MMDT3946
MMDT3946
    MDD(辰达半导体)
    SOT-363
    SOT-363封装双晶体管(NPN+PNP)
MMDT3946 数据手册
MMDT3946 MMDT3946 SOT-363 Plastic-Encapsulate Transistors DUAL TRANSISTOR(NPN+PNP) FEATURES z Complementary Pair z Epitaxial Planar Die Construction z Ideal for low Power Amplification and Switching z One 3904(NPN), one 3906(PNP) MAXIMUM RATINGS of TR1(NPN)3904(Ta=25℃ unless otherwise noted) Symbol Parameter Value Unit VCBO Collector-Base Voltage 60 V VCEO Collector-Emitter Voltage 40 V VEBO Emitter-Base Voltage 5 V IC Collector Current 200 mA PC Collector Power Dissipation 200 mW Thermal Resistance From Junction To Ambient 625 ℃/W Tj Junction Temperature 150 ℃ Tstg Storage Temperature -55~+150 ℃ RΘJA SOT-363 MARKING: K46 6 ● 1 5 4 K46 2 3 ELECTRICAL CHARACTERISTICS of TR1(NPN)3904(Ta= 25℃ unless otherwise specified) Parameter Symbol Test conditions Min Typ Max Unit Collector-base breakdown voltage V(BR)CBO IC=10µA, IE=0 60 V Collector-emitter breakdown voltage V(BR)CEO IC=1mA, IB=0 40 V Emitter-base breakdown voltage V(BR)EBO IE=10µA, IC=0 5 V 500 nA Collector cut-off current ICEO = VCE=30V, IB 0 Collector cut-off current ICBO VCB= 30V, IE=0 50 nA Emitter cut-off current IEBO hFE(1) VEB=5V, IC=0 50 nA DC current gain Collector-emitter saturation voltage Base-emitter saturation voltage hFE(2) hFE(3) hFE(4) hFE(5) VCE(sat) VBE(sat) VCE=1V, IC=0.1mA 40 VCE=1V, IC=1mA VCE=1V, IC=10mA VCE=1V, IC=50mA VCE=1V, IC=100mA IC=10mA, IB=1mA 70 100 60 30 fT VCE=20V,IC=20mA, f=100MHz Collector output capacitance Cob Noise figure NF VCB=5V, IE=0, f= 1MHz VCE=5V, IC=0.1mA, f=1KHz, Rg=1KΩ,△f=200MHz VCC=3V, VBE(off)=0.5V IC=10mA, IB1=1mA VCC=3V, VBE(off)=0.5V IC=10mA, IB1=1mA td Rise time tr Storage time ts Fall time tf 0.65 IC=50mA, IB=5mA Transition frequency Delay time 0.2 IC=50mA, IB=5mA IC=10mA, IB=1mA 300 V 0.3 V 0.85 V 0.95 V 300 MHz 4 pF 5 dB 35 ns 35 ns VCC=3V, IC=10mA, IB1= IB2=1mA 200 ns VCC=3V, IC=10mA, IB1= IB2=1mA 50 ns Pulse test: pulse width≤300us,duty cycle≤2.0% http://www.microdiode.com Rev:2024A0 Page :1 MMDT3946 MAXIMUM RATINGS of TR2(NPN)3906(Ta=25℃ unless otherwise noted) Symbol Parameter Value Unit VCBO Collector-Base Voltage -40 V VCEO Collector-Emitter Voltage -40 V VEBO Emitter-Base Voltage -5 V IC Collector Current -200 mA PC Collector Power Dissipation 200 mW Thermal Resistance From Junction To Ambient 625 ℃/W Tj Junction Temperature 150 ℃ Tstg Storage Temperature -55~+150 ℃ RΘJA ELECTRICAL CHARACTERISTICS of TR2(NPN)3906 (Ta= 25℃ unless otherwise specified) Parameter Symbol Test conditions Min Typ Max Unit Collector-base breakdown voltage V(BR)CBO IC=-10µA, IE=0 -40 V Collector-emitter breakdown voltage V(BR)CEO IC=-1mA, IB=0 -40 V Emitter-base breakdown voltage V(BR)EBO IE=-10µA, IC=0 -5 V Collector cut-off current ICBO VCB=-30V, IE=0 Emitter cut-off current IEBO hFE(1) VEB=-5V, IC=0 DC current gain Collector-emitter saturation voltage Base-emitter saturation voltage hFE(2) hFE(3) hFE(4) hFE(5) VCE(sat) VBE(sat) Transition frequency fT Collector output capacitance Cob Noise figure NF -50 nA -50 nA 60 VCE=-1V, IC=-0.1mA VCE=-1V, IC=-1mA VCE=-1V, IC=-10mA VCE=-1V, IC=-50mA VCE=-1V, IC=-100mA 80 100 60 30 300 IC=-10mA, IB=-1mA -0.25 IC=-50mA, IB=-5mA -0.40 V -0.85 V -0.95 V -0.65 IC=-10mA, IB=-1mA IC=-50mA, IB=-5mA 250 VCE=-20V, IC= -10mA, f= 100MHz VCB=-5V, IE=0, f=1MHz VCE=-5V, IC=-0.1mA, f=1KHz, Rg=1KΩ,△f=200MHz VCC=-3V, VBE(off)=-0.5V IC=10mA, IB1=-1mA V MHz 4.5 pF 4.0 dB 35 ns Delay time td Rise time tr VCC=-3V, VBE(off)=-0.5V IC=10mA, IB1=-1mA 35 ns Storage time ts VCC=-3V, IC=-10mA, IB1= IB2=-1mA 225 ns Fall time tf VCC=-3V, IC=-10mA, IB1= IB2=-1mA 75 ns Pulse test: pulse width≤300us,duty cycle≤2.0% http://www.microdiode.com Rev:2024A0 Page :2 MMDT3946 Typical Characteristics(3904) http://www.microdiode.com Rev:2024A0 Page :3 MMDT3946 Typical Characteristics(3906) http://www.microdiode.com Rev:2024A0 Page :4 MMDT3946 Outlitne Drawing SOT-363 Package Outline Dimensions Suggested Pad Layout http://www.microdiode.com Rev:2024A0 Page :5
MMDT3946 价格&库存
很抱歉,暂时无法提供与“MMDT3946”相匹配的价格&库存,您可以联系我们找货
