DTA114ECA
DTA114ECA
    MDD(辰达半导体)
    SOT-23
    特性:内置偏置电阻,无需连接外部输入电阻即可配置反相器电路。 偏置电阻由完全隔离的薄膜电阻组成,允许输入负偏置,几乎完全消除寄生效应。 仅需设置开/关条件即可操作,便于设备设计
DTA114ECA 数据手册
DTA114Exx Series Digital Transistors (PNP)(Built-in Resistors) 1. Features • Built-in bias resistors enable the configuration of an inverter circuit without connecting external input resistors(see equivalent circuit); • The bias resistors consist of thin-film resistors with complete isolation to allow negative biasing of the input.They also have the advantage of almost completely eliminating para sitic effects; • Only the on/off conditions need to be set for operation, making device design easy. 2.MAxIMUM RATINGS (Ta=25℃ unless otherwise noted) Symbol Parameter Limits(DTA114E xx) M CA UA E Unit SA KA Supply Voltage VCC -50 V Input Voltage VIN -40~+10 V Output Current IO -100 mA Power Dissipation PD Operation Junction and Storage Temperature Range 100 150 200 Tj ,Tstg 200 200 mW 300 -55~+150 ℃ 3. Electrical Characteristics (Ta=25℃ unless otherwise specified) Parameter Symbol Condition Min Typ Max Unit kΩ R1 Input resistance 7 10 13 R2/R1 Resistance ratio 0.8 1 1.2 VO(on) Output voltage IO/II=-10mA/-0.5mA — -0.3 V Input current — VI=-5V — — -0.88 mA IO(off) Output current VCC=-50V, VI =0 — — -0.5 µA G1 DC current gain VO=-5V, IO=-10mA 30 — VCC=-5V, IO=-100µA -0.5 — — VO =-0.3V, IO=-10mA — — V VO=-10V, IO=-5mA , f=100MHz — -3 250 — MHz II VI(off) VI(on) fT Input voltage Transition frequency Rev:2025A0 — V DTA114Exx Series Digital Transistors (PNP)(Built-in Resistors) 4. Pinning information Pin Symbol 1 IN 2 GND 3 1 OUT IN 2 GND 3 OUT 1 IN 2 GND 3 OUT 1 IN 2 GND 3 OUT Part Number Simplified outline DTA114ECA 1 Marking Package 14 SOT-23 14 SOT-23-3 14 SOT-523 14 SOT-323 2 3 DTA114EKA 1 2 3 DTA114EE 1 2 3 DTA114EUA z 1 2 Craftsman-Made Consciention Chip Rev:2025A0 Equivalent Circuit 3 2/4 www.microdiode.com DTA114Exx Series Digital Transistors (PNP)(Built-in Resistors) 5.Electrical Characteristics Diagrams ON Characteristics -100 -30 (mA) (V) -3 -10 -1 OUTPUT CURRENT INPUT VOLTAGE IO VI(ON) OFF Characteristics -10 VO=-0.3V Ta=25℃ -3 Ta=100℃ -1 Ta=100℃ -0.3 Ta=25℃ -0.1 -0.03 -0.3 -0.1 -0.1 -0.3 -3 -1 OUTPUT CURRENT IO GI IO 1000 -30 -10 —— VCC=-5V -0.01 -0.0 -100 -0.4 (mA) -0.8 -1.2 INPUT VOLTAGE VI(OFF) VO(ON) —— -1000 VO=-5V -1.6 -2.0 (V) IO IO/II=20 -300 VO(ON) 100 Ta=100℃ 30 OUTPUT VOLTAGE DC CURRENT GAIN GI (mV) 300 Ta=25℃ 10 Ta=100℃ -100 Ta=25℃ -30 3 1 -0.1 -0.3 -3 -1 OUTPUT CURRENT CO 12 —— -10 IO -10 -100 -30 -1 -10 -3 OUTPUT CURRENT (mA) VR PD 400 f=1MHz Ta=25℃ —— -100 -30 IO (mA) Ta 350 PD 8 POWER DISSIPATION OUTPUT CAPACITANCE CO (pF) (mW) 10 6 4 300 250 200 150 DTA114EUA/CA/KA DTA114EE 100 2 50 0 0 4 8 12 REVERSE BIAS VOLTAGE 16 VR (V) Craftsman-Made Consciention Chip Rev:2025A0 0 20 0 25 50 75 AMBIENT TEMPERATURE 3/5 100 Ta 125 150 (℃ ) www.microdiode.com DTA114Exx Series Digital Transistors (PNP)(Built-in Resistors) 6 . Outline Drawing SOT-23 Package Outline Dimensions A A1 b c D E E1 e L L1 θ L L1 E E1 Symbol 1 e Dimensions In Millimeters Min Typ Max 0.65 1.40 0.20 0.00 0.30 0.55 0.20 0.08 2.70 3.10 1.15 1.65 2.80 2.10 1.70 2.10 0.15 0.50 0.35 0° 0.70 12° 7 . Suggested Pad Layout 0.037 0.95 0.037 0.95 Note: 1. Controlling dimension:in/millimeters. 2. General tolerance: ±0.05mm. 3. The pad layout is for reference purposes only. 0.079 2.0 0.035 0.9 0.031 0.8 inches mm Craftsman-Made Consciention Chip Rev:2025A0 4/5 www.microdiode.com DTA114Exx Series Digital Transistors (PNP)(Built-in Resistors) 8.Important Notice and Disclaimer Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen). Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Shenzhen). Craftsman-Made Consciention Chip Rev:2025A0 5/5 www.microdiode.com
DTA114ECA 价格&库存
很抱歉,暂时无法提供与“DTA114ECA”相匹配的价格&库存,您可以联系我们找货
