trr 35 ns RqJC 4.0 C/W TJ -55 to +175 C TSTG -55 to +175 C Note:1.Reverse recovery time test condition: IF=0.5A IR=1.0A Irr=0.25A http://www.microdiode.com Rev:2025A3 Page :1 MURF1020DCT THRU MURF1060DCT Reverse Voltage - 200 - 600 Volts Forward Current - 10.0 Ampere Ratings And Characteristic Curves Fig.2 Typical Reverse Characteristics 10 8.0 6.0 4.0 2.0 RESISTIVE OR INDUCTIVE LOAD 0.0 25 75 50 100 125 150 175 Instaneous Reverse Current ( mA) Average Forward Current (A) Fig.1 Typical Forward Current Derating Curve 10 1.0 T J =125°C 0.1 0.01 T J =25°C 0.001 0.0001 0 Case Temperature (°C) Peak Forward Surage Current (A) 0V 60 40 0V 0V 1.0 20 Instaneous Forward Current (A) T J =25°C 0.1 1.0 60 80 100 Fig.4 Maximum Non-Repetitive Peak Forward Surage Current 10 0.5 40 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic 0.01 0 20 1.5 Instaneous Forward Voltage (V) 2.0 60 50 40 30 20 10 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles at 60Hz The curve above is for reference only. http://www.microdiode.com Rev:2025A3 Page :2 MURF1020DCT THRU MURF1060DCT Reverse Voltage - 200 - 600 Volts Forward Current - 10.0 Ampere Outlitne ITO-220AB Package Outline Dimensions A C E B M N D J L b F L1 b1 H G G A B b b1 C D E F G H L L1 M N max 10.5 3.3 1.5 1.0 4.9 16.2 2.9 3.55 2.74 0.70 3.8 14.3 7.0 3.4 min 9.6 2.54 1.1 0.5 4.3 14.7 2.4 2.56 2.34 0.30 2.3 12.0 6.3 3.0 UNIT mm Important Notice and Disclaimer Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen). Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Shenzhen). http://www.microdiode.com Rev:2025A3 Page :3
MURF1020DCT 价格&库存
很抱歉,暂时无法提供与“MURF1020DCT”相匹配的价格&库存,您可以联系我们找货
