5.0SMDJ78CA
5.0SMDJ78CA
    MDD(辰达半导体)
    SMC(DO-214AB)
    表面贴装瞬态电压抑制器,具备低泄漏、单双向可选、出色钳位能力和快速响应时间
5.0SMDJ78CA 数据手册
5.0SMDJ11(C)A THRU 5.0SMDJ440(C)A Stand-off Voltage - 11 to 440 Volts Peak Pulse Power: 5000 Watts SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Features DO-214AB/SMC  5000 W peak pulse power capability with a 10/1000 μs waveform 0.246(6.25) 0.220(5.60) 0.128 (3.25) 0.108 (2.75)  Low leakage  Uni and Bidirectional unit  Excellent clamping capability  Very fast response time 0.280(7.10) 0.256(6.50)  Meets MSL level 1 0.012(0.305) 0.006(0.152) 0.104(2.65) 0.077(2.00) Mechanical Data 0.063(1.60) 0.030(0.76) 0.010(0.25)MAX.  Package: DO-214AB (SMC) Molding compound meets UL 94 V-0 flammability rating, 0.321(8.15) 0.299(7.60) RoHS-compliant Dimensions in inches and (millimeters)  Terminals: Tin plated leads, solderable per J-STD-002 and JESD22-B102  Polarity: For uni-directional types the band denotes Marking Code cathode end, no marking on bi-directional types Cathode Band(for Uni-directional products only) MDD XXY Applications Trace Code Marking Y:Numeric code at the end of the year (A~K) XX: WeeK Code (NOTE:The weekly code is based on the actual number of weeks in the calendar year.) Marking Code XXX Use in sensitive electronics protection against voltage transients induced by inductive load switching and lighting on ICs, MOSFET, signal lines of sensor units for consumer, computer, industrial, telecommunication. MDD Logo Part Number Code 5.0SMDJ XXX C A Circuit Diagram 5% VBR Voltage Tolerance Bidirectional Unipolar Bipolar Voltage Series Code MAXIMUM RATINGS AND CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2 ) PPPM 5000 W 3.5/5.0 V Maximum Instantaneous Forward Voltage at 100A for Unidirectional only(Note4) VF Steady state power dissipation at TA=75℃(Note2 ) PD 6.5 W IFSM 300 A TJ,TSTG -55 to +150 ℃ RθJL 15 ℃/W RθJA 75 ℃/W Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (N ote3 ) Operating junction and Storage Temperature Range. Typical thermal resistance junction to lead(Note5) Typical thermal resistance junction to ambient(Note5) Notes: (1) (2) (3) (4) (5) Non-repetitive current pulse, per Fig. 3 and derated above TA= 25℃ per Fig.2. Mounted on 0.31 x 0.31" (8.0 x 8.0 mm) copper pads to each terminal Measured on 8.3ms single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum. VF=3.5V Max for devices of VBR≤85V,and VF=5.0V Max for devices of VBR>85V. Mounted on minimum recommended pad layout. http://www.microdiode.com Rev:2025A4 Page :1 5.0SMDJ11(C)A THRU 5.0SMDJ440(C)A Stand-off Voltage - 11 to 440 Volts Peak Pulse Power: 5000 Watts Electrical Characteristics (TA=25℃ unless otherwise noted) Working Peak Reverse Voltage VRWM (V) Maximum Reverse Surge (2) Current IPP (A) Maximum Clamping Voltage Vc @ IPP (V) Min(V) Max (V) IT (mA) Maximum Reverse Leakage IR @ VRWM (μA) 5.0SMDJ11CA 12.2 13.5 1.0 5.0 11.0 274.7 18.2 5.0SMDJ12A 5.0SMDJ12CA 13.3 14.7 1.0 5.0 12.0 251.3 19.9 5.0SMDJ13A 5.0SMDJ13CA 14.4 15.9 1.0 5.0 13.0 232.6 21.5 5.0SMDJ14A 5.0SMDJ14CA 15.6 17.2 1.0 5.0 14.0 215.5 23.2 5.0SMDJ15A 5.0SMDJ15CA 16.7 18.5 1.0 5.0 15.0 204.9 24.4 5.0SMDJ16A 5.0SMDJ16CA 17.8 19.7 1.0 5.0 16.0 192.3 26 5.0SMDJ17A 5.0SMDJ17CA 18.9 20.9 1.0 5.0 17.0 181.2 27.6 5.0SMDJ18A 5.0SMDJ18CA 20.0 22.1 1.0 5.0 18.0 171.2 29.2 5.0SMDJ19A 5.0SMDJ19CA 21.1 23.3 1.0 5.0 19.0 162.3 30.8 5.0SMDJ20A 5.0SMDJ20CA 22.2 24.5 1.0 5.0 20.0 154.3 32.4 5.0SMDJ22A 5.0SMDJ22CA 24.4 26.9 1.0 5.0 22.0 140.8 35.5 5.0SMDJ24A 5.0SMDJ24CA 26.7 29.5 1.0 5.0 24.0 128.5 38.9 5.0SMDJ26A 5.0SMDJ26CA 28.9 31.9 1.0 5.0 26.0 118.8 42.1 5.0SMDJ28A 5.0SMDJ28CA 31.1 34.4 1.0 5.0 28.0 110.1 45.4 5.0SMDJ30A 5.0SMDJ30CA 33.3 36.8 1.0 5.0 30.0 103.3 48.4 5.0SMDJ33A 5.0SMDJ33CA 36.7 40.6 1.0 5.0 33.0 93.8 53.3 5.0SMDJ36A 5.0SMDJ36CA 40.0 44.2 1.0 5.0 36.0 86.1 58.1 5.0SMDJ40A 5.0SMDJ40CA 44.4 49.1 1.0 5.0 40.0 77.5 64.5 5.0SMDJ43A 5.0SMDJ43CA 47.8 52.8 1.0 5.0 43.0 72.0 69.4 5.0SMDJ45A 5.0SMDJ45CA 50.0 55.3 1.0 5.0 45.0 68.8 72.7 5.0SMDJ48A 5.0SMDJ48CA 53.3 58.9 1.0 5.0 48.0 64.6 77.4 5.0SMDJ51A 5.0SMDJ51CA 56.7 62.7 1.0 5.0 51.0 60.7 82.4 5.0SMDJ54A 5.0SMDJ54CA 60.0 66.3 1.0 5.0 54.0 57.4 87.1 5.0SMDJ58A 5.0SMDJ58CA 64.4 71.2 1.0 5.0 58.0 53.4 93.6 5.0SMDJ60A 5.0SMDJ60CA 66.7 73.7 1.0 5.0 60.0 51.7 96.8 5.0SMDJ64A 5.0SMDJ64CA 71.1 78.6 1.0 5.0 64.0 48.5 103 5.0SMDJ70A 5.0SMDJ70CA 77.8 86.0 1.0 5.0 70.0 44.2 113 5.0SMDJ75A 5.0SMDJ75CA 83.3 92.1 1.0 5.0 75.0 41.3 121 5.0SMDJ78A 5.0SMDJ78CA 86.7 95.8 1.0 5.0 78.0 39.7 126 5.0SMDJ80A 5.0SMDJ80CA 88.96 97.6 1.0 5.0 80.0 38.6 129.6 5.0SMDJ85A 5.0SMDJ85CA 94.4 104.0 1.0 5.0 85.0 36.5 137 Part Number (Uni) Part Number (Bi) 5.0SMDJ11A Breakdown Voltage VBR@IT (1) 5.0SMDJ90A 5.0SMDJ90CA 100.0 111.0 1.0 5.0 90.0 34.2 146 5.0SMDJ100A 5.0SMDJ100CA 111.0 123.0 1.0 5.0 100.0 30.9 162 5.0SMDJ110A 5.0SMDJ110CA 122.0 135.0 1.0 5.0 110.0 28.2 177 5.0SMDJ120A 5.0SMDJ120CA 133.0 147.0 1.0 5.0 120.0 25.9 193 5.0SMDJ130A 5.0SMDJ130CA 144.0 159.0 1.0 5.0 130.0 23.9 209 5.0SMDJ140A 5.0SMDJ140CA 155.0 171.0 1.0 5.0 140.0 22.0 226.8 5.0SMDJ150A 5.0SMDJ150CA 167.0 185.0 1.0 5.0 150.0 20.6 243 5.0SMDJ160A 5.0SMDJ160CA 178.0 197.0 1.0 5.0 160.0 19.3 259 5.0SMDJ170A 5.0SMDJ170CA 189.0 209.0 1.0 5.0 170.0 18.2 275 http://www.microdiode.com Rev:2025A4 Page :2 5.0SMDJ11(C)A THRU 5.0SMDJ440(C)A Stand-off Voltage - 11 to 440 Volts Peak Pulse Power: 5000 Watts Electrical Characteristics (TA=25℃ unless otherwise noted) Working Peak Reverse Voltage VRWM (V) Maximum Reverse Surge (2) Current IPP (A) Maximum Clamping Voltage Vc @ IPP (V) Min(V) Max (V) IT (mA) Maximum Reverse Leakage IR @ VRWM (μA) 5.0SMDJ180CA 200.2 220.0 1.0 5.0 180.0 17.1 291.6 5.0SMDJ190A 5.0SMDJ190CA 211.0 232.0 1.0 5.0 190.0 16.2 307.8 5.0SMDJ200A 5.0SMDJ200CA 224.0 247.0 1.0 5.0 200.0 15.4 324 5.0SMDJ220A 5.0SMDJ220CA 246.0 272.0 1.0 5.0 220.0 14.0 356 5.0SMDJ250A 5.0SMDJ250CA 279.0 309.0 1.0 5.0 250.0 12.3 405 5.0SMDJ300A 5.0SMDJ300CA 335.0 371.0 1.0 5.0 300.0 10.3 486 5.0SMDJ350A 5.0SMDJ350CA 391.0 432.0 1.0 5.0 350.0 8.8 567 5.0SMDJ400A 5.0SMDJ400CA 447.0 494.0 1.0 5.0 400.0 7.7 648 5.0SMDJ440A 5.0SMDJ440CA 492.0 543.0 1.0 5.0 440.0 7.0 713 Part Number (Uni) Part Number (Bi) 5.0SMDJ180A http://www.microdiode.com Breakdown Voltage VBR@IT (1) Rev:2025A4 Page :3 5.0SMDJ11(C)A THRU 5.0SMDJ440(C)A Stand-off Voltage - 11 to 440 Volts Peak Pulse Power: 5000 Watts Characteristics(Typical) FIG1:Peak Pulse Power Rating Curve FIG2: Pulse Power or Current vs. Initial Junction Temperature 100 100 Non-Repetitive Pulse Waveform shown in Fige.3 TA=25℃ 75 P P P M (K W ) PPP or IPP(%) 10 1.0 50 25 0.1 0.31×0.31"(8.0×8.0mm) Copper Pad Areas 0.1μs 1μs 10μs 100μs 1.0ms 0 10ms 0 25 50 75 td(μs) 175 200 FIG4:Typical Transient Thermal Impedance TJ=25℃ Pulse Width(td) is defined as the Point where the Peak Current Decays to 50% of IPPM Peak Value IPPM 10 Rth(℃/W) Half Value - IPP 2 IPPM IPPM(%) 150 100 tr=10μs 100 125 TJ(℃) FIG3: Pulse Waveform 150 100 50 1 10/1000μs Waveform as Defined by R.E.A. td 0 0 1.0 2.0 3.0 4.0 0.1 0.001 0.01 t(ms) 0.1 1 10 100 1000 tp(s) FIG6:Steady State Power Dissipation FIG5: Maximum Non-Repetitive Surge Current 7 300 6 TJ=TJMax. 8.3ms Single Half Sine-Wave 250 PD(W) IFSM(A) 5 200 150 4 3 100 2 50 1 0 0 10 Number of Cycles 100 0 0 25 50 75 100 125 150 175 200 TL(℃) The curve above is for reference only. http://www.microdiode.com Rev:2025A4 Page :4 5.0SMDJ11(C)A THRU 5.0SMDJ440(C)A Stand-off Voltage - 11 to 440 Volts Peak Pulse Power: 5000 Watts Packing information unit:mm P0 P1 d Item Symbol Tolerance SMC Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width A B C d D D1 D2 E F P P0 P1 T W Reel width W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 6.15 8.41 2.42 1.50 330.00 50.00 13.00 1.75 7.50 8.00 4.00 2.00 0.25 16.00 16.50 E F B A W P D2 T D1 C W1 D Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (mm) SMC 13" 3,000 4.0 BOX (pcs) 6000 INNER BOX (mm) REEL DIA, (mm) 190*190*41 330 CARTON SIZE (mm) 365*365*340 CARTON (pcs) 42000 APPROX. GROSS WEIGHT (kg) 14.0 Suggested Pad Layout http://www.microdiode.com Symbol Unit (mm) A 4.3 0.170 B 0.160 C 4.1 7.9 0.311 D 3.8 0.150 E 12 0.472 Unit (inch) Rev:2025A4 Page :5
5.0SMDJ78CA 价格&库存
很抱歉,暂时无法提供与“5.0SMDJ78CA”相匹配的价格&库存,您可以联系我们找货
