MDD4438
60V N-Channel Enhancement Mode MOSFET
1. Description
This N-Channel MOSFET is based on MDD's unique device design to achieve low RDS(ON), fast
switching performance. The low Vth series is specially designed to use in synchronous
rectification power systems with low driving voltage.
2. Features
• LOW RDS(ON)
• Extremely low switching loss
• Excellent reliability and uniformity
• Fast switching and soft recovery
3. Application
• Battery protection
• Power management
• Switched mode power supply
4. Absolute Maximum Ratings(TA=25°C unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
60
V
Gate-Source Voltage
VGS
±20
V
ID
8.2
A
Pulsed Drain Current (Note 2)
IDM
40
A
Thermal Resistance, t<10s
RθJA
40
°C/W
Thermal Resistance, steady-state
RθJA
75
°C/W
PD
3.1
W
TJ
-55~+150
°C
Tstg
-55~+150
°C
Continuous Drain Current (Note 1)
Power Dissipation
Junction Temperature
Storage Temperature
Note:
1)Calculated continuous current based on maximum allowable junction temperature.
2)Repetitive rating, pulse width limited by max. junction temperature.
Rev: 2024A0
MDD4438
5. Pinning information
Pin
Symbol
Description
4
G
Gate
D
Drain
S
Source
5-8
1,2,3
Simplified outline
Equivalent Circuit
Package
Q4438
6. TA=25°C unless otherwise specified
Symbol
Marking
Parameter
Condition
SOP-8
Min
Typ
Max
Unit
VGS=0V, ID=250μA
60
V
Forward
VGS=20V
100
nA
Reverse
V(BR)DSS
Drain-Source Breakdown Voltage
IGSS
Gate-Source Leakage Current
VGS=-20V
-100
nA
IDSS
Drain-Source Leakage Current
VDS=60V, VGS=0V
Gate Threshold Voltage
VDS=VGS, ID=250μA
1.5
1
μA
1.0
2.5
Drain-Source On-State Resistance
VGS=10V, ID=8.2A
16
28
Min
Typ
Max
Unit
2000
pF
140
pF
116
pF
50
nC
7
nC
14
nC
Min
Typ
Max
Unit
10
ns
21
ns
35
ns
18
ns
Min
Typ
Max
Unit
VGS(TH)
RDS(ON)
VGS=4.5V, ID=7.6A
7. Dynamic Electrical Characteristics
Symbol
Parameter
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Qg
Total Gate Charge
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
VGS=0V
VDS=30V
f=1MHz
VGS=10V
VDS=30V
ID=10A
8. Switching Characteristics
Symbol
td(on)
tr
td(off)
tf
Parameter
Condition
Turn on Delay Time
VGS=10V
VDD=30V
ID=2A
RG=3Ω
Turn on Rise Time
Turn Off Delay Time
Turn Off Fall Time
9. Source Drain Diode Characteristics
Symbol
Condition
Parameter
Condition
V
mΩ
mΩ
Drain-Source Diode Forward Voltage
IS=8.2A, VGS=0V
0.8
V
trr
Body Diode Reverse Recovery Time
ns
Body Diode Reverse Recovery Charge
22
Qrr
IF=20A
di/dt=500A/μs
VSD
Craftsman-Made Consciention Chip
Rev: 2024A0
2/5
12
nC
www.microdiode.com
MDD4438
10.Test Circuits And Waveforms
Figure 1. Gate charge testcircuit & waveform
Figure 2.Switching time testcircuit & waveforms
Figure 3.Unclamped inductive switching (UIS)test circuit & waveforms
Figure 4. Diode reverse recoverytest circuit& waveforms
Rev: 2024A0
3/5
www.microdiode.com
MDD4438
11.Electrical Characteristics Diagrams
Ta=25℃
Pulsed
VGS=4V,4.5V,5V,5.5V
VDS=5V
Ta=25℃
Pulsed
15
3.5V
10
DRAIN CURRENT
DRAIN CURRENT
ID
ID
(A)
(A)
15
5
10
5
VGS=3V
2
3
4
DRAIN TO SOURCE VOLTAGE
VDS
4
GATE TO SOURCE VOLTAGE
(V)
Figure 1. Typ. output characteristics
6
VGS
(V)
Figure 2. Typ. transfer characteristics
80
80
Ta=25℃
Pulsed
RDS(ON)
40
VGS=4.5V
VGS=10V
4
6
DRAIN CURRENT
40
ON-RESISTANCE
ON-RESISTANCE
60
(m)
60
RDS(ON)
(m)
Ta=25℃
Pulsed
ID
8
ID=8.2A
(A)
4
6
Figure 3. On-Resistance vs. Drain Current
8
VGS
10
(V)
Figure 4. On-Resistance vs. Gate Voltage
1
Ta=25℃
Pulsed
IS (A)
1.7
SOURCE CURRENT
THRESHOLD VOLTAGE
VTH
(V)
1.8
ID=250uA
1.6
1.5
25
50
75
JUNCTION TEMPERATURE
PERAT
100
J
Rev: 2024A0
0.01
1E-3
0.2
125
Figure 5. Typ. Threshole Voltage characteristics
0.1
0.4
0.6
SOURCE TO DRAIN VOLTAGE
0.8
1.0
VSD (V)
Figure 6. Forward characteristic of body diode
4/5
www.microdiode.com
MDD4438
12. Outline Drawing
SOP-8 Package Outline Dimensions
13. Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and
specifications at any time without notice. Customers should obtain and confirm the latest product information
and specifications before final design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its
products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for
application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept
any liability with products which are purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics
(Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support
devices or systems without express written approval of Microdiode Electronics (Shenzhen).
Rev: 2024A0
5/5
www.microdiode.com
很抱歉,暂时无法提供与“MDD4438”相匹配的价格&库存,您可以联系我们找货
