M20A
M20A
    MDD(辰达半导体)
    SMA(DO-214AC)
    2KV 1A
M20A 数据手册
M20A Reverse Voltage - 2000 Volts Forward Current - 1.0 Ampere SURFACE MOUNT GENERAL PURPOSE SILICONRECTIFIER Features DO-214AC/SMA  For surface mounted applications  Low profile packag  Glass Passivated Chip Juntion  Easy to pick and place 0.110(2.80) 0.090(2.30) 0.067 (1.70) 0.051 (1.30)  Lead free in comply with EU RoHS 2011/65/EU 0.177(4.50) 0.150(3.80) directives 0.012(0.305) 0.006(0.152) 0.097(2.45) 0.073(1.85) Mechanical Data Case: SMA molded plastic body Terminals: Solderable per MIL-STD-750,Method 2026 Polarity: Polarity symbol marking on body Mounting Position: Any Weight : 0.002 ounce, 0.055grams 0.061(1.55) 0.029(0.75) 0.008(0.20) 0.002(0.05) 0.209(5.30) 0.184(4.70) Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter MDD M20A UNITS VRMS VDC 2000 1400 2000 V V V I(AV) 1.0 A IFSM 30 A VF 1.1 5 50 V μA 20 pF 95 ℃/W -55 to +150 ℃ SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at Tc=100℃ Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) Maximum instantaneous forward voltage at 1A Maximum DC reverse current at rated DC blocking voltage TA=25℃ TA=125℃ Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) VRMM IR CJ RJA Operating junction and storage temperature range TJ,TSTG Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas http://www.microdiode.com Rev:2024A2 Page :1 M20A Reverse Voltage - 2000 Volts Forward Current - 1.0 Ampere Typical Characterisitics Fig.2 Typical Reverse Characteristics Instaneous Reverse Current(μ A) Fig.1 Forward Current Derating Curve Average Forward Current (A) 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 100 T J =125°C 10 1.0 T J =25°C 0.1 00 175 20 40 60 80 100 120 140 percent of Rated Peak Reverse Voltage (%) Case Temperature (°C) Fig.4 Typical Junction Capacitance 10 T J =25°C 1.0 0.1 pulse with 300μs 1% duty cycle 0.01 0.0 Junction Capacitance (pF) Instaneous Forward Current (A) Fig.3 Typical Instaneous Forward Characteristics T J =25°C 100 10 1 0.5 1.0 1.5 2.0 2.5 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 35 30 25 20 15 10 8.3 ms Single Half Sine Wave (JEDEC Method) 05 00 1 10 100 Number of Cycles The curve above is for reference only. http://www.microdiode.com Rev:2024A2 Page :2 M20A Reverse Voltage - 2000 Volts Forward Current - 1.0 Ampere Packing information unit:mm P0 P1 d Item Symbol Tolerance SMA Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width A B C d D D1 D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 2.80 5.33 2.36 1.50 330.00 50.00 178.00 62.00 13.00 1.75 5.50 4.00 4.00 2.00 0.28 12.00 18.00 E F B A W P D2 D1 T C W1 D Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) 2,000 4.0 4,000 183*155*183 178 CARTON SIZE (m/m) CARTON (pcs) APPROX. GROSS WEIGHT (kg) SMA 7" SMA 11" 5,000 4.0 10,000 290*290*38 330 310*310*360 80,000 11.0 SMA 13" 7,500 4.0 15,000 335*335*38 330 350*330*360 120,000 14.5 382*356*392 160,000 16.0 Suggested Pad Layout http://www.microdiode.com Symbol Unit (mm) Unit (inch) A 1.68 0.066 B 1.80 0.071 C 0.157 D 4.2 2.40 E 6 0.220 0.094 Rev:2024A2 Page :3
很抱歉,暂时无法提供与“M20A”相匹配的价格&库存,您可以联系我们找货
