MDD4N60D
600V N-Channel Enhancement Mode MOSFET
VDS
600 V
ID(Tc=25℃)
4A
RDS(on),typ
1.75Ω@VGS=10V
Qg,typ
12nC
2
1
3
General Features
Equivalen t Circuit
Ultra low gate charge
Low reverse transfer Capacitance
Fast switching capability
Avalanche energy tested
Improved dv/dt capability, high ruggedness
Application
High efeciency switch mode power supplies
Electronic lamp ballasts based on half bridge
LED power supplies
Absolute Maximum Ratings (TA=25℃unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
600
V
Gate-Source Voltage
VGS
±30
V
Continuous Drain Current
ID
4
A
Pulsed Drain Current(Note 1)
IDM
16
A
EAS
134
mJ
IS
4
A
Diode pulse current
IS,pulse
16
A
Peak Diode Recovery dv/dt (Note 3)
dv/dt
5
Power Dissipation
PD
100
W
Junction Temperature
TJ
150
Storage Temperature
Tstg
-55 ~150
Avalanche Energy
Single Pulsed (Note 2)
Continuous diode forward current
V/ns
Thermal Characteristics
Parameter
Symbol
Value
Unit
Thermal resistance, Junction-to-case
RθJC
1.2
°C/W
Thermal resistance, Junction-to-ambient
RθJA
32.8
°C/W
Notes:
1. Pulse width limited by maximum junction temperature.
2. L=10mH, IAS = 5.2A, Starting Tj= 25°C.
3. ISD = 4A, di/dt≤100A/us, VDD≤BVDS, Starting Tj= 25°C.
1/5
V 1.1
MDD4N60D
Ta = 25℃ unless otherwise specified
Symbol
Parameter
Condition
Min
Typ
Max
Unit
VGS=0V, ID=250μA
600
V
Forward
VGS=30V, VDS=0V
100
nA
Reverse
VGS=-30V, VDS=0V
-100
nA
V(BR)DSS
Drain-Source Breakdown Voltage
IGSS
Gate-Source Leakage Current
IDSS
Drain-Source Leakage Current
VDS=600V, VGS=0V
1
uA
VGS(TH)
Gate Threshold Voltage
VDS=VGS, ID=250μA
2.0
4.0
V
RDS(ON)
Drain-Source On-State Resistance
VGS=10V, ID=2A
1.75
2.5
Ω
Min
Typ
Max
Unit
600
pF
61
pF
10
pF
12
nC
3.2
nC
4.4
nC
Min
Typ
Max
Unit
12
ns
18
ns
49
ns
27
ns
Dynamic Electrical Characteristics
Symbol
Parameter
Ciss
Input Capacitance
Coss
Output Capacitance
Condition
VDS=25V
VGS=0V
Crss
Reverse Transfer Capacitance
Qg
Total Gate Charge
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
f=1MHz
VDS=300V,
VGS=10V,
ID=2A
Switching Characteristics
Symbol
Parameter
td(on)
Turn on Delay Time
tr
Turn on Rise Time
td(off)
Turn Off Delay Time
tf
Turn Off Fall Time
Condition
Vgs= 10V
VDS=300V,
ID=2A,
RG=24Ω
Source Drain Diode Characteristics
Symbol
Parameter
Condition
Min
Typ
Max
Unit
ISD
Source drain current(Body Diode)
4
A
ISM
Pulsed Current
16
A
VSD
Drain-Source Diode Forward Voltage
IS=4A, VGS=0V
0.8
1.2
V
trr
Body Diode Reverse Recovery Time
VR=400
290
ns
Qrr
Body Diode Reverse Recovery Charge
0.8
uC
IF=4A,
di/dt =100A/µs
2/5
V 1.1
MDD4N60D
Electrical Characteristics Diagrams
Figure 1. Typical Output Characteristics
Figure 2. Transfer Characteristics
8
8
VDS = 20V
VGS = 10V
VGS =6.0V
6
TJ = -55°C
6
ID(A)
ID(A)
VGS = 5.0V
4
2
4
2
TJ = 25°C
VGS = 4.5V
TJ = 125°C
10
15
8
VDS(V)
12
16
VGS(V)
Figure 3. On-Resistance Variation vs. Drain Current
Figure 4. Body Diode Characteristics
4000
100
VGS = 0V
3200
2400
TJ = 125°C
IS(A)
RDS(ON)(mΩ)
10
VGS = 10V
1600
1
TJ = -55°C
0.1
800
TJ = 25°C
2
3
4
5
6
0.01
0.4
ID(A)
1
1.2
Figure 6. On-Resistance vs. Temperature
3
VGS = 10V
ID = 2A
ID = 1mA
1.15
2.5
1.10
Normalized RDS(ON)
Normalized V(BR)DSS
0.8
VSD(V)
Figure 5. Breakdown Voltage vs. Temperature
1.20
0.6
1.05
1.00
0.95
2
1.5
1
0.90
0.5
0.85
-80
-40
80
120
160
200
-80
-40
80
120
160
200
TJ(℃) Junction Temperature
3/5
V 1.1
MDD4N60D
RL
VDS
RG
VGS
VDD
D.U.T.
10V
Pulse Width≤ 1μs
Duty Factor≤0.1%
Switching Test Circuit
12V
0.2µF
50kΩ
0.3µF
Switching Waveforms
Same
Type as
D.U.T.
VDS
VGS
DUT
3mA
Gate Charge Test Circuit
Gate Charge Waveform
Unclamped Inductive Switching Test Circuit
Unclamped Inductive Switching Waveforms
The curve above is for reference only.
4/5
V 1.1
MDD4N60D
Mechanical Dimensions for TO-252
Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications at
any time without notice.
Customers should obtain and confirm the latest product information and specifications before final design, purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for
any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer
product design.
Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any
unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems
without express written approval of Microdiode Electronics (Shenzhen).
5/5
V 1.1
很抱歉,暂时无法提供与“MDD4N60D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.46178
- 50+1.14578
- 150+1.01034
- 500+0.84143
