MDD4N60F
600V N-Channel Enhancement Mode MOSFET
VDS
600V
ID(Tc=25℃)
4A
RDS(on),max
2.4Ω@VGS=10V
Qg,typ
12.8nC
TO-220F-3L
1
General Features
Low RDS(on)
Low gate charge
100% UIS tested
RoHS compliant
2
3
Equivalen t Circuit
Application
Power faction correction.
Switched mode power supplies.
LED driver.
Absolute Maximum Ratings (TA=25℃unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
600
V
Gate-Source Voltage
VGS
±30
V
Continuous Drain Current
ID
4
A
Pulsed Drain Current(Note 1)
IDM
16
A
EAS
245
mJ
dv/dt
5
V/ns
Power Dissipation TO-220F
PD
32
W
Junction Temperature
TJ
150
Storage Temperature
Tstg
-55 ~150
Avalanche Energy
Single Pulsed (Note 2)
Peak Diode Recovery dv/dt (Note 3)
Thermal Characteristics
Value
Parameter
Symbol
Thermal resistance, Junction-to-case
RθJC
3.8
°C/W
Thermal resistance, Junction-to-ambient
RθJA
62.5
°C/W
Notes:
TO-220F
Unit
1. Pulse width limited by maximum junction temperature.
2. L=10mH, IAS = 7A, Starting Tj= 25°C.
3. ISD = 4A, di/dt≤100A/us, VDD≤BVDS, Starting Tj= 25°C.
1/7
V 1.0
MDD4N60F
Ta = 25℃ unless otherwise specified
Symbol
Parameter
Condition
Min
Typ
Max
Unit
VGS=0V, ID=250μA
600
V
Forward
VGS=30V, VDS=0V
100
nA
Reverse
VGS=-30V, VDS=0V
-100
nA
V(BR)DSS
Drain-Source Breakdown Voltage
IGSS
Gate-Source Leakage Current
IDSS
Drain-Source Leakage Current
VDS=600V, VDS=0V
1
uA
VGS(TH)
Gate Threshold Voltage
VDS=VGS, ID=250μA
2.0
4.0
V
RDS(ON)
Drain-Source On-State Resistance
VGS=10V, ID=2A
2.0
2.4
Ω
Min
Typ
Max
Unit
580
pF
50
pF
3
pF
12.8
nC
3.1
nC
5.5
nC
Min
Typ
Max
Unit
13
ns
ID=4A,
31
ns
RG=10Ω
38
ns
17
ns
Min
Typ
Max
Unit
Dynamic Electrical Characteristics
Symbol
Parameter
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Qg
Total Gate Charge
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
Condition
VDS=25V
VGS=0V
f=1MHz
VDS=480V,
VGS=10V,
ID=4A
(Note1,2)
Switching Characteristics
Symbol
Parameter
td(on)
Turn on Delay Time
tr
Turn on Rise Time
td(off)
Turn Off Delay Time
tf
Turn Off Fall Time
Condition
VDS=300V,
(Note1,2)
Source Drain Diode Characteristics
Symbol
Parameter
Condition
VSD
Drain-Source Diode Forward Voltage
IS=4A, VGS=0V
1.5
V
trr
Body Diode Reverse Recovery Time
VR=400V
275
ns
Qrr
Body Diode Reverse Recovery Charge
1.43
uC
IF=4A,
-diF/dt =100A/µs
Notes:
1.Pulse test ; Pulse width≤300us, duty cycle≤2%.
2.Essentially independent of operating temperature.
2/7
V 1.0
MDD4N60F
Electrical Characteristics Diagrams
Figure 1. Typical Output Characteristics
Figure 2. Transfer Characteristics
VGS=10V
VGS=9V
VGS=6V
VGS=8V
Tc = 25°C
VGS=7V
VGS=5.5V
Tc = 150°C
VDS ,Drain−source voltage (V)
VGS ,Gate−source voltage (V)
Figure 3. On-Resistance Variation vs. Drain Current
Figure 4. Threshold Voltage vs. Temperature
VGS = 10 V
Tc = 25°C
Pulse test
IDS=0.25 mA
Pulse test
ID ,Drain current (A)
Tj ,Junction temperature (°C)
Figure 5. Breakdown Voltage vs. Temperature
Figure 6. On-Resistance vs. Temperature
VGS=10 V
IDS=2 A
Pulse test
VGS=0 V
IDS=0.25 mA
Pulse test
3/7
V 1.0
MDD4N60F
Figure 7. Capacitance Characteristics
Figure 8. Gate Charge Characterist
VDS=300
VDS=120
Ciss
Notes:f = 1 MHz,VGS=0 V
Ciss = Cgs + Cgd (Cds = shorted)
Coss = Cds + Cgd
Crss = Cgd
VDS=480
Coss
Crss
ID = 4 A
VDS ,Drain-Source Voltage (V)
QG ,Total Gate Charge (nC)
Figure 9. Maximum Safe Operating Area
Figure 10. Maximum Safe Operating Area
TO-220/TO-252
TO-220F
100us
100us
10ms
Limited by RDS(on)
1ms
10ms
1ms
Limited by RDS(on)
DC
Notes:
T = 25°C
c
Notes:
T = 25°C
j
T = 150°C
DC
c
T = 150°C
j
Single Pulse
Single Pulse
Figure 11. Power Dissipation vs. Temperature
Figure 12. Power Dissipation vs.
Temperature TO-220/TO-252
TO-220F
Tc ,Case temperature (°C)
4/7
V 1.0
MDD4N60F
Figure 13. Continuous Drain Current vs. Temperature
Figure 14. Body Diode Transfer Characteristics
Tc = 150°
Tc = 25°C
VSD ,Source-Drain Voltage (V)
Figure 15 Transient Thermal Impendance,Junction to Case, TO-220F
P
DM
In descending order
D= 0.5, 0.2, 0.1, 0.05, 0.02, 0.01, single pulse
t
Duty = t/T
T
Z (t)=3.8°C/W Max.
θJC
t ,Pulse Width (s)
Figure 16. Transient Thermal Impendance,Junction to Case, TO-220/TO-252
In descending order
P
DM
t
Duty = t/T
Z (t)=1.62°C/W Max.T
θJC
t ,Pulse Width (s)
5/7
V 1.0
MDD4N60F
RL
VDS
RG
VGS
VDD
D.U.T.
10V
Pulse Width≤ 1μs
Duty Factor≤0.1%
Switching Test Circuit
12V
0.2µF
50kΩ
0.3µF
Switching Waveforms
Same
Type as
D.U.T.
VDS
VGS
DUT
3mA
Gate Charge Test Circuit
Gate Charge Waveform
Unclamped Inductive Switching Test Circuit
Unclamped Inductive Switching Waveforms
The curve above is for reference only.
6/7
V 1.0
MDD4N60F
Mechanical Dimensions for TO-220F-3L
SYMBOL
E
A
A1
A4
c
D
H1
e
L
L1
ФP
ФP3
F3
G3
b1
b2
MIN
9.96
4.50
2.34
2.56
0.40
15.57
12.68
2.88
3.03
3.15
3.15
1.25
1.18
0.70
mm
NOM
10.16
4.70
2.54
2.76
0.50
15.87
6.70REF
2.54BSC
12.98
3.03
3.18
3.45
3.30
1.35
1.28
0.80
MAX
10.36
4.90
2.74
2.96
0.65
16.17
13.28
3.18
3.38
3.65
3.45
1.55
1.43
0.95
Package Marking and Ordering Information
Part Number
Marking
Package
Units/Tube
MDD4N60F
4N60F
TO-220F
50
7/7
Units/Reel
V 1.0
