74LVC1G97
Low-power configurable multiple function gate
Product datasheet, Rev. 1.0
Aug 08, 2024
1.General Description
The 74LVC1G97 is a configurable multiple function gate with Schmitt-trigger inputs. The device
can be configured as any of the following logic functions MUX, AND, OR, NAND, NOR, inverter
and buffer; using the 3-bit input. All inputs can be connected directly to VCC or GND.
Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these
devices as translators in mixed 3.3 V and 5 V environments.
This device is fully specified for partial power down applications using IOFF. The IOFF circuitry
disables the output, preventing the potentially damaging backflow current through the device
when it is powered down.
2.Features and Benefits
Wide supply voltage range from 1.65 V to 5.5 V
Overvoltage tolerant inputs to 5.5 V
High noise immunity
±24 mA output drive (VCC = 3.0 V)
CMOS low power dissipation
Latch-up performance exceeds 200 mA
Direct interface with TTL levels
IOFF circuitry provides partial Power-down mode operation
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8B/JESD36 (2.7 V to 3.6 V)
ESD protection:
HBM ANSI/ESDA/JEDEC JS-001 Class 3B exceeds 8000 V
CDM ANSI/ESDA/JEDEC JS-002 Class C3 exceeds 2000 V
Multiple package options
Rev. 1.0 – Aug 08, 2024
1
74LVC1G97
3.Ordering Information
Table 1. Ordering information
Type number
Package
Name
74LVC1G97GV
SOT23-6L
74LVC1G97GW
SOT363
Description
SOT23 package, 6 pins
2.92 mm × 1.6 mm; 1.25 mm (Max) height
SOT363 package, 6 pins
2.1 mm × 1.25 mm; 1.1 mm (Max) height
Quantity
3000
3000
4.Function Diagram
Fig. 1. Logic symbol
2
74LVC1G97
5.Pinning Information
5.1. Pinning
Fig. 2. Top view pin configuration SOT23-6 and SOT363
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
B
1
Data input
GND
2
Ground (0V)
A
3
Data input
Y
4
Data output
VCC
5
Supply voltage
C
6
Data input
3
74LVC1G97
6.Functional Description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level.
Input
Output
C
B
A
Y
L
L
L
L
L
L
H
L
L
H
L
H
L
H
H
H
H
L
L
L
H
L
H
H
H
H
L
L
H
H
H
H
6.1. Logic configurations
Table 4. Function selection table
Logic function
Figure
2-input MUX
see Fig. 3
2-input AND
see Fig. 4
2-input OR with one input inverted
see Fig. 5
2-input NAND with one input inverted
see Fig. 5
2-input AND with one input inverted
see Fig. 6
2-input NOR with one input inverted
see Fig. 6
2-input OR
see Fig. 7
Inverter
see Fig. 8
Buffer
see Fig. 9
4
74LVC1G97
Fig. 3. 2-input MUX
Fig. 4. 2-input AND gate
Fig. 5. 2-input NAND gate with input A inverted or
2-input OR gate with input C inverted
Fig. 6. 2-input NOR gate with input B inverted or
2-input AND gate with input C inverted
Fig. 7. 2-input OR gate
Fig. 8. Inverter
Fig. 9. Buffer
5
74LVC1G97
7.Absolute Maximum Ratings
Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be
operable above the recommended operating conditions and stressing the parts to these levels is not
recommended. In addition, extended exposure to stresses above the recommended operating conditions may
affect device reliability. The absolute maximum ratings are stress ratings only.
Table 5. Absolute Maximum Ratings
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND.
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO
output voltage
IO
output current
ICC
supply current
IGND
ground current
Ptot
total power dissipation
Tstg
storage temperature
Conditions
VI < 0 V
Min
Max
Unit
-0.5
6.5
V
-50
[1]
-0.5
VO > VCC or VO < 0 V
mA
6.5
V
±50
mA
Active mode
[1]
-0.5
6.5
V
Power-down mode; VCC = 0 V
[1]
-0.5
6.5
V
±50
mA
100
mA
VO = 0 V to VCC
-100
Tamb = -40 °C to + 125 °C
-65
mA
250
mW
150
°C
[1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
8.Recommended Operating Conditions
The Recommended Operating Conditions table defines the conditions for actual device operation. Recommended
operating conditions are specified to ensure optimal performance to the datasheet specifications. MDD does not
recommend exceeding them or designing to Absolute Maximum Ratings.
Table 6. Recommended Operating Conditions
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Conditions
Min
Typ
Max
Unit
1.65
5.5
V
V
Active mode
VCC
V
Power-down mode; VCC = 0V
V
-40
125
°C
6
74LVC1G97
9.Static Characteristics
Table 7. Static characteristics
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
-40 °C to +85 °C
Min
Typ[1]
-40 °C to +125 °C
Max
Min
Max
Unit
VI = VT+ or VTIO = -100μA;
VCC = 1.65 V to 5.5 V
VOH
HIGH-level
output
voltage
VCC - 0.1
VCC - 0.1
V
IO = -4 mA; VCC = 1.65 V
1.2
0.95
V
IO = -8 mA; VCC = 2.3 V
1.9
1.7
V
IO = -12 mA; VCC = 2.7 V
2.2
1.9
V
IO = -24 mA; VCC = 3.0 V
2.3
2.0
V
IO = -32 mA; VCC = 4.5 V
3.8
3.4
V
VI = VT+ or VT-
VOL
II
IOFF
ICC
ΔICC
CI
LOW-level
output
voltage
Input
leakage
current
power-off
leakage
current
supply
current
additional
supply
current
input
capacitance
IO = 100μA;
0.10
0.10
V
IO = 4 mA; VCC = 1.65 V
0.45
0.70
V
IO = 8 mA; VCC = 2.3 V
0.30
0.45
V
IO = 12 mA; VCC = 2.7 V
0.40
0.60
V
IO = 24 mA; VCC = 3.0 V
0.55
0.80
V
IO = 32 mA; VCC = 4.5 V
0.55
0.80
V
VI = 5.5 V or GND ;
VCC = 0 V to 5.5 V
±0.1
±1
±1
μA
VCC = 0V ; VI or VO = 5.5 V
±0.1
±2
±2
μA
0.1
4
4
μA
per pin ; VCC = 2.3V to 5.5V ;
VI = VCC -0.6V ; IO = 0A
5
500
500
μA
VCC = 3.3V ; VI = GND to VCC
5
VI = 5.5V or GND ; IO = 0A ;
VCC = 5.5V
pF
[1]All typical values are measured at Tamb = 25℃.
