74LVC1G3157GV
74LVC1G3157GV
    MDD(辰达半导体)
    SOT23-6L
    Low Voltage and High Speed SPDT Analog Switch with True Isolation
74LVC1G3157GV 数据手册
74LVC1G3157 Low Voltage and High Speed SPDT Analog Switch with True Isolation Product datasheet, Rev. 1.0 Aug 08, 2024 1.General Description The 74LVC1G3157G is a single SPDT low on-resistance analog switch. It can operate from 1.5V to 5.5V power supply. The device offers low ON-state resistance and excellent ON-state resistance matching with break-before-make feature, to prevent signal distortion during the transferring of a signal from one channel to another. The device is capable of truly isolation. Even when A overrides VCC, very little current will flow back to the supply. 2.Features and Benefits  Wide Supply Range from 1.5 V to 5.5 V  Low ON-state resistance, typically 1.9 Ω (VCC=5.5 V)  1.8 V Compatible Control Logic Inputs  High Off-Isolation: -80 dB @ 10 kHz  Low Channel-to-Channel Crosstalk: -82 dB @ 10 kHz  High Bandwidth: -3dB @ 800MHz  Low Quiescent Current (< 1uA) when VCC = 3.3 V 3.Applications  Audio, Video, UART, USB2.0 Signal and Supply Routing  Cell phones and TWS headset Rev. 1.0 – Aug 08, 2024 1 74LVC1G3157 Low Voltage and High Speed SPDT Analog Switch with True Isolation 4.Ordering Information Table 1. Ordering information Type number Package Name Description Quantity 74LVC1G3157GW SOT363 SOT363 package, 6 pins 2.1 mm × 1.25 mm; 1.1 mm (Max) height 3000 74LVC1G3157GV SOT23-6L SOT23 package, 6pins 2.92 mm × 1.6 mm; 1.25 mm (Max) height 3000 5.Pinning Information 5.1. Pin map Fig 1. Top view pin configuration SOT363 and SOT23-6L 5.2. Pin description Table 2. Pin description Symbol Pin Description B1 1 Analog/Digital Signal Port (Normally open) Rev. 1.0 – Aug 08, 2024 2 74LVC1G3157 Low Voltage and High Speed SPDT Analog Switch with True Isolation GND 2 Ground (0V) B0 3 Analog/Digital Signal Port (Normally closed) A 4 Common Signal Port VCC 5 Supply voltage SEL 6 Logic Input Control Rev. 1.0 – Aug 08, 2024 3 74LVC1G3157 Low Voltage and High Speed SPDT Analog Switch with True Isolation 6.Functional Description Table 3. Function table H = HIGH voltage level; L = LOW voltage level. Input SEL Channel on L B0 H B1 7.Absolute Maximum Ratings Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be operable above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. Table 4. Absolute Maximum Ratings In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND. Symbol Parameter VCC Min Max Unit supply voltage -0.3 6.5 V VSEL control Input Voltage -0.3 6.5 V VA signal input voltage -0.3 6.5 V continuous Current Through A, B0, B1 ±100 mA Imax peak Current Through A, B0, B1 (pulsed at 1ms 50% duty cycle) ±200 mA TJ junction Temperature under Bias 150 °C TL lead Temperature (Soldering, 10 seconds) 260 °C RθJA thermal resistance 350 Rev. 1.0 – Aug 08, 2024 Conditions o C/W 4 74LVC1G3157 Low Voltage and High Speed SPDT Analog Switch with True Isolation 8.Recommended Operating Conditions The