1N4148WT-E
1N4148WT-E
    MDD(辰达半导体)
    SOD-523
    SOD-523塑料封装开关二极管
1N4148WT-E 数据手册
1N4148WT-E Reverse Voltage 100 Volts Forward Current - 0.15 Ampere 1. Description FAST SWITCHING DIODES 2. Features • Small Package • Low Reverse Current • Fast Switching Speed • Surface Mount Package Ideally Suited for Automatic Insertion 3. Application • High frequency rectifier • Signal switching 4. Mechanical Data • Case : SOD-523 Molded Plastic • Polarity : Polarity symbols marked on case • Marking: T4 5. Absolute Maximum Ratings(TA=25°C unless otherwise noted) Parameter Maximum repetitive peak reverse voltage RMS Reverse Voltage Reverse Breakdown voltage at IR=1 μA Forward continuous current Average rectified output current Non-repetitive Peak Forward Surge Current@t=8.3m s Power Dissipation Thermal resistance junction to ambient Junction Temperature Storage Temperature Rev:2025A0 Symbol Value Unit VRRM 100 V VR(RMS) 53 V V(BR)R 75 V IFM 300 mA IO 150 mA IFSM PD RθJA TJ Tstg 2 A 150 mW 833 °C/W 125 °C -55~+125 °C 1N4148WT-E Reverse Voltage 100 Volts Forward Current - 0.15 Ampere 6. Pinning information Pin Symbol Description 1 - Cathode 2 + Anode Simplified outline (1) T4 Equivalent Circuit (2) Marking Package T4 SOD-523 (2)Anode (1)Cathode 7. Characteristics(TA=25°C unless otherwise noted) Parameter Forward voltage Reverse current Capacitance between terminals Reverse recovery time Craftsman-Made Consciention Chip Rev:2025A0 Condition Symbols Min Typ Max Unit VF1 IF=1.0mA — — 0.715 V VF2 IF=10mA — — 0.855 V VF3 IF=50mA — — 1.0 V VF4 IF=150mA — — 1.25 V IR1 VR=20V — — 0.025 μA IR2 VR=75V — — μA VR=0V , f=1.0MHz 1 — — 2 pF — — 4 ns Ctot trr IF=IR=10mA Irr=0.1 ×IR , RL=100Ω 2/5 www.microdiode.com 1N4148WT-E Reverse Voltage 100 Volts Forward Current - 0.15 Ampere 8.Typical Characterisitics 1000 200 100 (nA) (mA) Ta=100℃ REVERSE CURRENT IR 1 T= a 2 5℃ FORWARD CURRENT IF T= a 1 00 ℃ 10 0.1 0.01 0.0 0.2 0.4 0.6 FORWARD VOLTAGE 0.8 VF 1.0 100 1 1.2 Ta=25℃ 10 0 REVERSE VOLTAGE Figure 1. Forward Characteristics 60 40 20 (V) VR 80 (V) Figure 2. Reverse Characteristics 1.2 200 Ta=25℃ (mW) 150 PD 1.1 POWER DISSIPATION CAPACITANCE BETWEEN TERMINALS CT (pF) f=1MHz 1.0 0.9 0.8 0 5 15 10 REVERSE VOLTAGE VR 100 50 0 20 (V) 0 25 50 75 AMBIENT TEMPERATURE Figure 3. Capacitance Characteristics 100 Ta 125 150 (℃) Figure 4. Power Derating Curve The curve above is for reference only. Craftsman-Made Consciention Chip Rev:2025A0 3/5 www.microdiode.com 1N4148WT-E Reverse Voltage 100 Volts Forward Current - 0.15 Ampere 9. Outline Drawing SOD-523 Package Outline Dimensions 6\P RO A A1 b c D E E1 E2 L Κ LPHQVLRQV,Q0LOOLPHWHUV 0LQ 0D[ 0.510 0.770 0.500 0.770 0.250 0.400 0.080 0.150 0.750 1.000 1.100 1.300 1.500 1.700 0.250 0.150 0.000 0.070 0° 8° LPHQVLRQV,Q,QFKHV 0D[ 0LQ 0.020 0.031 0.020 0.031 0.010 0.016 0.003 0.006 0.030 0.040 0.043 0.051 0.059 0.067 0.006 0.010 0.000 0.003 0° 8° 10. Suggested Pad Layout Note: 1.Controlling dimension:in/millimeters. 2.General tolerance: ±0.05mm. 3.The pad layout is for reference purposes only. 11.PACKAGE SPECIFICATIONS Package Reel Size Reel DIA. (mm) Q'TY/Reel (pcs) Box Size QTY/Box Carton Size Q'TY/Carton (mm) (pcs) (mm) (pcs) SOD-523 7' 178 3000 183×188×80 45,000 386×265×215 180,000 Craftsman-Made Consciention Chip Rev:2025A0 4/5 www.microdiode.com 1N4148WT-E Reverse Voltage 100 Volts Forward Current - 0.15 Amper 12.Important Notice and Disclaimer Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights or Microdiode Electronics (Shenzhen). Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Shenzhen). Craftsman-Made Consciention Chip Rev:2025A0 5/5 www.microdiode.com
1N4148WT-E 价格&库存
很抱歉,暂时无法提供与“1N4148WT-E”相匹配的价格&库存,您可以联系我们找货
