MUR1620DCT
MUR1620DCT
    MDD(辰达半导体)
    TO-220AB
    200V 8A
MUR1620DCT 数据手册
MUR1620DCT THRU MUR1660DCT Reverse Voltage - 200 - 600 Volts Forward Current - 16.0 Ampere Ultra-Fast Recovery Diodes Features TO-220AB  High frequency operation. High surge forward current capability  High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance  Guard ring for enhanced ruggedness and long term reliability  Solder dip 275 °C max. 7s, per JESD 22-B106 PIN2 PIN1 Mechanical Data PIN2 Case : JEDEC TO-220AB Molded plastic body Weight : 0.067 ounce, 1.9 grams Lead free finish, RoHS compliant Case Material: “Green” molding compound, UL flammability classification 94V-0,“Halogen-free”. PIN3 PIN1 PIN2 PIN3 Maximum Ratings And Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Parameter SYMBOLS MDD MUR1620DCT MDD MUR1640DCT MDD MUR1660DCT UNITS Maximum repetitive peak reverse voltage VRRM 200 400 600 V Maximum RMS voltage VRMS 140 280 420 V Maximum DC blocking voltage VDC 200 400 600 V Maximum average forward rectified current at T C=110 C I(AV) 16.0 8.0 A Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load IFSM 100.0 A Maximum instantaneous forward voltage per diode at 8.0A VF Maximum DC reverse current at rated DC blocking voltage Maximum reverse recovery time Typical thermal resistance Operating junction temperature range Storage temperature range per device per diode T A =25 C T A=125 C 1.0 1.3 1.6 V IR 10 500 uA Trr 35 ns RqJC 4.0 C/W TJ -55 to +175 C TSTG -55 to +175 C Note:1.Reverse recovery time test condition: IF=0.5A IR=1.0A Irr=0.25A http://www.microdiode.com Rev:2025A2 Page :1 MUR1620DCT THRU MUR1660DCT Reverse Voltage - 200 - 600 Volts Forward Current - 16.0 Ampere Ratings And Characteristic Curves Fig.2 Typical Reverse Characteristics 20 16 12 8.0 4.0 RESISTIVE OR INDUCTIVE LOAD 0.0 25 75 50 100 125 150 175 Instaneous Reverse Current ( mA) Average Forward Current (A) Fig.1 Typical Forward Current Derating Curve 10 1.0 T J =125°C 0.1 0.01 T J =25°C 0.001 0.0001 0 Case Temperature (°C) Peak Forward Surage Current (A) 0V 60 0V 40 0V 1.0 0.1 0.01 0 0.5 1.0 40 60 80 100 Fig.4 Maximum Non-Repetitive Peak Forward Surage Current T J =25°C 20 Instaneous Forward Current (A) Fig.3 Typical Forward Characteristic 10 20 Percent of Rated Peak Reverse Voltage(%) 1.5 Instaneous Forward Voltage (V) 2.0 120 100 80 60 40 20 0 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 100 Number of Cycles at 60Hz The curve above is for reference only. http://www.microdiode.com Rev:2025A2 Page :2 MUR1620DCT THRU MUR1660DCT Reverse Voltage - 200 - 600 Volts Forward Current - 16.0 Ampere Outlitne TO-220AB Package Outline Dimensions A C E B M N D L b F L1 b1 H G G TO-220AB mechanical data UNIT A B b b1 C D E F max 10.45 2.94 1.77 0.94 4.76 min 0.62 4.42 14.6 1.14 2.20 16.0 1.40 2.90 mm 9.85 2.54 1.14 G H L 2.54 TYPICAL 0.64 0.35 L1 M N 4.2 14.79 6.60 3.86 2.8 13.00 6.13 3.8 Important Notice and Disclaimer Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen). Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Shenzhen). http://www.microdiode.com Rev:2025A2 Page :3
MUR1620DCT 价格&库存
很抱歉,暂时无法提供与“MUR1620DCT”相匹配的价格&库存,您可以联系我们找货
