74LVC1G125GV
74LVC1G125GV
    MDD(辰达半导体)
    SOT23-5L
    是一款具有三态输出的单缓冲器/线路驱动器。其输入可由3.3 V或5 V器件驱动
74LVC1G125GV 数据手册
74LVC1G125 Bus buffer/line driver; 3-state Product datasheet, Rev1.0 Aug 08, 2024 1.General Description The 74LVC1G125 is a single buffer/line driver with 3-state output. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these devices as translators in mixed 3.3 V and 5 V environments. Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall times. This device is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. 2.Features and Benefits  Wide supply voltage range from 1.65 V to 5.5 V  Overvoltage tolerant inputs to 5.5 V  High noise immunity  CMOS low power dissipation  IOFF circuitry provides partial Power-down mode operation  ±24 mA output drive (VCC = 3.0 V)  Latch-up performance exceeds 100 mA  Direct interface with TTL levels  Complies with JEDEC standard: • JESD8-7 (1.65 V to 1.95 V) • JESD8-5 (2.3 V to 2.7 V) • JESD8C (2.7 V to 3.6 V) • JESD36 (4.5 V to 5.5 V)  ESD protection: • HBM ANSI/ESDA/JEDEC JS-001 Class 3B exceeds 8000 V • MM JESD22-A115C Class C exceeds 550 V • CDM ANSI/ESDA/JEDEC JS-002 Class C3 exceeds 2000 V  Multiple package options Rev. 1.0 – Aug 08, 2024 1 74LVC1G125 Bus buffer/line driver; 3-state Rev. 1.0 – Aug 08, 2024 2 74LVC1G125 Bus buffer/line driver; 3-state 3.Ordering Information Table 1. Ordering information Package Type number Name Description Quantity 74LVC1G125GV SOT23-5L SOT23 package, 5 pins 2.92 mm × 1.6 mm; 1.25 mm (Max) height 3000 74LVC1G125GW SOT353 SOT353 package, 5 pins 2.1 mm × 1.25 mm; 1.1 mm (Max) height 3000 74LVC1G125GS DFN1x1-6L DFN1×1 package, 6 pins 1 mm × 1 mm; 0.42 mm (Max) height 3000 74LVC1G125GM DFN1x1.45-6L DFN1.45×1 package, 6 pins 1.45 mm × 1 mm; 0.6 mm (Max) height 3000 74LVC1G125GX DFN0.8x0.8-4L DFN0.8×0.8 package, 5pins 0.8 mm × 0.8 mm; 0.4 mm (Max) height 3000 4.Function Diagram Fig 1. Logic symbol Rev. 1.0 – Aug 08, 2024 Fig 2. IEC logic symbol Fig 3. Logic diagram 3 74LVC1G125 Bus buffer/line driver; 3-state 5.Pinning Information 5.1. Pin map Fig 4. Top view pin configuration SOT23-5 and SOT353 Fig 5. Top view pin configuration DFN6L Fig 6. Top view pin configuration DFN4L 5.2. Pin description Table 2. Pin description Symbol Pin Description SOT23-5, SOT353 and DFN4L DFN6L OE 1 1 Output enable input A 2 2 Data input GND 3 3 Ground (0V) Y 4 4 Data output NC - 5 Not connected VCC 5 6 Supply voltage Rev. 1.0 – Aug 08, 2024 4 74LVC1G125 Bus buffer/line driver; 3-state 6.Functional Description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Input Output OE A Y L L L L H H H X Z 7.Absolute Maximum Ratings Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be operable above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. Table 4. Absolute Maximum Ratings In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND. Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO output voltage IO output current ICC supply current IGND ground current Ptot total power dissipation Tstg storage temperature Conditions VI < 0 V Min Max Unit -0.5 6.5 V -50 [1] -0.5 6.5 V ±50 mA -0.5 VCC + 0.5 V -0.5 6.5 V ±50 mA 100 mA VO > VCC or VO < 0 V Active [1] Power-down [1] mode mode; VCC = 0 V mA VO = 0 V to VCC -100 Tamb = -40 °C to + 125 °C -65 mA 250 mW 150 °C [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. Rev. 1.0 – Aug 08, 2024 5 74LVC1G125 Bus buffer/line driver; 3-state 8.Recommended Operating Conditions The Recommended Operating Conditions table defines the conditions for actual device operation. Recommended operating conditions are specified to ensure optimal performance to the datasheet specifications. MDD does not recommend exceeding them or designing to Absolute Maximum Ratings. Table 5. Recommended Operating Conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature Δt/ΔV Input transition rise and fall rate Rev. 1.0 – Aug 08, 2024 Conditions Min Typ Max Unit 1.65 5.5 V 0 5.5 V Active mode 0 VCC V Power-down mode; VCC = 0 V 0 5.5 V -40 125 °C VCC = 1.65 V to 2.7 V 20 ns/V VCC = 2.7 V to 5.5 V 10 ns/V 6 74LVC1G125 Bus buffer/line driver; 3-state 9.Static Characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC = 1.65 V to 1.95 V VIH HIGH-level input VCC = 2.3 V to 2.7 V voltage VCC = 2.7 V to 3.6 V VCC = 4.5 V to 5.5 V -40 °C to +85 °C Min Typ[1] LOW-level input voltage Max Min Max Unit 0.65VCC 0.65VCC V 1.7 1.7 V 2.0 2.0 V 0.7VCC 0.7VCC V VCC = 1.65 V to 1.95 V VIL -40 °C to +125 °C 0.35VCC 0.35VCC V VCC = 2.3 V to 2.7 V 0.7 0.7 V VCC = 2.7 V to 3.6 V 0.8 0.8 V VCC = 4.5 V to 5.5 V 0.3VCC 0.3VCC V VI = VIH or VIL IO = -100μA; VCC = 1.65 V to 5.5 V VOH HIGH-level output voltage VCC - 0.1 VCC - 0.1 V IO = -4 mA; VCC = 1.65 V 1.2 0.95 V IO = -8 mA; VCC = 2.3 V 1.9 1.7 V IO = -12 mA; VCC = 2.7 V 2.2 1.9 V IO = -24 mA; VCC = 3.0 V 2.3 2.0 V IO = -32 mA; VCC = 4.5 V 3.8 3.4 V VI = VIH or VIL VOL II LOW-level output voltage Input leakage current Rev. 1.0 – Aug 08, 2024 IO = 100μA; VCC = 1.65 V to 5.5 V 0.10 0.10 V IO = 4 mA; VCC = 1.65 V 0.45 0.70 V IO = 8 mA; VCC = 2.3 V 0.30 0.45 V IO = 12 mA; VCC = 2.7 V 0.40 0.60 V IO = 24 mA; VCC = 3.0 V 0.55 0.80 V IO = 32 mA; VCC = 4.5 V 0.55 0.80 V ±1 ±1 μA VI = 5.5 V or GND ; VCC = 0 V to 5.5 V ±0.1 7 74LVC1G125 Bus buffer/line driver; 3-state IOZ OFF-state output VCC = 3.6 V; VI = VIH or VIL; current VO = 5.5 V or GND ±0.1 ±2 ±2 μA IOFF power-off leakage current VCC = 0V ; VI or VO = 5.5 V ±0.1 ±2 ±2 μA ICC supply current VI = 5.5V or GND ; IO = 0A ; VCC = 1.65V to 5.5V 0.1 4 4 μA ΔICC additional supply per pin ; VCC = 2.3V to 5.5V ; current VI = VCC -0.6V ; IO = 0A 5 500 500 μA CI input capacitance 5 VCC = 3.3V ; VI = GND to VCC pF [1]All typical values are measured at VCC = 3.3V and Tamb = 25℃. 