MMBT3904T
MMBT3904T
    MDD(辰达半导体)
    SOT523-3
    200MA 40V
MMBT3904T 数据手册
MMBT3904T MMBT3904T SOT-523 Plastic-Encapsulate Transistors TRANSISTOR (NPN) SOT-523 FEATURES z Complementary to MMBT3906T Small Surface Mount Package Ideal for Medium Power Amplification and Switching MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) z z Symbol Parameter 1. BASE Value Unit VCBO Collector-Base Voltage 60 V VCEO Collector-Emitter Voltage 40 V VEBO Emitter-Base Voltage 6 V IC Collector Current 0.2 A PC Collector Power Dissipation 0.15 W Thermal Resistance From Junction To Ambient 833 ℃/W Tj Junction Temperature 150 ℃ Tstg Storage Temperature -55~+150 ℃ RΘJA 2. EMITTER 3. COLLECTOR MARKING:1N (3)C 1N (1)B (2)E ELECTRICAL CHARACTERISTICS (Ta= 25℃ unless otherwise specified) Parameter Symbol Test conditions Min Typ Max Unit Collector-base breakdown voltage V(BR)CBO IC=10µA, IE=0 60 V Collector-emitter breakdown voltage V(BR)CEO I C=1mA, IB=0 40 V Emitter-base breakdown voltage V(BR)EBO IE=10µA, IC=0 6 V IEBO VEB=5V, IC=0 Emitter cut-off current Collector cut-off current DC current gain Collector-emitter saturation voltage Base-emitter saturation voltage Transition frequency ICEX = = VCE 30V,VEB(off) 3V hFE(1) * VCE=1V, IC=0.1mA 40 hFE(2) * VCE=1V, IC=1mA 70 hFE(3) * VCE=1V, IC=10mA 100 hFE(4) * VCE=1V, IC=50mA 60 100 nA 50 nA 300 VCE(sat)1 * IC=10mA, IB=1mA 0.20 V VCE(sat)2 * IC=50mA, IB=5mA 0.30 V VBE(sat)1 * IC=10mA, IB=1mA 0.85 V VBE(sat)2 * IC=50mA, IB=5mA 0.95 V fT 0.65 VCE=20V,IC=10mA,f=100MHz 300 MHz Collector output capacitance Cob VCB=5V,IE=0,f=1MHz 4 pF Input capacitance Cib VCE=5V,IE=0mA,f=1MHz 8 pF VCC=3V, VBE(off)=0.5V IC=10mA, IB1=1mA 35 ns 35 ns 200 ns 50 ns Transition frequency td Collector output capacitance tr Input capacitance ts Collector output capacitance tf IB1= IB2 1mA VCC=3V, IC=10mA,= *Pulse test: pulse width ≤300μs, duty cycle≤ 2.0%. http://www.microdiode.com Rev:2024A0 Page :1 MMBT3904T Typical Characteristics http://www.microdiode.com Rev:2024A0 Page :2 MMBT3904T Outlitne Drawing SOT-523 Package Outline Dimensions Symbol A A1 A2 b1 b2 c D E E1 e e1 L L1 θ Dimensions In Millimeters Min. Max. 0.700 0.900 0.000 0.100 0.700 0.800 0.150 0.250 0.250 0.350 0.100 0.200 1.500 1.700 0.700 0.900 1.450 1.750 0.500 TYP. 0.900 1.100 0.400 REF. 0.260 0.460 0° 8° Dimensions In Inches Min. Max. 0.028 0.035 0.000 0.004 0.028 0.031 0.006 0.010 0.010 0.014 0.004 0.008 0.059 0.067 0.028 0.035 0.057 0.069 0.020 TYP. 0.035 0.043 0.016 REF. 0.010 0.018 0° 8° Suggested Pad Layout http://www.microdiode.com Rev:2024A0 Page :3
MMBT3904T 价格&库存
很抱歉,暂时无法提供与“MMBT3904T”相匹配的价格&库存,您可以联系我们找货
