MMDT3904
MMDT3904
    MDD(辰达半导体)
    SOT-363
    SOT-363封装双晶体管(NPN+NPN)
MMDT3904 数据手册
MMDT3904 SOT-363 Plastic-Encapsulate Transistors MMDT3904 DUAL TRANSISTOR (NPN+NPN) SOT-363 FEATURES Epitaxial planar die construction Ideal for low power amplification and switching z High Stability and High Reliability MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) z z Symbol Parameter Value Unit VCBO Collector-Base Voltage 60 V VCEO Collector-Emitter Voltage 40 V VEBO Emitter-Base Voltage 5 V IC Collector Current 200 mA PC Collector Power Dissipation 200 mW Thermal Resistance From Junction To Ambient 625 ℃/W Tj Junction Temperature 150 ℃ Tstg Storage Temperature -55~+150 ℃ RΘJA MARKING: K6N 6 ● 1 5 4 K6N 2 3 ELECTRICAL CHARACTERISTICS (Ta= 25℃ unless otherwise specified) Parameter Symbol Test conditions Min Typ Max Unit Collector-base breakdown voltage V(BR)CBO IC=10µA, IE=0 60 V Collector-emitter breakdown voltage V(BR)CEO IC=1mA, IB=0 40 V Emitter-base breakdown voltage V(BR)EBO IE=10µA, IC=0 5 V Collector cut-off current ICEX VCE=30V, VEB(off)=3V 50 Collector cut-off current ICBO VCB=30V, IE=0 50 nA Emitter cut-off current IEBO hFE(1) VEB=5V, IC=0 50 nA DC current gain Collector-emitter saturation voltage Base-emitter saturation voltage hFE(2) hFE(3) hFE(4) hFE(5) VCE(sat) VBE(sat) VCE=1V, IC=0.1mA 40 VCE=1V, IC=1mA VCE=1V, IC=10mA VCE=1V, IC=50mA VCE=1V, IC=100mA IC=10mA, IB=1mA 70 100 60 30 300 0.2 IC=50mA, IB=5mA 0.65 IC=10mA, IB=1mA IC=50mA, IB=5mA nA V 0.3 V 0.85 V 0.95 V Transition frequency fT VCE=20V,IC=10mA, f=100MHz 300 Collector output capacitance Cob VCB=5V, IE=0, f= 1MHz 4 pF Noise figure NF VCE=5V, IC=0.1mA, f=1KHz,RS=1KΩ VCC=3V, VBE(off)=-0.5V IC=10mA, IB1=1mA 5 dB 35 ns MHz Delay time td Rise time tr VCC=3V, VBE(off)=0.5V IC=10mA, IB1=1mA 35 ns Storage time ts VCC=3V, IC=10mA, IB1= IB2=1mA 200 ns Fall time tf VCC=3V, IC=10mA, IB1= IB2=1mA 50 ns Pulse test: pulse width≤300us,duty cycle≤2.0% http://www.microdiode.com Rev:2024A0 Page :1 MMDT3904 Typical Characteristics http://www.microdiode.com Rev:2024A0 Page :2 MMDT3904 Outlitne Drawing SOT-363 Package Outline Dimensions Suggested Pad Layout http://www.microdiode.com Rev:2024A0 Page :3
MMDT3904 价格&库存
很抱歉,暂时无法提供与“MMDT3904”相匹配的价格&库存,您可以联系我们找货
