ST20100
ST20100
    MDD(辰达半导体)
    TO-277
    100V 20A
ST20100 数据手册
ST20100 Reverse Voltage - 100 Volts Forward Current -20.0 Ampere SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER Features TO-277  Trench MOS Schottky barrier diodes  Low forward voltage drop  low profile - typical body height 1.1 mm  Moisture sensitivity: level 1, per J-STD-020  High temperature soldering guaranteed: 260℃/10 seconds - RoHS Compliant  Halogen-free according to IEC 61249-2-21 definition Mechanical Data Case : JEDEC TO-277 Molded plastic body Case Material: Molding compound meets UL 94V-0 flammability rating Terminals :Plated Leads Solderable per MIL-STD-202,Method 208 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.003 ounce, 0.092 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. ST20100 Parameter SYMBOL MDD ST20100 Marking Code Maximum repetitive peak reverse voltage VRRM Maximum DC blocking voltage VDC RMS Reverse voltage UNIT 100 V VRMS 70 V Average Rectified Output Current I(O) 20 A Non-Repetitive Peak Forward Surge8.3ms Single Half Sine-Wave Superimposed on rated load(JEDEC Method) IFSM 320 A Electrical Characteristics Ta=25℃ unless otherwise noted Test Symbol Conditions Parameter TA=25℃ TA=125℃ vF Peak reverse curent at rated DC TA=25℃ blocking voltage TA=125℃ IR Forward Voltage Drop at 20A TTypical junction capacitance 4.0 V, 1 MHz Typical thermal resistance Junctionto Ambient Operating junction and storage temperaturerange Value Typ 0.61 0.55 50 Max 0.64 0.58 120 35 100 Unit V uA mA CJ 1.8 nF RθJA 100 ℃/W -55 to +150 ℃ TJ,TSTG Note:1.The typical data above is for referenceonly. http://www.microdiode.com Rev:2024A3 Page :1 ST20100 Reverse Voltage - 100 Volts Forward Current -20.0 Ampere Ratings And Characteristic Curves The curve above is for reference only. http://www.microdiode.com Rev:2024A3 Page :2 ST20100 Reverse Voltage - 100 Volts Forward Current -20.0 Ampere Packing information P0 P1 unit:mm d E Item Symbol Tolerance TO-277 Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 4.45 7.0 1.60 1.55 330.00 50.0 13.00 1.75 7.50 8.00 4.00 2.00 F W B A P D2 D1 T C W1 D 0.25 12.00 12.30 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) CARTON SIZE (m/m) CARTON (pcs) APPROX. GROSS WEIGHT (kg) TO-277 13" 5,000 4.0 10,000 210*208*203 330 430*430*235 80,000 13.0 TO-277 Outlitne Drawing B C F G A D J K N M E imensions in Millimeters Symbol E G Min Max A 5.2 5.8 B 3.8 4.3 C 1.7 1.9 D 6.4 6.6 E 0.8 1.0 F 1.0 1.3 G 0.2 0.45 J 1.1 1.5 K 2.4 4.0 M 1.65 1.95 N 0.7 1.3 Suggested Pad Layout http://www.microdiode.com Symbol Unit (mm) Unit (inch) A 0.142 B 3.60 5.35 C 1.50 0.059 D 1.85 0.073 E 4.30 0.169 Rev:2024A3 0.211 Page :3
ST20100 价格&库存
很抱歉,暂时无法提供与“ST20100”相匹配的价格&库存,您可以联系我们找货
