MURB2060D
MURB2060D
    MDD(辰达半导体)
    TO-263
    反向电压200 - 600伏,正向电流20.0安培超快恢复二极管
MURB2060D 数据手册
MURB2020D THRU MURB2060D Reverse Voltage - 200 to 600 Volts Forward Current - 20.0 Ampere Ultra-Fast Recovery Diodes Features TO-263(D2PAK)  High frequency operation.  High surge forward current capability  High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Guard ring for enhanced ruggedness and long term reliability  Low forward Voltage drop  K Mechanical Data ① Case: TO-263 molded plastic body Terminals: Plated axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end ② ① ② K HEAT SINK Mounting Position: Any Maximum Ratings And Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Symble MDD MURB2020D MDD MURB2040D Maximum Recurrent Peak Reverse Voltage V RRM 200 400 600 V Maximum RMS voltage V RMS 140 280 420 V Maximum DC Blocking Voltage V DC 200 400 600 V Parameter Maximum Average Forward Rectified Current Per leg Per device Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method)(Per leg) Max Instantaneous Forward Voltage at 20 A (Per leg) Maximum DC Reverse Current T a = 25°C at Rated DC Reverse Voltage T a =125°C Maximum Reverse Recovery Time (1) Typical Thermal Resistance Operating Junction Temperature Range Storage Temperature Range MDD MURB2060D Units I F(AV) 10 20 A I FSM 150 A VF 1.0 1.3 1.6 V IR 10 500 uA trr 35 ns RθJC 4 °C/W Tj -55 ~ +175 °C T stg -55 ~ +175 °C NOTE 1:Reverse recovery test conditions I F =0.5A,I R =1.0A, Irr=0.25A http://www.microdiode.com Rev:2025A1 Page :1 MURB2020D THRU MURB2060D Reverse Voltage - 200 to 600 Volts Forward Current - 20.0 Ampere Ratings And Characteristic Curves Fig.2 Typical Reverse Characteristics 25 20 15 10 5.0 0.0 20 40 60 100 120 140 160 180 80 Instaneous Reverse Current ( mA) Average Forward Current (A) Fig.1 Typical Forward Current Derating Curve 10 1.0 T J =125°C 0.1 0.01 T J =25°C 0.001 0.0001 0 Case Temperature (°C) Peak Forward Surage Current (A) 0V 60 0V 40 0V 1.0 20 Instaneous Forward Current (A) T J =25°C 0.1 1.0 1.5 Instaneous Forward Voltage (V) 60 80 100 Fig.4 Maximum Non-Repetitive Peak Forward Surage Current 10 0.5 40 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic 0.01 0 20 2.0 180 150 120 90 60 30 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles at 60Hz The curve above is for reference only. http://www.microdiode.com Rev:2025A1 Page :2 MURB2020D THRU MURB2060D Reverse Voltage - 200 to 600 Volts Forward Current - 20.0 Ampere Outlitne Drawing TO-263(D2PAK) Package Outline Dimensions C A E D B a L2 b L L1 L3 b1 H G G TO-263(D2PAK) mechanical data A B b b1 max 10.4 9.4 1.50 0.91 min 9.6 8.4 1.07 0.70 UNIT C D G H L L1 L2 L3 a 4.80 11.00 1.40 2.74 0.60 6.0 1.47 1.75 3.18 0.25 4.30 2.34 0.30 4.1 1.07 1.0 1.7 0 E mm 9.68 1.20 8. 50 3 . 00 Suggested Pad Layout Note: 1. Controlling dimension:in/millimeters. 2. General tolerance: ±0.05mm. 3. The pad layout is for reference purposes only. 3.00 8 .4 0 1 .2 0 http://www.microdiode.com Rev:2025A1 Page :3 MURB2020D THRU MURB2060D Reverse Voltage - 200 to 600 Volts Forward Current - 20.0 Ampere TO-263 Embossed Carrier Tapeape Packaging Description: TO-263 parts are shipped in tape. The carrier tape is made from a dissipative (carbon filled) polycarbonate resin. The cover tape is a multilayer film (Heat Activated Adhesive in nature) primarily composed of polyester film,adhesive laye,sealant, and anti-static sprayed agent.These reeled parts In standard option are shipped with 800 units per 13" or 33.0cm diameter reel. The reels are clear in color and is made of polystyrene plastic (anti-static coated). TO-263 Tape Leader and Trailer TO-263 Reel 800 pcs 13 Inch http://www.microdiode.com 1,600 pcs 340×336×66 8,000 pcs 400×353×365 Rev:2025A1 Page :4 MURB2020D THRU MURB2060D Reverse Voltage - 200 to 600 Volts Forward Current - 20.0 Ampere Important Notice and Disclaimer Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen). Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Shenzhen). http://www.microdiode.com Rev:2025A1 Page :5
MURB2060D 价格&库存
很抱歉,暂时无法提供与“MURB2060D”相匹配的价格&库存,您可以联系我们找货
