MDDG06R01L
MDDG06R01L
    MDD(辰达半导体)
    TOLL
    60V N通道增强模式MOSFET
MDDG06R01L 数据手册
MDDG06R01L 60V N-Channel Enhancement Mode MOSFET 1. Description This N-Channel MV MOSFET is produced using MDD Semiconductor's advanced Power Trench process that incorporates Shielded Gate technology. This process has been optimized to minimize on-state resistance and yet maintain superior switching performance with best in class soft body diode. 2. Features • Max RDS(on) = 1.5 mΩ at VGS = 10 V, ID = 30 A • Extremely Low Reverse Recovery Charge, Qrr • 100% UIS Tested • 100% dVDS Tested 3. Application • PWM Application • Motor Drives and Uninterruptible Power Supplies • Micro Solar Inverter • Battery management System 4. Absolute Maximum Ratings(TA=25°C unless otherwise noted) Parameter Symbol Value Unit Drain-Source Voltage VDS 60 V Gate-Source Voltage VGS ±20 V ID 330 A Continuous Drain Current (Note 1) Pulsed Drain Current (Note 2) IDM 1320 A Single Pulsed Avalanche Energy (Note 3) EAS 676 mJ Thermal Resistance (Junction to Case) RθJC 0.46 °C/W PD 330 W TJ -55~+150 °C Tstg -55~+150 °C Power Dissipation Junction Temperature Storage Temperature Note: 1)Calculated continuous current based on maximum allowable junction temperature. 2)Repetitive rating, pulse width limited by max. junction temperature. 3)EAS condition:TJ=25°C, VDD=40V, VGS=10V, L= 0.5mH, Rg= 25Ù, IAS=52A. Rev: 2025A0 MDDG06R01L 60V N-Channel Enhancement Mode MOSFET 5. Pinning information Pin Symbol Description 1 G Gate 9-11 D 2-8 S Simplified outline Equivalent Circuit Package MDD G06R01L Drain Source 6. TA=25°C unless otherwise specified Symbol Marking Parameter Condition TOLL Min Typ Max Unit VGS=0V, ID=250μA 60 — — V Forward VGS=20V — — 100 nA Reverse V(BR)DSS Drain-Source Breakdown Voltage IGSS Gate-Source Leakage Current VGS=-20V — — -100 nA IDSS Drain-Source Leakage Current VDS =60V, V GS=0V — 1 μA VGS(TH) Gate Threshold Voltage VDS=VGS, ID=250μA 2 — RDS(ON) Drain-Source On-State Resistance VGS=10V, ID=30A 7. Dynamic Electrical Characteristics Symbol Parameter Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance Qg Total Gate Charge Qgs Gate Source Charge Qgd Gate Drain Charge VGS=0V VDS =25V f=1MHZ VGS=10V VDS=32V ID=150A 8. Switching Characteristics Symbol td(on) tr td(off) tf Parameter Condition Turn on Delay Time VGS=10V VDD =30V ID=30A RG=3Ω Turn on Rise Time Turn Off Delay Time Turn Off Fall Time 9. Source Drain Diode Characteristics Symbol Condition Parameter Condition 3 4 V — 1.2 1.5 mΩ Min Typ Max Unit — 7397 — pF — 3885 — pF — 203 — pF — 120 — nC — 37 — nC — 33 — nC Min Typ Max Unit — 26 — ns — 33 — ns — 50 — ns — 25 — ns Min Typ Max Unit Drain-Source Diode Forward Voltage IS=30A, VGS=0V — 0.8 1.2 V trr Body Diode Reverse Recovery Time — — ns Body Diode Reverse Recovery Charge — — 74 Qrr IF=30A di/dt=100A/μs VSD Craftsman-Made Consciention Chip Rev: 2025A0 2/5 123 nC www.microdiode.com MDDG06R01L 10.Test Circuits And Waveforms 60V N-Channel Enhancement Mode MOSFET Figure 1. Gate charge testcircuit & waveform Figure 2.Switching time testcircuit & waveforms Figure 3.Unclamped inductive switching (UIS)test circuit & waveforms Figure 4. Diode reverse recoverytest circuit& waveforms Craftsman-Made Consciention Chip Rev: 2025A0 3/5 www.microdiode.com MDDG06R01L 60V N-Channel Enhancement Mode MOSFET 11.Electrical Characteristics Diagrams 400 180 10V 5V 4.5V 4V 150 300 ID (A) ID (A) 120 VDS = 5.0V VGS=3.5V 90 60 VGS=3V 200 TJ = 125°C TJ = 25°C 100 30 VGS=2.5V 0 0.0 0.2 0.4 0.6 0.8 1.0 VDS (V) 1.2 1.4 1.6 1.8 0 2.0 Figure 1. Typ. output characteristics 4 3 VGS (V) 5 Figure 2. Typ. transfer characteristics 2.0 2.5 1.8 1.6 VGS = 10V 2.0 1.4 VGS=10V 1.2 ID = 20A Normalized RDS(ON) RDS(on) (mΩ) 2 1 1.5 1.0 0.8 1.0 0.6 0.4 0.5 0.2 0.0 20 40 60 ID (A) 80 0.0 120 100 Figure 3. On-Resistance vs. Drain Current -60 0 60 120 180 Temperature (℃) Figure 4. On-Resistance vs. Junction Temperature 100 4.0 VGS = 0V VGS = VDS 3.5 10 ID = 1.0mA IS(A) VGS(th) (V) 3.0 2.5 ID = 250A TJ = 125°C 1 TJ = -55°C 2.0 0.1 1.5 1.0 TJ = 25°C -60 0 60 120 180 0.01 0 Temperature (℃) Figure 5. Normalized Threshold Voltage vs. Junction Temperature Craftsman-Made Consciention Chip Rev: 2025A0 0.2 0.4 0.6 0.8 1 1.2 VSD (V) Figure 6. Forward characteristic of body diode 4/5 www.microdiode.com MDDG06R01L 60V N-Channel Enhancement Mode MOSFET 12. Outline Drawing TOLL Package Outline Dimensions b1 A A1 H D 2xD2 D4 L1 e1 e1 L2 e E2 c 6xb 2xb2 E E1 3xb3 Min Typ Max Symbol Min Typ Max A 2.25 2.30 2.35 E 9.85 9.90 9.95 A1 1.75 1.80 1.85 E1 8.00 8.10 8.20 b 0.65 0.70 0.75 E2 0.65 0.70 0.75 b1 9.75 9.80 9.85 H 11.60 11.70 11.80 b2 0.70 0.75 0.80 H1 6.95 BSC b3 1.15 1.20 1.25 H2 5.90 BSC c 0.45 0.50 0.55 K D 10.35 10.40 10.45 L 1.55 1.65 1.75 D1 11.00 11.10 11.20 L1 0.65 0.70 0.75 D2 3.25 3.30 3.35 L2 0.50 0.60 0.70 D4 4.50 4.55 4.60 L3 0.40 0.50 0.60 e 1.20 BSC Q e1 1.225 BSC R 3.10 REF 7.95 REF 3.00 3.10 3.20 D1 H2 H1 R Symbol L K L3 Q 13. Important Notice and Disclaimer Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen). Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Shenzhen). Craftsman-Made Consciention Chip Rev: 2025A0 5/5 www.microdiode.com
MDDG06R01L 价格&库存
很抱歉,暂时无法提供与“MDDG06R01L”相匹配的价格&库存,您可以联系我们找货
