MUR1620DCT THRU MUR1660DCT
Reverse Voltage - 200 - 600 Volts
Forward Current - 16.0 Ampere
Ultra-Fast Recovery Diodes
Features
TO-220AB
High frequency operation.
High surge forward current capability
High purity, high temperature epoxy encapsulation for
enhanced mechanical strength and moisture resistance
Guard ring for enhanced ruggedness and long term reliability
Solder dip 275 °C max. 7s, per JESD 22-B106
PIN2
PIN1
Mechanical Data
PIN2
Case : JEDEC TO-220AB Molded plastic body
Weight : 0.067 ounce, 1.9 grams
Lead free finish, RoHS compliant
Case Material: “Green” molding compound, UL flammability
classification 94V-0,“Halogen-free”.
PIN3
PIN1
PIN2
PIN3
Maximum Ratings And Electrical Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
SYMBOLS
MDD
MUR1620DCT
MDD
MUR1640DCT
MDD
MUR1660DCT
UNITS
Maximum repetitive peak reverse voltage
VRRM
200
400
600
V
Maximum RMS voltage
VRMS
140
280
420
V
Maximum DC blocking voltage
VDC
200
400
600
V
Maximum average forward
rectified current at T C=110 C
I(AV)
16.0
8.0
A
Peak forward surge current, 8.3ms single half
sine-wave superimposed on rated load
IFSM
100.0
A
Maximum instantaneous forward voltage
per diode at 8.0A
VF
Maximum DC reverse current
at rated DC blocking voltage
Maximum reverse recovery time
Typical thermal resistance
Operating junction temperature range
Storage temperature range
per device
per diode
T A =25 C
T A=125 C
1.0
1.3
1.6
V
IR
10
500
uA
Trr
35
ns
RqJC
4.0
C/W
TJ
-55 to +175
C
TSTG
-55 to +175
C
Note:1.Reverse recovery time test condition: IF=0.5A IR=1.0A Irr=0.25A
http://www.microdiode.com
Rev:2025A2
Page :1
Ratings And Characteristic Curves
Fig.2 Typical Reverse Characteristics
12
8.0
4.0
RESISTIVE OR INDUCTIVE LOAD
0.0
25
75
50
100
125
150
175
Instaneous Reverse Current ( mA)
Average Forward Current (A)
Fig.1 Typical Forward Current Derating Curve
10
1.0
T J =125°C
0.1
0.01
T J =25°C
0.001
0.0001
Case Temperature (°C)
Peak Forward Surage Current (A)
0V
60
0V
40
0V
1.0
0.1
0.01
1.0
40
60
80
100
Fig.4 Maximum Non-Repetitive Peak
T J =25°C
Instaneous Forward Current (A)
Fig.3 Typical Forward Characteristic
10
Percent of Rated Peak Reverse Voltage(%)
1.5
Instaneous Forward Voltage (V)
2.0
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
1
10
100
Number of Cycles at 60Hz
The curve above is for reference only.
Rev:2025A2
Page :2
Outlitne
TO-220AB Package Outline Dimensions
A
C
E
B
M
N
D
L
b
F
L1
b1
H
G
G
TO-220AB mechanical data
UNIT
A
B
b
b1
C
D
E
F
max 10.45 2.94 1.77
0.94
4.76
min
0.62
4.42 14.6 1.14 2.20
16.0 1.40 2.90
mm
9.85
2.54
1.14
G
H
L
2.54
TYPICAL
0.64
0.35
L1
M
N
4.2 14.79
6.60
3.86
2.8 13.00
6.13
3.8
Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications
at any time without notice. Customers should obtain and confirm the latest product information and specifications before final
design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products
for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Electronics (Shenzhen).
Rev:2025A2
Page :3
很抱歉,暂时无法提供与“MUR1640DCT”相匹配的价格&库存,您可以联系我们找货
