74HC164PW
74HC164PW
    MDD(辰达半导体)
    TSSOP-14L
    8 位并行输出串行移位寄存器 14-TSSOP -40 to 125
74HC164PW 数据手册
74HC164 8-bit serial-in, parallel-out shift register Draft datasheet, Rev. 1.0 Aug 08, 2024 1.General Description The 74HC164is an 8-bit serial-in/parallel-out shift register. The device features two serial data inputs (DSA and DSB), eight parallel data outputs (Q0 to Q7). Data is entered serially through DSA or DSB and either input can be used as an active HIGH enable for data entry through the other input. Data is shifted on the LOW-to-HIGH transitions of the clock (CP) input. A LOW on the master reset input (MR) clears the register and forces all outputs LOW, independently of otherinputs. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2.Features and Benefits  Wide supply voltage range from 2.0 V to 6.0 V  High noise immunity  CMOS low power dissipation  Gated serial data inputs  Asynchronous master reset  Latch-up performance exceeds 250 mA  Complies with JEDEC standard: • JESD8C(2.7 V to 3.6 V) • JESD7A(2.0 V to 6.0 V)  ESD protection: • HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 3500 V • CDM ANSI/ESDA/JEDEC JS-002 Class C3 exceeds 2000 V  Multiple package options  Specified from -40 °C to +85 °C and from -40 °C to +125 °C Rev. 1.0 – Aug 08, 2024 1 74HC164 8-bit serial-in, parallel-out shift register Draft datasheet, Rev. 1.0 Aug 08, 2024 3.Ordering Information Table 1. Ordering information Type number Package Name 74HC164D SOP-14L 74HC164PW TSSOP-14L Rev. 1.0 – Aug 08, 2024 Description plastic small outline package; 14 leads; body width 3.9 mm plastic thin shrink small outline package; 14 leads; body width 4.4 mm Quantity 2500 2500 2 74HC164 8-bit serial-in, parallel-out shift register 4.Function Diagram Fig. 1. Logic symbol Fig. 2. IEC logic symbol Fig. 3. Logic diagram Rev. 1.0 – Aug 08, 2024 3 74HC164 8-bit serial-in, parallel-out shift register Fig. 4. Functional diagram 5.Pinning Information 5.1. Pinning Fig. 5. Top view pin configuration SOP and TSSOP Rev. 1.0 – Aug 08, 2024 4 74HC164 8-bit serial-in, parallel-out shift register 5.2. Pin description Table 2. Pin description Symbol Pin Description DSA 1 data input DSB 2 data input Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7 3, 4, 5, 6, 10, 11, 12, 13 output CP 8 clock input (LOW-to-HIGH, edge-triggered) MR 9 master reset input (active LOW) VCC 14 supply voltage GND 7 ground 6.Functional Description Table 3. Function table H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition; L = LOW voltage level; I = LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition; q = lower case letters indicate the state of the referenced input one set-up time prior to the LOW-to-HIGH clock transition; ↑ = LOW-to-HIGH transition; X = don’t care Operating modes Reset(clear) Shift Input Output MR CP DSA DSB Q0 Q1 to Q7 L X X X L L to L H ↑ l l L q0 to q6 H ↑ l h L q0 to q6 H ↑ h l L q0 to q6 H ↑ h h H q0 to q6 Rev. 1.0 – Aug 08, 2024 5 74HC164 8-bit serial-in, parallel-out shift register 7.Absolute Maximum Ratings Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be operable above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. Table 4. Absolute Maximum Ratings In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND. Symbol Parameter VCC supply voltage IIK input clamping current IOK output clamping current IO output current ICC supply current IGND ground current Ptot total power dissipation Tstg storage temperature Conditions Min Max Unit -0.5 7.0 V ±20 mA ±20 mA ±25 mA 50 mA VO < -0.5 V or VO > VCC + 0.5 V [1] VO < -0.5 V or VO > VCC + 0.5 V [1] -0.5 V < VO < VCC + 0.5 V -50 mA Tamb = -40 °C to + 125 °C -65 500 mW 150 °C [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. 8.Recommended Operating Conditions The Recommended Operating Conditions table defines the conditions for actual device operation. Recommended operating conditions are specified to ensure optimal performance to the datasheet specifications. MDD does not recommend exceeding them or designing to Absolute Maximum Ratings. Table 5. Recommended Operating Conditions Symbol Parameter VCC Conditions 74HC164 Unit Min Typ Max supply voltage 2.0 5.0 6.0 V VI input voltage 0 VCC V VO output voltage 0 VCC V Tamb ambient temperature +125 °C 625 ns/V 139 ns/V 83 ns/V -40 +25 VCC = 2.0 V Δt/ΔV input transition rise and fall rate VCC = 4.5 V VCC = 6.0 V Rev. 1.0 – Aug 08, 2024 1.67 6 74HC164 8-bit serial-in, parallel-out shift register 9.Static Characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH HIGH-level input voltage VIL