74LVC1G17
Single Schmitt trigger buffer
Product datasheet, Rev1.0
Aug 08, 2024
1.General Description
The 74LVC1G17 is a single buffer Schmitt-trigger. Inputs can be driven from either 3.3 V or 5 V
devices. This feature allows the use of these devices as translators in mixed 3.3 V and 5 V
environments. This device is fully specified for partial power down applications using IOFF. The
IOFF circuitry disables the output, preventing the potentially damaging backflow current through
the device when it is powered down.
2.Features and Benefits
Wide supply voltage range from 1.65 V to 5.5 V
Overvoltage tolerant inputs to 5.5 V
High noise immunity
±24 mA output drive (VCC = 3.0 V)
CMOS low power dissipation
Latch-up performance exceeds 100 mA
Direct interface with TTL levels
IOFF circuitry provides partial Power-down mode operation
Unlimited rise and fall times
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8B/JESD36 (2.7 V to 3.6 V)
ESD protection:
HBM ANSI/ESDA/JEDEC JS-001 Class 3B exceeds 8000 V
MM JESD22-A115C Class C exceeds 550 V
CDM ANSI/ESDA/JEDEC JS-002 Class C3 exceeds 2000 V
Multiple package options
Rev. 1.0 – Aug 08, 2024
1
74LVC1G17
3.Ordering Information
Table 1. Ordering information
Package
Type number
Name
Description
Quantity
74LVC1G17GV
SOT23-5L
SOT23 package, 5 pins
2.92 mm × 1.6 mm; 1.25 mm (Max) height
3000
74LVC1G17GW
SOT353
SOT353 package, 5 pins
2.1 mm × 1.25 mm; 1.1 mm (Max) height
3000
74LVC1G17GS
DFN1x1-6L
DFN1×1 package, 6 pins
1 mm × 1 mm; 0.42 mm (Max) height
3000
74LVC1G17GM
DFN1x1.456L
DFN1.45×1 package, 6 pins
1.45 mm × 1 mm; 0.6 mm (Max) height
3000
74LVC1G17GX
DFN0.8x0.84L
DFN0.8×0.8 package, 5pins
0.8 mm × 0.8 mm; 0.4 mm (Max) height
3000
74LVC1G17YZV
DFN-4L
DFN package, 4pins
0.888 mm × 0.888 mm; 0.4 mm (Max) height
3000
4.Function Diagram
Fig 1.
Logic symbol
Fig 2.
IEC logic symbol
Fig 3.
Logic diagram
2
74LVC1G17
5.Pinning Information
5.1. Pin map
Fig 4. Top view pin configuration SOT23-5 and SOT353
Fig 5. Top view pin configuration DFN6L
Fig 6. Top view pin configuration DFN0.8x0.8-4L
Fig 7. Top view pin configuration DFN-4L
5.2. Pin description
Table 2. Pin description
Pin
Symbol
SOT23-5, SOT353 and
DFN0.8x0.8-4L
DFN-6L
DFN-4L
NC
1
1, 5
Not connected
A
2
2
1
Data input
GND
3
3
2
Ground (0V)
Y
4
4
3
Data output
VCC
5
6
4
Supply voltage
Description
3
74LVC1G17
6.Functional Description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level.
Input
Output
A
Y
L
L
H
H
7.Absolute Maximum Ratings
Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be
operable above the recommended operating conditions and stressing the parts to these levels is not
recommended. In addition, extended exposure to stresses above the recommended operating conditions may
affect device reliability. The absolute maximum ratings are stress ratings only.
Table 4. Absolute Maximum Ratings
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND.
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO
output voltage
IO
output current
ICC
supply current
IGND
ground current
Ptot
total power dissipation
Tstg
storage temperature
Conditions
VI < 0 V
Min
Max
Unit
-0.5
6.5
V
-50
[1]
-0.5
6.5
V
±50
mA
-0.5
VCC + 0.5
V
-0.5
6.5
V
±50
mA
100
mA
VO >VCC or VO < 0 V
Active
[1]
Power-down
[1]
mode
mode;
VCC
V
mA
VO = 0 V to VCC
-100
Tamb = -40 °C to + 125 °C
-65
mA
250
mW
150
°C
[1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
4
74LVC1G17
8.Recommended Operating Conditions
The Recommended Operating Conditions table defines the conditions for actual device operation.
