DTA143ZCA
DTA143ZCA
    MDD(辰达半导体)
    SOT-23
    数字晶体管(PNP,内置电阻)
DTA143ZCA 数据手册
DTA143Zxx Series Digital Transistors (PNP)(Built-in Resistors) 1. Features • Built-in bias resistors enable the configuration of an inverter circuit without connecting external input resistors(see equivalent circuit) • The bias resistors consist of thin-film resistors with complete isolation to allow negative biasing of the input.They also have the advantage of almost complete -ly eliminating parasitic effects • Only the on/off conditions need to be set for operation, making device design easy 2.MA xIMUM RATINGS (Ta=25℃ unless otherwise noted) Symbol Parameter Limits(DTA143Z xx) M CA UA E Unit SA KA Supply Voltage VCC -50 V Input Voltage VIN -30~+5 V Output Current IO -100 mA Power Dissipation PD Operation Junction and Storage Temperature Range 100 150 200 Tj ,Tstg 200 mW 300 200 -55~+150 ℃ 3. Electrical Characteristics (Ta=25℃unless otherwise specified) Parameter Symbol Condition Min Typ Max Unit kΩ R1 Input resistance 3.29 4.7 6.11 R2/R1 Resistance ratio 8 10 12 VO(on) Output voltage IO/II=-5mA/-0.25mA — -0.3 V Input current — VI=-5V — — -1.8 mA IO(off) Output current VCC=-50V, VI =0 — — -0.5 µA G1 DC current gain VO=-5V, IO=-10mA 80 — VCC=-5V, IO=-100µA -0.5 — — VO =-0.3V, IO=-5mA — — V VO=-10V, IO=-5mA , f=100MHz — -1.3 250 — MHz II VI(off) VI(on) fT Input voltage Transition frequency Rev:2025A0 — V DTA143Zxx Series Digital Transistors (PNP)(Built-in Resistors) 4. Pinning information Pin Symbol 1 IN 2 GND 3 1 OUT IN 2 GND 3 OUT 1 IN 2 GND 3 OUT 1 IN 2 GND 3 OUT Part Number Simplified outline DTA143ZCA 1 Marking Package E13 SOT-23 E13 SOT-23-3 E13 SOT-523 E13 SOT-323 2 3 DTA143ZKA 1 2 3 DTA143ZE 1 2 3 DTA143ZUA z 1 2 Craftsman-Made Consciention Chip Rev:2025A0 Equivalent Circuit 3 2/5 www.microdiode.com DTA143Zxx Series Digital Transistors (PNP)(Built-in Resistors) 5.Electrical Characteristics Diagrams ON Characteristics OFF Characteristics -100 -10 VO=-0.3 VCC=-5V (mA) (V) -30 -3 -3 Ta=25℃ -1 Ta=100℃ OUTPUT CURRENT INPUT VOLTAGE IO VI(ON) -10 Ta=100℃ Ta=25℃ -1 -0.3 -0.1 -0.3 -0.03 -0.1 -0.1 -0.3 -3 -1 -10 OUTPUT CURRENT GI —— IO -0.01 -0.2 -100 -30 -0.4 -0.6 INPUT VOLTAGE (mA) -0.8 VI(OFF) VO(ON) —— IO -1.0 (V) IO -1000 1000 IO/II=20 VO=-5V (mV) 300 -300 VO(ON) Ta=25℃ OUTPUT VOLTAGE DC CURRENT GAIN GI Ta=100℃ 100 30 10 -100 Ta=100℃ Ta=25℃ -30 3 1 -0.1 -1 -0.3 OUTPUT CURRENT CO 10 -10 -3 IO -10 -0.1 -100 -30 -1 -0.3 PD —— VR -10 -3 OUTPUT CURRENT (mA) —— IO -30 -100 125 150 (mA) Ta 400 f=1MHz Ta=25℃ 350 (mW) 250 POWER DISSIPATION OUTPUT CAPACITANCE 6 300 PD CO (pF) 8 4 2 DTA143ZUA/CA/KA 200 150 DTA143ZE 100 50 0 0 -4 -8 0 -12 REVERSE BIAS VOLTAGE -16 VR -20 0 (V) 25 50 75 AMBIENT TEMPERATURE 100 Ta (℃ ) The curves above is for reference only. Craftsman-Made Consciention Chip Rev:2025A0 3/5 www.microdiode.com DTA143Zxx Series Digital Transistors (PNP)(Built-in Resistors) 6 . Outline Drawing SOT-23 Package Outline Dimensions A A1 b c D E E1 e L L1 θ L L1 E E1 Symbol 1 e Dimensions In Millimeters Min Typ Max 0.65 1.40 0.20 0.00 0.30 0.55 0.20 0.08 2.70 3.10 1.15 1.65 2.80 2.10 1.70 2.10 0.15 0.50 0.35 0° 0.70 12° 7 . Suggested Pad Layout 0.037 0.95 0.037 0.95 Note: 1. Controlling dimension:in/millimeters. 2. General tolerance: ±0.05mm. 3. The pad layout is for reference purposes only. 0.079 2.0 0.035 0.9 0.031 0.8 inches mm Craftsman-Made Consciention Chip Rev:2025A0 4/5 www.microdiode.com DTA143Zxx Series Digital Transistors (PNP)(Built-in Resistors) 8.Important Notice and Disclaimer Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its productsand specifications at a ny time without notice. Customers should obtain and confirm the latest product information and specifications before final design ,purchase or use. Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen). Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Shenzhen). Craftsman-Made Consciention Chip Rev:2025A0 5/5 www.microdiode.com
DTA143ZCA 价格&库存
很抱歉,暂时无法提供与“DTA143ZCA”相匹配的价格&库存,您可以联系我们找货
