DTC143XCA
DTC143XCA
    MDD(辰达半导体)
    SOT-23
    NPN 50V 100MA
DTC143XCA 数据手册
DTC143Xxx Series Digital Transistors (NPN)(Built-in Resistors) 1. Features • Built-in bias resistors enable the configuration of an inverter circuit without connecting external input resistors(see equivalent circuit); • The bias resistors consist of thin-film resistors with complete isolation to allow negative biasing of the input.They also have the advantage of almost completely eliminating para sitic effects; • Only the on/off conditions need to be set for operation, making device design easy. 2.MAxIMUM RATINGS (Ta=25℃ unless otherwise noted) Symbol Parameter Limits(DTC143X xx) M CA UA E Unit SA KA Supply Voltage VCC 50 V Input Voltage VIN -7~+20 V Output Current IO 100 mA Power Dissipation PD Operation Junction and Storage Temperature Range 100 150 200 Tj ,Tstg 200 200 mW 300 -55~+150 ℃ 3. Electrical Characteristics (Ta=25℃unless otherwise specified) Parameter Symbol Condition Min Typ Max Unit kΩ R1 Input resistance 3.29 4.7 6.11 R2/R1 Resistance ratio 1.7 2.1 2.6 VO(on) Output voltage IO/II=10mA/0.5mA — 0.3 V Input current — VI=5V — — 1.8 mA IO(off) Output current VCC=50V, V I =0 — — 0.5 µA G1 DC current gain VO=5V, IO=10mA 30 — VCC=5V, IO=100µA 0.3 — — VO =0.3V, IO=20mA — — V VO=10V, IO=5mA , f=100MHz — 2.5 250 — MHz II VI(off) VI(on) fT Input voltage Transition frequency Rev:2025A0 — V DTC143Xxx Series Digital Transistors (NPN)(Built-in Resistors) 4. Pinning information Pin Symbol 1 IN 2 GND 3 1 OUT IN 2 GND 3 OUT 1 IN 2 GND 3 OUT 1 IN 2 GND 3 OUT Part Number Simplified outline DTC143XCA 1 Marking Package 43 SOT-23 43 SOT-23-3 43 SOT-523 43 SOT-323 2 3 DTC143XKA 1 2 3 DTC143XE 1 2 3 DTC143XUA z 1 2 Craftsman-Made Consciention Chip Rev:2025A0 Equivalent Circuit 3 2/4 www.microdiode.com DTC143Xxx Series 5.Electrical Characteristics Diagrams ON Characteristics 100 OFF Characteristics 10 VO=0.3V VCC=5V 3 (mA) (V) 30 10 1 3 OUTPUT CURRENT INPUT VOLTAGE I0 VI(ON) Digital Transistors (NPN)(Built-in Resistors) Ta=25℃ Ta=100℃ 1 Ta=25℃ 0.1 0.03 0.3 0.1 Ta=100℃ 0.3 0.1 1 0.3 10 3 OUTPUT CURRENT GI 1000 —— IO 0.01 100 30 0.0 0.4 0.8 (mA) 1.2 INPUT VOLTAGE IO VO(ON) —— 1000 1.6 VI(OFF) 2.0 (V) IO IO/II=20 VO=5V 100 300 VO(ON) DC CURRENT GAIN GI (mV) 300 OUTPUT VOLTAGE Ta=100℃ 30 Ta=25℃ 10 Ta=100℃ 100 Ta=25℃ 30 3 1 0.1 1 0.3 3 OUTPUT CURRENT CO 12 —— 10 IO (mA) 100 30 10 200 1 10 3 OUTPUT CURRENT VR PD 400 f=1MHz Ta=25℃ —— 100 30 IO (mA) Ta 350 PD 8 POWER DISSIPATION OUTPUT CAPACITANCE CO (pF) (mW) 10 6 4 300 250 200 150 DTC143XUA/CA/KA DTC143XE 100 2 50 0 0 4 8 REVERSE VOLTAGE 12 VR 16 0 25 50 75 AMBIENT TEMPERATURE (V) Craftsman-Made Consciention Chip Rev:2025A0 0 20 3/5 100 Ta 125 150 (℃ ) www.microdiode.com DTC143Xxx Series Digital Transistors (NPN)(Built-in Resistors) 6 . Outline Drawing SOT-23 Package Outline Dimensions A A1 b c D E E1 e L L1 θ L L1 E E1 Symbol 1 e Dimensions In Millimeters Min Typ Max 0.65 1.40 0.20 0.00 0.30 0.55 0.20 0.08 2.70 3.10 1.15 1.65 2.80 2.10 1.70 2.10 0.15 0.50 0.35 0° 0.70 12° 7 . Suggested Pad Layout 0.037 0.95 0.037 0.95 Note: 1. Controlling dimension:in/millimeters. 2. General tolerance: ±0.05mm. 3. The pad layout is for reference purposes only. 0.079 2.0 0.035 0.9 0.031 0.8 inches mm Craftsman-Made Consciention Chip Rev:2025A0 4/5 www.microdiode.com DTC143Xxx Series Digital Transistors (NPN)(Built-in Resistors) 8.Important Notice and Disclaimer Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen). Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Shenzhen). Craftsman-Made Consciention Chip Rev:2025A0 5/5 www.microdiode.com
DTC143XCA 价格&库存
很抱歉,暂时无法提供与“DTC143XCA”相匹配的价格&库存,您可以联系我们找货