10. Dynamic Characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 8. Symbol Parameter propagation delay enable time Max Min Max VCC = 1.65 V to 1.95 V 2.8 8.1 14.1 2.8 14.5 ns VCC = 2.3 V to 2.7 V 1.8 4.8 7.3 1.8 7.6 ns VCC = 3.0 V to 3.6 V 1.4 3.6 5.3 1.4 5.6 ns VCC = 4.5 V to 5.5 V 1.1 2.6 3.6 1.1 3.8 ns VCC = 1.65 V to 1.95 V 2.5 7.5 12.2 2.5 12.5 ns VCC = 2.3 V to 2.7 V 1.6 4.4 6.6 1.6 6.9 ns VCC = 3.0 V to 3.6 V 1.3 3.8 5.2 1.3 5.5 ns VCC = 4.5 V to 5.5 V 1.1 2.4 3.4 1.1 3.7 ns VCC = 1.65 V to 1.95 V 4.1 7.4 14.6 4.1 14.9 ns VCC = 2.3 V to 2.7 V 2.9 5.6 10.3 2.9 10.5 ns VCC = 3.0 V to 3.6 V 2.2 4.3 7.6 2.2 7.8 ns VCC = 4.5 V to 5.5 V 1.7 4.0 5.0 1.7 5.2 ns [2] OE to Y; see Fig. 8 tdis CPD disable time power dissipation Rev. 1.0 – Aug 08, 2024 Unit Typ[1] OE to Y; see Fig. 8 ten -40 °C to +125 °C Min A to Y; see Fig. 7 tpd -40 °C to +85 °C Conditions [3] [4] per buffer; VI = GND to 8 74LVC1G125 Bus buffer/line driver; 3-state capacitance VCC [5] output enabled 24 pF output disabled 0.8 pF [1] Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 3.3 V and 5.0 V respectively. [2] tpd is the same as tPLH and tPHL. [3] ten is the same as tPZH and tPZL. [4] tdis is the same as tPLZ and tPHZ. [5] CPD is used to determine the dynamic power dissipation (PD in μW). PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; Σ(CL × VCC2 × fo) = sum of outputs. 10.1. Waveforms and test circuit Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 7. The input A to output Y propagation delays Rev. 1.0 – Aug 08, 2024 9 74LVC1G125 Bus buffer/line driver; 3-state Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 8. 3-state enable and disable times Table 8. Measurement points Supply voltage Input Output VCC VM VM VX VY 1.65 V to 1.95 V 0.5VCC 0.5VCC VOL + 0.15V VOH – 0.15V 2.3 V to 2.7 V 0.5VCC 0.5VCC VOL + 0.15V VOH – 0.15V 3.0 V to 3.6 V 1.5 V 1.5 V VOL + 0.3V VOH – 0.3V 4.5 V to 5.5 V 0.5VCC 0.5VCC VOL + 0.3V VOH – 0.3V Rev. 1.0 – Aug 08, 2024 10 74LVC1G125 Bus buffer/line driver; 3-state Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 9. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VCC VI tr = tf CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ 1.65 V to 1.95 V VCC ≤ 2.0 ns 30 pF 1 kΩ open GND 2 x VCC 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open GND 2 x VCC 3.0 V to 3.6 V 3V ≤ 2.5 ns 50 pF 500 Ω open GND 6V 4.5 V to 5.5 V VCC ≤ 2.5 ns 50 pF 500 Ω open GND 2 x VCC Rev. 1.0 – Aug 08, 2024 Load VEXT 11 74LVC1G125 Bus buffer/line driver; 3-state 11. Package Outline SOT23-5L Rev. 1.0 – Aug 08, 2024 12 74LVC1G125 Bus buffer/line driver; 3-state SOT353 Rev. 1.0 – Aug 08, 2024 13 74LVC1G125 Bus buffer/line driver; 3-state DFN1x1-6L Rev. 1.0 – Aug 08, 2024 14 74LVC1G125 Bus buffer/line driver; 3-state DFN1x1.45-6L Rev. 1.0 – Aug 08, 2024 15 74LVC1G125 Bus buffer/line driver; 3-state DFN0.8x0.8-4L Rev. 1.0 – Aug 08, 2024 16 74LVC1G125 Bus buffer/line driver; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13. Revision History Table 11. Revision history Document ID Release Date Data sheet status 74LVC1G125 Rev1.0 Oct 30, 2023 Product datasheet Rev. 1.0 – Aug 08, 2024 Change notice Supersedes 17
74LVC1G125GV 价格&库存
很抱歉,暂时无法提供与“74LVC1G125GV”相匹配的价格&库存,您可以联系我们找货