Recommended operating conditions are specified to ensure optimal performance to the datasheet
specifications. MDD does not recommend exceeding them or designing to Absolute Maximum Ratings.
Table 5. Recommended Operating Conditions
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Conditions
Min
Typ
Max
Unit
1.65
5.5
V
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
-40
125
°C
5
74LVC1G17
9.Static Characteristics
Table 6. Static characteristics
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
-40 °C to +85 °C
Min
Typ[1]
-40 °C to +125 °C
Max
Min
Max
Unit
VI = VT+ or VTIO = -100μA;
VCC = 1.65 V to 5.5 V
VOH
HIGH-level
output voltage
VCC - 0.1
VCC - 0.1
V
IO = -4 mA; VCC = 1.65 V
1.2
0.95
V
IO = -8 mA; VCC = 2.3 V
1.9
1.7
V
IO = -12 mA; VCC = 2.7 V
2.2
1.9
V
IO = -24 mA; VCC = 3.0 V
2.3
2.0
V
IO = -32 mA; VCC = 4.5 V
3.8
3.4
V
VI = VT+ or VT-
VOL
LOW-level
output voltage
IO = 100μA;
0.10
0.10
V
IO = 4 mA; VCC = 1.65 V
0.45
0.70
V
IO = 8 mA; VCC = 2.3 V
0.30
0.45
V
IO = 12 mA; VCC = 2.7 V
0.40
0.60
V
IO = 24 mA; VCC = 3.0 V
0.55
0.80
V
IO = 32 mA; VCC = 4.5 V
0.55
0.80
V
II
Input leakage
current
VI = 5.5 V or GND ;
VCC = 5.5 V
±0.1
±1
±1
μA
IOFF
power-off
leakage current
VCC = 0V ; VI or VO = 5.5 V
±0.1
±2
±2
μA
ICC
supply current
VI = 5.5V or GND ; IO = 0A ;
VCC = 5.5V
0.1
4
4
μA
ΔICC
additional supply per pin ; VCC = 2.3V to 5.5V ;
current
VI = VCC -0.6V ; IO = 0A
5
500
500
μA
CI
input
capacitance
5
VCC = 3.3V ; VI = GND to VCC
pF
[1]All typical values are measured at VCC = 3.3V and Tamb = 25℃.
6
74LVC1G17
10. Dynamic Characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 9.
Symbol Parameter
CPD
propagation delay
power dissipation
capacitance
-40 °C to +125 °C
Unit
Min
Typ[1]
Max
Min
Max
VCC = 1.65 V to 1.95 V
4.0
10.6
19.5
4.0
19.8
ns
VCC = 2.3 V to 2.7 V
2.5
5.9
10.6
2.5
10.9
ns
VCC = 3.0 V to 3.6 V
2.0
4.3
7
2.0
7.5
ns
VCC = 4.5 V to 5.5 V
1.5
2.9
4.8
1.5
5.0
ns
nA to nY; see Fig. 8
tpd
-40 °C to +85 °C
Conditions
[2]
per buffer ; VI = GND to VCC ;
VCC = 3.3V [3]
24
pF
[1] Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 3.3 V and 5.0 V respectively.
[2] tpd is the same as tPLH and tPHL.
[3] CPD is used to determine the dynamic power dissipation (PD in μW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of outputs.
