74LVC1G14GV
74LVC1G14GV
    MDD(辰达半导体)
    SOT23-5L
    single inverter; Schmitt-trigger
74LVC1G14GV 数据手册
74LVC1G14 Single Schmitt trigger inverter Product datasheet, Rev1.0 Aug 08, 2024 1.General Description The 74LVC1G14 is a single inverter with Schmitt-trigger inputs. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these devices as translators in mixed 3.3 V and 5 V environments. This device is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. 2.Features and Benefits  Wide supply voltage range from 1.65 V to 5.5 V  Overvoltage tolerant inputs to 5.5 V  High noise immunity  ±24 mA output drive (VCC = 3.0 V)  CMOS low power dissipation  Latch-up performance exceeds 100 mA  Direct interface with TTL levels  IOFF circuitry provides partial Power-down mode operation  Unlimited rise and fall times  Complies with JEDEC standard: • JESD8-7 (1.65 V to 1.95 V) • JESD8-5 (2.3 V to 2.7 V) • JESD8C (2.7 V to 3.6 V) • JESD36 (4.5 V to 5.5 V)  ESD protection: • HBM ANSI/ESDA/JEDEC JS-001 Class 3B exceeds 8000 V • MM JESD22-A115C Class C exceeds 550 V • CDM ANSI/ESDA/JEDEC JS-002 Class C3 exceeds 2000 V  Multiple package options Rev. 1.0 – Aug 08, 2024 1 74LVC1G14 Single Schmitt trigger inverter 3.Ordering Information Table 1. Ordering information Package Type number Name Description Quantity 74LVC1G14GV SOT23-5L SOT23 package, 5 pins 2.92 mm × 1.6 mm; 1.25 mm (Max) height 3000 74LVC1G14GW SOT353 SOT353 package, 5 pins 2.1 mm × 1.25 mm; 1.1 mm (Max) height 3000 74LVC1G14GS DFN1x1-6L DFN1×1 package, 6 pins 1 mm × 1 mm; 0.42 mm (Max) height 3000 74LVC1G14GM DFN1x1.45-6L DFN1.45×1 package, 6 pins 1.45 mm × 1 mm; 0.6 mm (Max) height 3000 74LVC1G14GX DFN0.8x0.8-4L DFN0.8×0.8 package, 5pins 0.8 mm × 0.8 mm; 0.4 mm (Max) height 3000 4.Function Diagram Fig 1. Logic symbol Rev. 1.0 – Aug 08, 2024 Fig 2. IEC logic symbol Fig 3. Logic diagram 2 74LVC1G14 Single Schmitt trigger inverter 5.Pinning Information 5.1. Pin map Fig 4. Top view pin configuration SOT23-5 and SOT353 Fig 5. Top view pin configuration DFN6L Fig 6. Top view pin configuration DFN4L 5.2. Pin description Table 2. Pin description Symbol Pin Description SOT23-5, SOT353 and DFN4L DFN6L NC 1 1, 5 Not connected A 2 2 Data input GND 3 3 Ground (0V) Y 4 4 Data output VCC 5 6 Supply voltage Rev. 1.0 – Aug 08, 2024 3 74LVC1G14 Single Schmitt trigger inverter 6.Functional Description Table 3. Function table H = HIGH voltage level; L = LOW voltage level. Input Output A Y L H H L 7.Absolute Maximum Ratings Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be operable above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. Table 4. Absolute Maximum Ratings In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND. Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO output voltage IO output current ICC supply current IGND ground current Ptot total power dissipation Tstg storage temperature Conditions VI < 0 V Min Max Unit -0.5 6.5 V -50 [1] -0.5 6.5 V ±50 mA -0.5 VCC + 0.5 V -0.5 6.5 V ±50 mA 100 mA VO >VCC or VO < 0 V Active [1] Power-down [1] mode mode; VCC = 0 V mA VO = 0 V to VCC -100 Tamb = -40 °C to + 125 °C -65 mA 250 mW 150 °C [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. Rev. 1.0 – Aug 08, 2024 4 74LVC1G14 Single Schmitt trigger inverter 8.Recommended Operating Conditions The Recommended Operating Conditions table defines the conditions for actual device operation. Recommended operating conditions are specified to ensure optimal performance to the datasheet specifications. MDD does not recommend exceeding them or designing to Absolute Maximum Ratings. Table 5. Recommended Operating Conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature Rev. 1.0 – Aug 08, 2024 Conditions Min Typ Max Unit 1.65 5.5 V 0 5.5 V Active mode 0 VCC V Power-down mode; VCC = 0 V 0 5.5 V -40 125 °C 5 74LVC1G14 Single Schmitt trigger inverter 9.Static Characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions -40 °C to +85 °C Min Typ[1] -40 °C to +125 °C Max Min Max Unit VI = VT+ or VTIO = -100μA; VCC = 1.65 V to 5.5 V VOH HIGH-level output voltage VCC - 0.1 VCC - 0.1 V IO = -4 mA; VCC = 1.65 V 1.2 1.54 0.95 V IO = -8 mA; VCC = 2.3 V 1.9 2.15 1.7 V IO = -12 mA; VCC = 2.7 V 2.2 2.50 1.9 V IO = -24 mA; VCC = 3.0 V 2.3 2.62 2.0 V IO = -32 mA; VCC = 4.5 V 3.8 4.11 3.4 V VI = VT+ or VTIO = 100μA; VCC = 1.65 V to 5.5 V VOL LOW-level output voltage 0.10 0.10 V IO = 4 mA; VCC = 1.65 V 0.07 0.45 0.70 V IO = 8 mA; VCC = 2.3 V 0.12 0.30 0.45 V IO = 12 mA; VCC = 2.7 V 0.17 0.40 0.60 V IO = 24 mA; VCC = 3.0 V 0.33 0.55 0.80 V IO = 32 mA; VCC = 4.5 V 0.39 0.55 0.80 V II Input leakage current VI = 5.5 V or GND ; VCC = 5.5 V ±0.1 ±1 ±1 μA IOFF power-off leakage current VCC = 0V ; VI or VO = 5.5 V ±0.1 ±2 ±2 μA ICC supply current VI = 5.5V or GND ; IO = 0A ; VCC = 5.5V 0.1 4 4 μA ΔICC additional supply per pin ; VCC = 2.3V to 5.5V ; current VI = VCC -0.6V ; IO = 0A 5 500 500 μA CI input capacitance 5 VCC = 3.3V ; VI = GND to VCC pF [1]All typical values are measured at VCC = 3.3V and Tamb = 25℃. Rev. 1.0 – Aug 08, 2024 6 74LVC1G14 Single Schmitt trigger inverter 10. Dynamic Characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 7. Symbol Parameter CPD propagation delay power dissipation capacitance -40 °C to +125 °C Unit Min Typ[1] Max Min Max VCC = 1.65 V to 1.95 V 4.0 10.6 19.5 4.0 19.8 ns VCC = 2.3 V to 2.7 V 2.5 5.9 10.6 2.5 10.9 ns VCC = 3.0 V to 3.6 V 2.0 4.3 7 2.0 7.5 ns VCC = 4.5 V to 5.5 V 1.5 2.9 4.8 1.5 5.0 ns nA to nY; see Fig. 6 tpd -40 °C to +85 °C Conditions [2] per buffer ; VI = GND to VCC ; VCC = 3.3V [3] 24 pF [1] Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 3.3 V and 5.0 V respectively. [2] tpd is the same as tPLH and tPHL. [3] CPD is used to determine the dynamic power dissipation (PD in μW). PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; Σ(CL × VCC2 × fo) = sum of outputs. Rev. 1.0 – Aug 08, 2024 7 74LVC1G14 Single Schmitt trigger inverter 10.1. Waveforms and test circuit Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 7. The input nA to output nY propagation delays Table 8. Measurement points Supply voltage Input Output VCC VM VM 1.65 V to 1.95 V 0.5VCC 0.5VCC 2.3 V to 2.7 V 0.5VCC 0.5VCC 3.0 V to 3.6 V 1.5 V 1.5 V 4.5 V to 5.5 V 0.5VCC 0.5VCC Rev. 1.0 – Aug 08, 2024 8 74LVC1G14 Single Schmitt trigger inverter Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 8. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VCC VI tr = tf CL RL tPLH, tPHL 1.65 V to 1.95 V VCC ≤ 2.0 ns 30 pF 1 kΩ open 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 3.0 V to 3.6 V 3V ≤ 2.5 ns 50 pF 500 Ω open 4.5 V to 5.5 V VCC ≤ 2.5 ns 50 pF 500 Ω open Rev. 1.0 – Aug 08, 2024 Load VEXT 9 74LVC1G14 Single Schmitt trigger inverter 11. Transfer Characteristics Table 10. Transfer characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ[1] Max Min Max VCC = 1.8 V 0.82 1.0 1.14 0.79 1.14 V VCC = 2.3 V 1.03 1.2 1.40 1.00 1.40 V VCC = 3.0 V 1.29 1.5 1.71 1.26 1.71 V VCC = 4.5 V 1.84 2.2 2.36 1.81 2.36 V VCC = 5.5 V 2.19 2.6 2.79 2.16 2.79 V VCC = 1.8 V 0.46 0.6 0.75 0.46 0.78 V VCC = 2.3 V 0.65 0.7 0.96 0.65 0.99 V VCC = 3.0 V 0.88 1.0 1.24 0.88 1.27 V VCC = 4.5 V 1.32 1.6 1.84 1.32 1.87 V VCC = 5.5 V 1.58 1.9 2.24 1.58 2.27 V VCC = 1.8 V 0.26 0.5 0.62 0.19 0.62 V VCC = 2.3 V 0.28 0.5 0.65 0.22 0.65 V VCC = 3.0 V 0.31 0.6 0.7 0.25 0.7 V VCC = 4.5 V 0.40 0.6 0.77 0.34 0.77 V VCC = 5.5 V 0.47 0.6 0.88 0.41 0.88 V see Fig. 9 and Fig. 10 VT+ positive-going threshold voltage see Fig. 9 and Fig. 10 VT- negative-going threshold voltage see Fig. 9 and Fig. 10 VH hysteresis voltage [1] Typical values are measured at Tamb = 25 °C. Rev. 1.0 – Aug 08, 2024 10 74LVC1G14 Single Schmitt trigger inverter 11.1. Waveforms transfer characteristics VT+ and VT- limits at 70% and 20%. Fig 9. Transfer characteristic Rev. 1.0 – Aug 08, 2024 Fig 10. Definition of VT+, VT- and VH 11 74LVC1G14 Single Schmitt trigger inverter 12. Package Outline SOT23-5L Rev. 1.0 – Aug 08, 2024 12 74LVC1G14 Single Schmitt trigger inverter SOT353 Rev. 1.0 – Aug 08, 2024 13 74LVC1G14 Single Schmitt trigger inverter DFN1x1-6L Rev. 1.0 – Aug 08, 2024 14 74LVC1G14 Single Schmitt trigger inverter DFN1x1.45-6L Rev. 1.0 – Aug 08, 2024 15 74LVC1G14 Single Schmitt trigger inverter DFN0.8x0.8-4L Rev. 1.0 – Aug 08, 2024 16 74LVC1G14 Single Schmitt trigger inverter 15. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 16. Revision History Table 11. Revision history Document ID Release Date Data sheet status 74LVC1G14 Rev1.0 Oct 30, 2023 Product datasheet Rev. 1.0 – Aug 08, 2024 Change notice Supersedes 17
74LVC1G14GV 价格&库存
很抱歉,暂时无法提供与“74LVC1G14GV”相匹配的价格&库存,您可以联系我们找货