Recommended Operating Conditions table defines the conditions for actual device operation. Recommended operating conditions are specified to ensure optimal performance to the datasheet specifications. Please do not exceed them or design to Absolute Maximum Ratings. Table 5. Recommended Operating Conditions Symbol Parameter VCC supply voltage VSEL Min Max Unit 1.5 5.5 V control input voltage 0 5.5 V VA signal input voltage 0 VCC V Tamb ambient temperature -40 125 °C Rev. 1.0 – Aug 08, 2024 Conditions 5 74LVC1G3157 Low Voltage and High Speed SPDT Analog Switch with True Isolation 9.Electrical Characteristics Table 6. Static characteristics Tamb=25 ℃, VCC=3.3 V, unless otherwise specified Symbol Parameter Conditions Min Typ Max Unit VCC = 3.4 V to 5.5 V 1.6 V VCC = 1.5 V to 3.3 V 1.4 V DC Electrical Characteristics VIH input logic high level VIL input logic low level ICC VCC = 3.4 V to 5.5 V 0.6 V VCC = 1.5 V to 3.3 V 0.4 V supply current IA = 0, VSEL = 0 or VSEL = VCC 1.0 μA ΔICC additional supply current IA = 0, VCC = 2.5 V or 4.2 V VSEL = 1.6 V 3.0 μA Ioff OFF-state switch leakage current from A to B0 (or B1) VA = 5 V , VB0 or VB1 = 0 V ±2.0 μA RON RFLAT ΔRON on-resistance on-resistance flatness on-resistance matching between channels Rev. 1.0 – Aug 08, 2024 VCC = 3.5 V , VA = 0.8 V to 2.0 V, IA = 10 mA 3.4 4.0 Ω VCC = 4.5 V , VA = 0.8 V to 2.3 V, IA = 10 mA 2.4 3.0 Ω VCC = 5.5 V , VA = 0.8 V to 2.6 V, IA = 10 mA 1.9 2.5 Ω VCC = 3.5 V , VA = 0.8 V to 2.0 V, IA = 10 mA 0.2 0.4 Ω VCC = 4.5 V , VA = 0.8 V to 2.3 V, IA = 10 mA 0.25 0.45 Ω VCC = 5.5 V , VA = 0.8 V to 2.6 V, IA = 10 mA 0.3 0.5 Ω VCC = 3.5 V , VA = 0.8 V to 2.0 V, IA = 10 mA 0.1 0.2 Ω VCC = 4.5 V , VA = 0.8 V to 2.3 V, IA = 10 mA 0.1 0.2 Ω VCC = 5.5 V , VA = 0.8 V to 2.6 V, IA = 10 mA 0.1 0.2 Ω 6 74LVC1G3157 Low Voltage and High Speed SPDT Analog Switch with True Isolation Symbol Parameter Conditions Min Typ Max Unit AC Electronics Characteristics tON turn-On Time VA=1.5V, CL=50pF, RL=50Ω 470 ns tOFF turn-Off Time VA=1.5V, CL=50pF, RL=50Ω 120 ns tBBM break-before-make time VA=1.5V, CL=50pF, RL=50Ω 600 ns BW -3dB Bandwidth CL=0pF 800 MHz OIRR off isolation f=10 KHz -80 dB f=240 MHz -31 dB XTALK crosstalk f=10 KHz -82 dB f=240 MHz -26 dB THD total harmonic distortion f=20Hz to 20KHz VA=600mVpp, RL=32Ω -80 dB Capacitance CON On Capacitance f=100KHz 12 pF COFF Off Capacitance f=100KHz 4 pF Rev. 1.0 – Aug 08, 2024 7 74LVC1G3157 Low Voltage and High Speed SPDT Analog Switch with True Isolation 10. Package Outline SOT363 Rev. 1.0 – Aug 08, 2024 8 74LVC1G3157 Low Voltage and High Speed SPDT Analog Switch with True Isolation SOT23-6L Rev. 1.0 – Aug 08, 2024 9 74LVC1G3157 Low Voltage and High Speed SPDT Analog Switch with True Isolation 11. Revision History Table 7. Revision history Document ID Release Date Data sheet status 74LVC1G3157 Rev.1.0 Oct 30, 2023 Product datasheet Rev. 1.0 – Aug 08, 2024 Change notice Supersedes 10
74LVC1G3157GV 价格&库存
很抱歉,暂时无法提供与“74LVC1G3157GV”相匹配的价格&库存,您可以联系我们找货
