2N7002KDW
SOT-363 Plastic-Encapsulate MOSFETS
SOT-363
60V N-Channel Enhancement Mode MOSFET
RDS(on)Max
V(BR)DSS
2.7Ω@10V
60 V
ID MAX
0.34A
3.0Ω@4.5V
Mechanical Data
Feature
z
z
z
z
z
z
z
High density cell design for low RDS(ON)
Voltage controlled small signal switch
Rugged and reliable
High saturation current capability
ESD protected
Load Switch for Portable Devices.
DC/DC Converter.
z
z
z
Marking
SOT-363 Small Outline Plastic Package.
Epoxy UL: 94V-0.
Mounting Position: Any.
Equivalent circuit
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
60
V
Gate-Source Voltage
VGS
±20
V
Continuous Drain Current
ID
0.34
A
Power Dissipation
PD
150
mW
RθJA
833
℃/W
Junction Temperature
TJ
150
Storage Temperature
Tstg
-50 ~+150
Thermal Resistance from Junction to Ambient
The above data are for reference only.
http://www.microdiode.com
Rev:2024A1
Page :1
2N7002KDW
MOSFET ELECTRICAL CHARACTERISTICS
Ta=25°C unless otherwise specified
Symbol
Parameter
Condition
Min
Typ
Max
Unit
V(BR)DSS
Drain-Source Breakdown Voltage
VGS=0V ID=250μA
60
V
IDSS
Zero Gate Voltage Drain Current(TA=25℃)
VDS=48V, VGS=0V
1
μA
IGSS
Gate-Body Leakage Current
VGS=±20V, VDS=0V
±10
uA
VGS(TH)
Gate Threshold Voltage
VDS=VGS, ID=1mA
1.0
1.3
2.5
V
RDS(ON)
Drain-Source On-State Resistance②
VGS=10V, ID=0.5A
0.9
2.7
Ω
RDS(ON)
VGS=4.5V, ID=0.2A
1.1
3
Ω
40
pF
30
pF
10
pF
30
nC
10
ns
15
ns
VGS=0V, IS=300mA,
VR=25V, dIs/dt=-100A/us
30
ns
Igs=±1mA(Open Drain)
±21.5
±32
V
Dynamic Electrical Characteristics
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Qr
Recovered Charge
VDS=10V, VGS=0V,
f=1MHz
VDS=0V,ID=0.2A,
VR=25V,dIs/dt=-100A/us
Switching Characteristics
t d(on)
Turn on Delay Time
t d(off)
Turn Off Delay Time
t rr
Reverse Recovery Time
VDD=50V, RL=250Ω,
VGS=10V, RG=50Ω
Source Drain Diode Characteristics
BVGSO
Gate-Source Breakdown Voltage
Notes:
① Pulse width limited by maximum allowable junction temperature
②Pulse test ; Pulse width300s, duty cycle2%.
Rev:2024A1
Page :2
2N7002KDW
Typical Characteristics
The curve above is for reference only.
Rev:2024A1
Page :3
2N7002KDW
Outlitne Drawing
SOT-363Package Outline Dimensions
Suggested Pad Layout
Rev:2024A1
Page :4
很抱歉,暂时无法提供与“2N7002KDW”相匹配的价格&库存,您可以联系我们找货
