MDD90N02G
MDD90N02G
    MDD(辰达半导体)
    PDFN8_6X5MM
    20V N通道增强模式MOSFET
MDD90N02G 数据手册
MDD90N02G 20V N-Channel Enhancement Mode MOSFET 1. Description This N-Channel MOSFET is produced using MDD Semiconductor's advanced Power Trench process technology. This process has been optimized to minimize on-state resistance and yet maintain superior switching performance with best in class soft body diode. 2. Features • Max RDS(on) = 3.6 mΩ at VGS = 4.5 V, ID =30 A • Extremely Low Reverse Recovery Charge, Qrr • 100% UIS Tested • 100% dVDS Tested 3. Application • Synchronous Rectification for ATX / Server / Telecom PSU • Motor Drives and Uninterruptible Power Supplies • DC-DC converters 4. Absolute Maximum Ratings(TA=25°C unless otherwise noted) Parameter Symbol Value Unit Drain-Source Voltage VDS 20 V Gate-Source Voltage VGS ±12 V ID 90 A Continuous Drain Current (Note 1) Pulsed Drain Current (Note 2) IDM 360 A Single Pulsed Avalanche Energy (Note 3) EAS 126.6 Thermal Resistance, steady-state RθJA 33 mJ °C/W TJ -55~+150 °C Tstg -55~+150 °C Junction Temperature Storage Temperature Note: 1)Calculated continuous current based on maximum allowable junction temperature. 2)Repetitive rating, pulse width limited by max. junction temperature. 3)EAS condition:TJ=25°C, VDD=20V, L= 0.5mH, Rg = 25Ω, ID=22.5A Rev: 2025A0 MDD90N02G 20V N-Channel Enhancement Mode MOSFET 5. Pinning information Pin Symbol Description 4 G Gate 5-8 D 1-3 S Simplified outline Equivalent Circuit Package MDD Drain 90N02G PDFN5*6-8L XXY: Date code Source 6. TA=25°C unless otherwise specified Symbol Marking Min Typ Max Unit VGS=0V, ID=250μA 20 — — V Parameter Condition V(BR)DSS Drain-Source Breakdown Voltage IGSS Gate-Source Leakage Current VGS=±12V — — ±100 nA IDSS Drain-Source Leakage Current VDS =20V, V GS =0V — — 1 μA Gate Threshold Voltage VDS=VGS, ID=250μA 0.45 — 0.95 V VGS=4.5V, I D =30A — 2.8 3.6 mΩ 3.9 4.9 mΩ VGS(TH) RDS(ON) Drain-Source On-State Resistance VGS=2.5V, I D= 20A 7. Dynamic Electrical Characteristics Symbol Parameter Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance Qg Total Gate Charge Qgs Gate Source Charge Qgd Gate Drain Charge VGS=0V VDS =10V f=1.0MHz VGS=0-8V VDS =10V ID=30A 8. Switching Characteristics Symbol td(on) tr td(off) tf Parameter Condition Turn on Delay Time VGS =10V VDD =10V ID=30A RG=3Ω Turn on Rise Time Turn Off Delay Time Turn Off Fall Time 9. Source Drain Diode Characteristics Symbol Condition Parameter — Min Typ Max Unit — 3845 — pF — — 551 484 — — pF pF — 65 — nC — 6 — nC — 16 — nC Min Typ Max Unit — — 8 ns 19 — — ns — 73 — ns — ns Typ Max Unit — Condition 80 Drain-Source Diode Forward Voltage IS=30A, VGS =0V — 0.8 1.2 V trr Body Diode Reverse Recovery Time — ns Body Diode Reverse Recovery Charge 16 — Qrr IF=20A — 5.6 — nC VSD Craftsman-Made Consciention Chip Rev: 2025A0 di/dt=100A/μs 2/5 www.microdiode.com MDD90N02G 20V N-Channel Enhancement Mode MOSFET 10.Electrical Characteristics Diagrams 150 20 VDS = 5V VGS = 4.5V VGS = 4.0V VGS = 2.5V 120 16 TJ = 125°C 90 TJ = -55°C ID(A) 12 ID(A) VGS = 1.8V TJ = 25°C 60 8 VGS = 1.5V 30 4 VGS = 1.3V 0 0 0 1 2 3 4 0 5 0.5 1 1.5 2 2.5 3 VGS(V) VDS(V) Figure 1. Typ. output characteristics Figure 2. Typ. transfer characteristics 5 8 VDD = 8V ID = 30A VGS = 2.5V 6 VGS(V) RDS(ON)(mΩ) 4 3 4 VGS =4.5V 2 1 2 0 10 20 30 40 0 50 0 10 20 30 ID(A) 40 50 60 70 Qg(nC) Figure 3. On-Resistance vs. Drain Current Figure 4. Gate Charge Characteristics 100 2.2 VGS = 0V 2 VGS = 4.5V ID = 30A 10 TJ = 125°C 1.6 IS(A) Normalized RDS(ON) 1.8 1.4 1.2 1 TJ = -55°C 1 TJ = 25°C 0.1 0.8 0.6 0.4 -80 -40 0 40 80 120 160 200 0.01 TJ(℃) Junction Temperature Figure 5. Normalized on Resistance vs. Junction Temperature Craftsman-Made Consciention Chip Rev: 2025A0 0 0.2 0.4 0.6 0.8 1 1.2 VSD(V) Figure 6. Forward characteristic of body diode 3/5 www.microdiode.com MDD90N02G 20V N-Channel Enhancement Mode MOSFET 11.Test Circuits And Waveforms Figure 1. Gate charge testcircuit & waveform Figure 2.Switching time testcircuit & waveforms Figure 3.Unclamped inductive switching (UIS)test circuit & waveforms Figure 4. Diode reverse recoverytest circuit& waveforms Craftsman-Made Consciention Chip Rev: 2025A0 4/5 www.microdiode.com MDD90N02G 20V N-Channel Enhancement Mode MOSFET 12. Outline Drawing PDFN5*6-8L Package Outline Dimensions 13. Important Notice and Disclaimer Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen). Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Shenzhen). Craftsman-Made Consciention Chip Rev: 2025A0 5/5 www.microdiode.com
MDD90N02G 价格&库存
很抱歉,暂时无法提供与“MDD90N02G”相匹配的价格&库存,您可以联系我们找货
