RB751V-40
SOD-323 Plastic-Encapulate Diodes
SOD-323
SCHOTTKY BARRIER DIODES
FEATURES
Guard ring protection
Low forward voltage drop
For use in low voltage, high frequency inverters
Cathode bar
0.016(0.40)
0.057(1.45)
0.007(0.20)
0.043(1.10)
0.008(0.20)max.
RB751V-40
0.070(1.80)
Marking
0.063 (1.40)
0.110 (2.80)
Case : SOD-323
Terminals : Solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.00019 ounce, 0.00548 grams
0.024 (0.60)
0.014 (0.35)
0.0019 (0.05)
0.0079 (0.20)
0.006 (0.15)
0° to
Mechanical Data
9°
0.016 (0.45)
0.008 (0.2 )
0.043 (1.10)
5
0.032 (0.80)
0.098 (2.50)
Dimensions in inches and (millimeters)
Maximum Ratings and Electrical Characteristics, Single Diode @Ta=25℃
Symbo
Limit
Unit
Peak Reverse Voltage
VRM
40
V
DC Blocking Voltage
VR
30
V
Average Rectified Output Current
IO
30
mA
Non-Repetitive Peak Forward Surge Current @ t=8.3ms
IFSM
0.2
A
Power Dissipation
Pd
200
mW
RθJA
635
℃/W
Junction Temperature
Tj
125
Storage Temperature
TSTG
-55~+150
Parameter
Thermal Resistance Junction to Ambient
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Min
Typ
Max
Unit
Conditions
Forward voltage
VF
0.37
V
IF=1.0mA
Reverse current
IR
0.5
μA
VR=30V
Capacitance between terminals
CT
pF
VR=10V, f=1MHZ
6.0
The above data are for reference only.
http://www.microdiode.com
Rev:2024A3
Page :1
RB751V-40
Typical Characterisitics
The curve above is for reference only.
Rev:2024A3
Page :2
RB751V-40
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SOD-323
E
F
B
A
W
P
D2
T
D1
C
W1
D
1.46
2.90
1.25
1.50
330.00
50.00
178.00
54.40
13.00
1.75
3.50
4.00
4.00
2.00
0.06
8.00
12.30
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SOD-323
REEL SIZE
7"
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
3,000
4.0
45,000
210*208*203
178
CARTON
SIZE
(m/m)
430*430*235
CARTON
(pcs)
APPROX.
GROSS WEIGHT
(kg)
180,000
9.0
Suggested Pad Layout
Symbol
A
Unit (mm)
Unit (inch)
0.047
B
1.2
1.2
C
2.6
0.102
D
1.4
0.055
E
3.8
0.149
0.047
Rev:2024A3
Page :3
很抱歉,暂时无法提供与“RB751V-40”相匹配的价格&库存,您可以联系我们找货
