MDD3080
MDD3080
    MDD(辰达半导体)
    TO-252
    N沟道 30V 80A
MDD3080 数据手册
MDD3080 30V N-Channel Enhancement Mode POWER MOSFET 1. Description This N-Channel MOSFET is produced using MDD's advanced Power Trench technology. This process has been optimized to minimize on-state resistance and yet maintain superior switching performance with best in class soft body diode. 2. Features • Max RDS(on) = 4.4mΩ at VGS = 10 V, ID = 30 A • Extremely Low Reverse Recovery Charge, Qg • 100% UIS Tested • RoHS Compliant 3. Application • Power Management in Telecom.,Industrial Automation • Motor Drives and Uninterruptible Power Supplies • Current Switching in DC/DC&AC/DC(SR) Sub-systems 4. Absolute Maximum Ratings(TA=25°C unless otherwise noted) Parameter Symbol Value Unit Drain-Source Voltage VDS 30 V Gate-Source Voltage VGS ±20 V ID 80 A Single Pulsed Avalanche Energy (Note 3) EAS 247 mJ Thermal Resistance, steady-state RθJA 65 °C/W PD W TJ 83 -55~+150 °C Tstg -55~+150 °C Continuous Drain Current (Note 1) Power Dissipation Junction Temperature Storage Temperature Note: 1)Calculated continuous current based on maximum allowable junction temperature. 2)Repetitive rating, pulse width limited by max. junction temperature. 3)EAS condition:TJ=25°C, VDD=15V, V GS=10V, L= 0.5mH, Rg= 25Ω, IAS=17A. Rev: 2025A0 MDD3080 30V N-Channel Enhancement Mode MOSFET 5. Pinning information Pin Symbol Description 1 G Gate 2 3 D S Simplified outline Equivalent Circuit Drain Package MDD 3080 TO-252 G Source Parameter V(BR)DSS Drain-Source Breakdown Voltage IGSS Gate-Source Leakage Current XXY: Date code S 6. TA=25°C unless otherwise specified Symbol Marking D Condition Min Typ Max Unit VGS=0V, ID=250μA 30 — — V Forward VGS=20V — — 100 nA Reverse VGS=-20V — — -100 nA 1 μA Drain-Source Leakage Current VDS =30V, VGS=0V — VGS(TH) Gate Threshold Voltage VDS=VGS, ID=250μA 1.2 1.55 2.2 V RDS(ON) Drain-Source On-State Resistance VGS=10V, ID=30A — 3.5 4.4 mΩ VGS=4.5V, ID=20A — 4.8 7.4 mΩ Min Typ Max Unit — 2330 — pF — 280 — IDSS 7. Dynamic Electrical Characteristics Symbol Parameter Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance Qg Total Gate Charge Qgs Gate Source Charge Qgd Gate Drain Charge VGS=0V VDS =20V f=1MHz VGS=0 to 10V VDS=20V ID=20A 8. Switching Characteristics Symbol td(on) tr td(off) tf Parameter Condition Turn on Delay Time VGS =10V VDD =20V ID=20A RG=3Ω Turn on Rise Time Turn Off Delay Time Turn Off Fall Time 9. Source Drain Diode Characteristics Symbol Condition Parameter Condition — — 245 — pF pF — 48 — nC — 10 — nC — 10 — nC Min Typ Max Unit — — 10 ns 28 — — — 40 ns — 7 — — ns Min Typ Max Unit ns Drain-Source Diode Forward Voltage IS=30A, VGS=0V — 0.8 1.2 V trr Body Diode Reverse Recovery Time — 11 — ns Qrr Body Diode Reverse Recovery Charge IF=20A di/dt=100A/μs — 5 — nC VSD Craftsman-Made Consciention Chip Rev: 2025A0 2/5 www.microdiode.com MDD3080 30V N-Channel Enhancement Mode MOSFET 10.Test Circuits And Waveforms Figure 1. Gate charge testcircuit & waveform Figure 2.Switching time testcircuit & waveforms Figure 3.Unclamped inductive switching (UIS)test circuit & waveforms Figure 4. Diode reverse recoverytest circuit& waveforms Craftsman-Made Consciention Chip Rev: 2025A0 3/5 www.microdiode.com MDD3080 30V N-Channel Enhancement Mode MOSFET 11.Electrical Characteristics Diagrams 100 50 VGS = 10V VGS = 4.5V VDS = 5V VGS = 4.0V 80 40 TJ = 125°C 30 VGS = 3.5V 40 TJ = -55°C ID(A) ID(A) 60 20 10 20 TJ = 25°C VGS = 3.0V 0 0 0 1 2 3 4 5 1 1.5 2 2.5 3 3.5 4 VGS(V) VDS(V) Figure 1. Typ. output characteristics Figure 2. Typ. transfer characteristics 10 12 VDD = 15V ID = 20A 11 8 10 6 8 VGS(V) RDS(ON)(mΩ) 9 7 6 VGS = 4.5V 5 4 2 3 2 4 VGS = 10V 0 10 20 30 40 0 50 ID(A) 0 10 20 30 40 50 Qg(nC) Figure 3. On-Resistance vs. Drain Current Figure 4. Gate Charge Characteristics Is-Reverse Drain Current (A) 100 150℃ 10 25℃ 1 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 1.2 Vsd- Source to Drain Voltage (V) Figure 5. Normalized on Resistance vs. Junction Temperature Craftsman-Made Consciention Chip Rev: 2025A0 Figure 6. Forward characteristic of body diode 4/5 www.microdiode.com MDD3080 30V N-Channel Enhancement Mode MOSFET 12. Outline Drawing TO-252 Package Outline Dimensions 13. Important Notice and Disclaimer Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen). Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Shenzhen). Craftsman-Made Consciention Chip Rev: 2025A0 5/5 www.microdiode.com
MDD3080 价格&库存
很抱歉,暂时无法提供与“MDD3080”相匹配的价格&库存,您可以联系我们找货
MDD3080
  • 5+0.78700
  • 50+0.61960
  • 150+0.53590
  • 500+0.47304
库存:2037
MDD3080
  • 10+1.55690
  • 200+0.92870
  • 800+0.65010
  • 2500+0.46440
  • 5000+0.44110
  • 25000+0.40860
库存:2500
