MBRB10200
MBRB10200
    MDD(辰达半导体)
    TO-263
    反向电压45至200伏,正向电流10.0安培,肖特基势垒玻璃钝化整流器
MBRB10200 数据手册
MBRB1045 THRU MBRB10200 Reverse Voltage - 45 to 200 Volts Forward Current - 10.0 Ampere SCHOTTKY BARRIER GLASS PASSIVATED RECTIFIERS TO-263(D2PAK) FEATURES High current capability Low forward voltage drop Low power loss, high efficiency High surge capability High temperature soldering guaranteed Mounting position: any K ① MECHANICAL DATA Case: TO-263 molded plastic body Terminals: Plated axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any ② ① ② K HEAT SINK MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. MCHARACTERISTICS SYMBOL MDD MBRB 1045 MDD MBRB 1060 MDD MBRB 10100 MDD MBRB 10150 MDD MBRB 10200 UNITS Maximum repetitive peak reverse voltage VRRM 45 60 100 150 200 V Maximum RMS voltage VRMS 32 42 70 105 140 V Maximum DC blocking voltage VDC 45 60 100 150 200 V Maximum average forward rectified current per diode per device Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) per device IF(AV) 5 10 A IFSM 100 A Maximum instantaneous forward voltage at 5A DC Per leg VF Maximum DC reverse current at rated DC blocking voltage IR TA=25℃ TA=125℃ Typical junction capacitance (NOTE 1) CJ Typical thermal resistance (NOTE 2) RθJA Operating junction temperature range Storage temperature range 0.75 0.60 0.85 0.95 0.1 20 0.05 20 500 300 V mA pF 45 ℃/W TJ -55 to +150 ℃ TSTG -55 to +150 ℃ Note:1.Measured at 1.0MHz and applied reverse voltage of 4.0V D.C. 2.PCB. Mounted on 10cm x 10cm x 1mm copper pad areas 3. The typical data above is for reference only. http://www.microdiode.com Rev:2025A3 Page :1 MBRB1045 THRU MBRB10200 Reverse Voltage - 45 to 200 Volts Forward Current - 10.0 Ampere Typical Characterisitics Fig.2 Typical Reverse Characteristics 8.0 6.0 ~2 00 V 4.0 2.0 0.0 20 40 60 80 100 120 140 160 180 Instaneous Reverse Current ( mA) 10 45 Average Forward Current (A) Fig.1 Typical Forward Current Derating Curve 100 45~60V 100~200V 10 T J =100°C 1.0 0.1 T J =25°C 0.01 0.001 0 Case Temperature (°C) T J =25°C 10 1 45V 60V 100V 150V 200V 0.1 0 0.3 0.6 0.9 1.2 1.5 Instaneous Forward Voltage (V) http://www.microdiode.com 40 60 80 100 Fig.4 Maximum Non-Repetitive Peak Forward Surage Current Peak Forward Surage Current (A) Instaneous Forward Current (A) Fig.3 Typical Forward Characteristic(per leg) 20 20 Percent of Rated Peak Reverse Voltage(%) 1.8 160 140 120 100 80 60 40 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles at 60Hz Rev:2025A3 Page :2 MBRB1045 THRU MBRB10200 Reverse Voltage - 45 to 200 Volts Forward Current - 10.0 Ampere Outlitne Drawing TO-263(D2PAK) Package Outline Dimensions C A E D B a L2 b L L1 L3 b1 H G G TO-263(D2PAK) mechanical data A B b b1 max 10.4 9.4 1.50 0.91 min 9.6 8.4 1.07 0.70 UNIT C D G H L L1 L2 L3 a 4.80 11.00 1.40 2.74 0.60 6.0 1.47 1.75 3.18 0.25 4.30 2.34 0.30 4.1 1.07 1.0 1.7 0 E mm 9.68 1.20 8. 50 3 . 00 Suggested Pad Layout Note: 1. Controlling dimension:in/millimeters. 2. General tolerance: ±0.05mm. 3. The pad layout is for reference purposes only. 3.00 8 .4 0 1 .2 0 http://www.microdiode.com Rev:2025A3 Page :3 MBRB1045 THRU MBRB10200 Reverse Voltage - 45 to 200 Volts Forward Current - 10.0 Ampere TO-263 Embossed Carrier Tapeape Packaging Description: TO-263 parts are shipped in tape. The carrier tape is made from a dissipative (carbon filled) polycarbonate resin. The cover tape is a multilayer film (Heat Activated Adhesive in nature) primarily composed of polyester film,adhesive laye,sealant, and anti-static sprayed agent.These reeled parts In standard option are shipped with 800 units per 13" or 33.0cm diameter reel. The reels are clear in color and is made of polystyrene plastic (anti-static coated). TO-263 Tape Leader and Trailer TO-263 Reel 800 pcs 13 Inch http://www.microdiode.com 1,600 pcs 340×336×66 8,000 pcs 400×353×365 Rev:2025A3 Page :4 MBRB1045 THRU MBRB10200 Reverse Voltage - 45 to 200 Volts Forward Current - 10.0 Ampere Important Notice and Disclaimer Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen). Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Shenzhen). http://www.microdiode.com Rev:2025A3 Page :5
MBRB10200 价格&库存
很抱歉,暂时无法提供与“MBRB10200”相匹配的价格&库存,您可以联系我们找货