7
74LVC1G17
10.1. Waveforms and test circuit
Measurement points are given in Table 8.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig 8. The input nA to output nY propagation delays
Table 8. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
1.65 V to 1.95 V
0.5VCC
0.5VCC
2.3 V to 2.7 V
0.5VCC
0.5VCC
3.0 V to 3.6 V
1.5 V
1.5 V
4.5 V to 5.5 V
0.5VCC
0.5VCC
8
74LVC1G17
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig 9. Test circuit for measuring switching times
Table 9. Test data
Supply voltage
Input
VCC
VI
tr = tf
CL
RL
tPLH, tPHL
1.65 V to 1.95 V
VCC
≤ 2.0 ns
30 pF
1 kΩ
open
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
3.0 V to 3.6 V
3V
≤ 2.5 ns
50 pF
500 Ω
open
4.5 V to 5.5 V
VCC
≤ 2.5 ns
50 pF
500 Ω
open
Load
VEXT
9
74LVC1G17
11. Transfer Characteristics
Table 10. Transfer characteristics
Symbol Parameter
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Typ[1]
Max
Min
Max
VCC = 1.8 V
0.82
1.0
1.14
0.79
1.14
V
VCC = 2.3 V
1.03
1.2
1.40
1.00
1.40
V
VCC = 3.0 V
1.29
1.5
1.71
1.26
1.71
V
VCC = 4.5 V
1.84
2.2
2.36
1.81
2.36
V
VCC = 5.5 V
2.19
2.6
2.79
2.16
2.79
V
VCC = 1.8 V
0.46
0.6
0.75
0.46
0.78
V
VCC = 2.3 V
0.65
0.7
0.96
0.65
0.99
V
VCC = 3.0 V
0.88
1.0
1.24
0.88
1.27
V
VCC = 4.5 V
1.32
1.6
1.84
1.32
1.87
V
VCC = 5.5 V
1.58
1.9
2.24
1.58
2.27
V
VCC = 1.8 V
0.26
0.5
0.62
0.19
0.62
V
VCC = 2.3 V
0.28
0.5
0.65
0.22
0.65
V
VCC = 3.0 V
0.31
0.6
0.7
0.25
0.7
V
VCC = 4.5 V
0.40
0.6
0.77
0.34
0.77
V
VCC = 5.5 V
0.47
0.6
0.88
0.41
0.88
V
see Fig. 10 and Fig. 11
VT+
positive-going
threshold voltage
VT-
negative-going
threshold voltage
VH
hysteresis voltage
[1] Typical values are measured at Tamb = 25 °C.
10
74LVC1G17
11.1. Waveforms transfer characteristics
VT+ and VT- limits at 70% and 20%.
Fig 10.
Fig 11.
Definition of VT+, VT- and VH
12. Package Outline
SOT23-5L
11
74LVC1G17
SOT353
12
74LVC1G17
DFN1x1-6L
13
74LVC1G17
14
74LVC1G17
DFN1x1.45-6L
15
74LVC1G17
DFN0.8x0.8-4L
16
74LVC1G17
DFN-4L
Symbol
A
A1
D
E
e
ф
Dimensions in Millimeters
Min.
0.34
0.858
Max.
0.4
0.05
0.918
0.918
0.5TYP
0.21
0.25
17
74LVC1G17
13. Tape and Reel Information
13.1. Carrier tape dimensions
Direction of feed
Table 11. Carrier tape dimensions
Package version
A0(mm) B0(mm)
DFN1x1.45-6L
1.15
1.6
DFN1x1-6L
1.16
1.16
DFN0.8x0.8-4L
0.91
0.91
SOT353
2.55
2.55
SOT363
2.55
2.55
SOT23-5L/6L
3.23
3.17
K0(mm)
0.75
0.5
0.5
1.2
1.2
1.37
T(mm)
0.2
0.23
0.2
0.2
0.2
0.25
P1(mm)
4
4
2
4
4
4
W(mm)
8
8
8
8
8
8
P0(mm)
4
4
4
4
4
4
PIN 1
Q1
Q1
Q1
Q3
Q3
Q3
18
74LVC1G17
13.2. Reel and box dimensions
Table 12. Dimensions and quantities
Reel
Package
Type NO.
Dimension
version
ending
A (mm)
DFN1x1.45-6L
1R
180
DFN1x1-6L
1R
180
DFN0.8x0.8-4L
1R
180
SOT353
1R
180
SOT363
1R
180
SOT23-5L/6L
1R
180
Reel
Width W1
(mm)
12.2
12.2
12.2
12.2
12.2
12.2
SPQ
(pcs)[1]
Reels per
box
Outer box dimensions
L×W×H(mm)[2]
3000
3000
3000
3000
3000
3000
1
1
1
1
1
1
210x200x40
210x200x40
210x200x40
210x200x40
210x200x40
210x200x40
[1] Packing quantity dependent on specific product type. Please contact your local MDD representative for ordering.
[2] Dimensions for reference only.
19
74LVC1G17
14. Abbreviations
Table 13. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
15. Revision History
Table 14. Revision history
Document ID
Release Date
Data sheet status
74LVC1G17 Rev1.0
Oct 30, 2023
Product datasheet
Change notice
Supersedes
很抱歉,暂时无法提供与“74LVC1G17GW”相匹配的价格&库存,您可以联系我们找货