LOW-level input voltage Conditions -40 °C to +85 °C -40 °C to +125 °C Max Min Max Unit Min Typ[1] VCC = 2.0 V 1.5 1.2 1.5 V VCC = 4.5 V 3.15 2.7 3.15 V VCC = 6.0 V 4.2 3.5 4.2 V VCC = 2.0 V 0.8 0.5 0.5 V VCC = 4.5 V 2.68 1.35 1.35 V VCC = 6.0 V 3.5 1.8 1.8 V VI = VIH or VIL VOH HIGH-level output voltage IO = -20μA; VCC = 2.0 V 1.9 2.0 1.9 V IO = -20μA; VCC = 4.5 V 4.4 4.5 4.4 V IO = -20μA; VCC = 6.0 V 5.9 6.0 5.9 V IO = -4.0 mA; VCC = 4.5 V 3.84 4.45 3.7 V IO = -5.2 mA; VCC = 6.0 V 5.34 5.95 5.2 V VI = VIH or VIL VOL II ICC CI LOW-level output voltage input leakage current supply current input capacitance IO = 20μA; VCC = 2.5 V 0 0.1 0.1 V IO = 20μA; VCC = 4.5 V 0 0.1 0.1 V IO = 20μA; VCC = 6.0 V 0 0.1 0.1 V V IO = 4.0 mA; VCC = 4.5 V 0.04 0.33 0.4 IO = 5.2 mA; VCC = 6.0 V 0.05 0.33 0.4 V VI = VCC or GND ; VCC = 6.0 V 0.001 ±1 ±1 μA 7.7 20 40 μA VI = VCC or GND ; IO = 0A ; VCC = 6.0 V Pin DSA, DSB 7 pF Pin CP 8 pF Pin MR 3 pF [1]All typical values are measured at Tamb = 25°C. Rev. 1.0 – Aug 08, 2024 7 74HC164 8-bit serial-in, parallel-out shift register 10. Dynamic Characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 9. Symbol Parameter tpd Min -40 °C to +125 °C Min Max Unit Typ[1] Max VCC = 2.0 V 28.5 60 65 ns VCC = 4.5 V 13.5 17 20 ns VCC = 5.0 V 11.8 15 18 ns VCC = 6.0 V 9.9 13 15 ns VCC = 2.0 V 30.8 60 65 ns VCC = 4.5 V 13.2 17 20 ns VCC = 5.0 V 12.3 15 18 ns VCC = 6.0 V 11.4 13 15 ns VCC = 2.0 V 1.3 8 10 ns VCC = 4.5 V 2.3 7 9 ns VCC = 6.0 V 2.1 7 9 ns CP to Qn; see Fig. 6 propagation delay -40 °C to +85 °C Conditions [2] MR to Qn; see Fig. 7 tPHL HIGH to LOW propagation delay see Fig. 6 tt transition time [3] CP HIGH or LOW; see Fig. 6 tW pulse width VCC = 2.0 V 100 120 ns VCC = 4.5 V 20 24 ns VCC = 6.0 V 17 20 ns VCC = 2.0 V 75 90 ns VCC = 4.5 V 15 18 ns VCC = 6.0 V 13 15 ns VCC = 2.0 V 75 90 ns VCC = 4.5 V 15 18 ns VCC = 6.0 V 13 15 ns MR LOW; see Fig. 7 MR to CP; see Fig. 7 trec recovery time Rev. 1.0 – Aug 08, 2024 8 74HC164 8-bit serial-in, parallel-out shift register Symbol Parameter -40 °C to +85 °C Conditions Min Typ[1] -40 °C to +125 °C Max Min Max Unit DSA and DSB to CP; see Fig. 8 tSU set up time VCC = 2.0 V 75 90 ns VCC = 4.5 V 15 18 ns VCC = 6.0 V 13 15 ns VCC = 2.0 V 4 4 ns VCC = 4.5 V 4 4 ns VCC = 6.0 V 4 4 ns VCC = 2.0 V 5 4 MHz VCC = 4.5 V 24 20 MHz VCC = 6.0 V 28 24 MHz DSA and DSB to CP; see Fig. 8 th hold time for CP; see Fig. 6 fmax maximum frequency CPD power dissipation capacitance per package ; VI = GND to VCC ; [4] 68 pF [1] Typical values are measured at Tamb = 25 °C. [2] tpd is the same as tPLH and tPHL. [3] tt is the same as tTHL and tTHL. [4] CPD is used to determine the dynamic power dissipation (PD in μW). PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; Σ(CL × VCC2 × fo) = sum of outputs. Rev. 1.0 – Aug 08, 2024 9 74HC164 8-bit serial-in, parallel-out shift register 10.1. Waveforms and test circuit Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 6. Waveforms showing the clock (CP) to output (Qn) propagation delays, the clock pulse width, the output transition times and the maximum clock frequency Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 7. Waveforms showing the master reset (MR) pulse width, the master reset to output (Qn) propagation delays and the master reset to clock (CP) removal time Rev. 1.0 – Aug 08, 2024 10 74HC164 8-bit serial-in, parallel-out shift register Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 8. Waveforms showing the data set-up and hold times for Dn inputs Table 8. Measurement points Type 74HC164 Rev. 1.0 – Aug 08, 2024 Input Output VI VM VX VY 0.5VCC 0.5VCC 0.1VCC 0.9VCC 11 74HC164 8-bit serial-in, parallel-out shift register Test data is given in Table 9. Definitions for test circuit: CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. Fig. 9. Test circuit for measuring switching times Table 9. Test data Type 74HC164 Rev. 1.0 – Aug 08, 2024 Input Load VI tr = tf CL VCC 2.5 ns 50 pF Test tPHL, tPLH 12 74HC164 8-bit serial-in, parallel-out shift register 11. Package Outline SOP-14L Rev. 1.0 – Aug 08, 2024 13 74HC164 8-bit serial-in, parallel-out shift register TSSOP-14L Rev. 1.0 – Aug 08, 2024 14 74HC164 8-bit serial-in, parallel-out shift register 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model CDM Charged Device Model 13. Revision History Table 11. Revision history Document ID Release Date Data sheet status 74HC164 Rev. 1.0 Jun 26, 2025 Product datasheet Rev. 1.0 – Aug 08, 2024 Change notice Supersedes 15
74HC164PW 价格&库存
很抱歉,暂时无法提供与“74HC164PW”相匹配的价格&库存,您可以联系我们找货