7
74LVC1G97
10. Dynamic Characteristics
Table 8. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 11.
Symbol
Parameter
tpd
CPD
power
dissipation
capacitance
-40 °C to +125 °C
Unit
Min
Typ[1]
Max
Min
Max
VCC = 1.65 V to 1.95 V
4.0
15.7
26
4.0
26.5
ns
VCC = 2.3 V to 2.7 V
2.5
9.5
14
2.5
14.5
ns
VCC = 3.0 V to 3.6 V
2.0
7.1
9
2.0
9.5
ns
VCC = 4.5 V to 5.5 V
1.5
2.9
5
1.5
5.5
ns
A, B, C to Y; see Fig. 10
propagation
delay
-40 °C to +85 °C
Conditions
CL = 15 pF; f = 1 MHz;
VI = GND to VCC
[2]
[3]
25
pF
[1] Typical values are measured at norminal VCC and at Tamb = 25 °C.
[2] tpd is the same as tPLH and tPHL.
[3] CPD is used to determine the dynamic power dissipation (PD in μW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of outputs.
8
74LVC1G97
10.1. Waveforms and test circuit
Measurement points are given in Table 9.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 10. Input A, B and C to output Y propagation delays
Table 9. Measurement points
Supply Voltage
Input
Output
VCC
VM
VM
1.65 V to 1.95 V
0.5VCC
0.5VCC
2.3 V to 2.7 V
0.5VCC
0.5VCC
3.0 V to 3.6 V
1.5 V
1.5 V
4.5 V to 5.5 V
0.5VCC
0.5VCC
9
74LVC1G97
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 11. Test circuit for measuring switching times
Table 10. Test data
Supply voltage
Input
VCC
VI
tr = tf
CL
RL
tPLH, tPHL
1.65 V to 1.95 V
VCC
≤ 2.0 ns
30 pF
1 kΩ
open
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
3.0 V to 3.6 V
3V
≤ 2.5 ns
50 pF
500 Ω
open
4.5 V to 5.5 V
VCC
≤ 2.5 ns
50 pF
500 Ω
open
Load
VEXT
10
74LVC1G97
11. Transfer Characteristics
Table 11. Transfer characteristics
Symbol
Parameter
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Typ[1]
Max
Min
Max
VCC = 1.8 V
0.70
1.09
1.20
0.67
1.20
V
VCC = 2.3 V
1.11
1.36
1.60
1.08
1.60
V
VCC = 3.0 V
1.50
1.69
2.00
1.47
2.00
V
VCC = 4.5 V
2.16
2.39
2.74
2.13
2.74
V
VCC = 5.5 V
2.61
2.86
3.33
2.58
3.33
V
VCC = 1.8 V
0.30
0.6
0.72
0.30
0.75
V
VCC = 2.3 V
0.58
0.77
1.00
0.58
1.03
V
VCC = 3.0 V
0.80
1.09
1.30
0.80
1.33
V
VCC = 4.5 V
1.21
1.62
1.90
1.21
1.93
V
VCC = 5.5 V
1.45
1.99
2.29
1.45
2.32
V
VCC = 1.8 V
0.30
0.49
0.62
0.23
0.62
V
VCC = 2.3 V
0.40
0.58
0.80
0.34
0.80
V
VCC = 3.0 V
0.50
0.6
1.00
0.44
1.00
V
VCC = 4.5 V
0.71
0.76
1.20
0.65
1.20
V
VCC = 5.5 V
0.71
0.86
1.40
0.65
1.40
V
see Fig. 12, Fig. 13, Fig. 14
and Fig. 15
VT+
positivegoing
threshold
voltage
and Fig. 15
VT-
negativegoing
threshold
voltage
and Fig. 15
VH
hysteresis
voltage
11
74LVC1G97
11.1. Waveforms transfer characteristics
VT+ and VT- limits at 70% and 20%.
Fig. 12.
Fig. 13.
Definition of VT+, VT- and VH
Fig. 14. Transfer characteristic
Fig. 15. Definition of VT+, VT- and VH
12
74LVC1G97
12. Package Outline
SOT23-6L
13
74LVC1G97
SOT363
14
74LVC1G97
13. Abbreviations
Table 12. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
CDM
Charged Device Model
TTL
Transistor-Transistor Logic
14. Revision History
Table 13. Revision history
Document ID
Release Date
Data sheet status
74LVC1G97 Rev. 1.0
Jun 30, 2024
Product datasheet
Change notice
Supersedes
15
很抱歉,暂时无法提供与“74LVC1G97GV”相匹配的价格&库存,您可以联系我们找货
