P0300DM
P0300DM
    MDD(辰达半导体)
    SMF(SOD-123FL)
    用于保护基带设备免受浪涌过电压影响的晶闸管浪涌抑制器
P0300DM 数据手册
P0300DM THYRISTOR SURGE SUPPRESSORS Description SOD-123FL Thyristors are a type of semi—conduct component. They are designed to protect baseband equipment 0.079(2.00) 0.063(1.60) 0.046 (1.20) from damaging overvoltage transients. 0.031 (0.80) 0.118(3.00) 0.098(2.50) Features • • • • • • 0.052(1.35) 0.035(0.90) Excellent capability of absorbing transient surge. Quick response to surge voltage (ns Level). Eliminates overvoltage caused by fast rising transients. Moisture sensitivity level: Level 1. IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact). Non degenerative. 0.012(0.30) 0.002(0.05) 0.039( . 0.012(0.30) 0.158(4.00) 0.134(3.45)   Dimensions in inches and (millimeters) Absolute Maximum Ratings (Ta = 25 °C Unless Otherwise Noted) Parameter Symbol Unit Value Operating junction temperature range TJ -40 to +125 °C Storage temperature range TSTG -40 to +125 °C IPP 35 A RθJA 180 °C/W Repetitive peak pulse current@10/1000μs Typical Thermal Resistance Electrical Characteristics (Ta=25℃) Symbol Parameter VDRM Peak off-state voltage IDRM Off-state current VS Switching voltage IS Switching current VT On-state voltage IT On-state current IH Holding current CO Off-state capacitance http://www.microdiode.com V‐I Curve  +I IT IS IH IDRM +V -V VT VDRM VS -I Rev:2024A3 Page :1 P0300DM Electrical Characteristics (Ta=25℃) IDRM@VDRM Parameter P0300DM VS(1)@IS VT@ IT IH CO(2) μA V V mA V A mA pF max min max max max max Typ max 1 25 40 800 4 2.2 50 40 Marking P03DA · Note:(1)Vs is measured at 100KV/s (2)Off-state capacitance is measured in VDC=2V, VRMS=1V, f=1MHz Surge Ratings Type IEC61000-4-5 Wave Sharp Voltage VPP 10/700μs 3000V Soldering Parameters Pb-Free assembly (see fig2) Reflow Condition Pre Heat -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquidus Temp (TL)to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL) (Liquidus) +217℃ -Temperature(tL) 60-150 secs Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ http://www.microdiode.com Rev:2024A3 Page :2 P0300DM Typical Characterisitics fig1 tr × td pulse waveform fig2 Reflow condition %IPP tp tr = rise time to peak value td = decay time to half value 100 TP Critical Zone TL to TP Ramp-up Peak value TL tL Temperature TS(max) Half value 50 0 0 tr td t(μs) Preheat TS(min) ts 25 to temperatue (t 25℃ to peak) fig3 Normalized Vs change vs. junction temperature fig4 Normalized DC holding current vs. case temperature Percent of Vs change(%) 2.0 12 IH(Tj )/IH(Tj =25℃ ) 1.8 1.6 8 1.4 4 1.2 25℃ 25℃ 1.0 0 0.8 -4 -8 -40 Time -20 0 20 T j (℃ ) 40 60 0.6 80 100 120 140 0.4 -40 -20 0 20 T C(℃ ) 40 60 80 100 120 140 The curve above is for reference only. http://www.microdiode.com Rev:2024A3 Page :3 P0300DM Packing information unit:mm P0 P1 d Item Symbol Tolerance SOD-123FL A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 2.1 4.0 1.60 1.55 178.00 50.0 13.00 1.75 3.50 4.00 4.00 2.00 E F B A Carrier width Carrier length Carrier depth Sprocket hole 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width W P D2 T D1 C W1 D 0.25 8.15 10.5 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) CARTON SIZE (m/m) CARTON (pcs) SOD-123FL 7" 3,000 4.0 45,000 190*190*190 178 400*400*220 180,000 APPROX. GROSS WEIGHT (kg) 9.0 Suggested Pad Layout Unit (inch) Symbol Unit (mm) A 1.2 0.047 C 1.2 3.2 0.047 0.126 D 2 0.079 E 4.4 0.173 B Important Notice and Disclaimer Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights or Microdiode Electronics (Shenzhen). Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Shenzhen). http://www.microdiode.com Rev:2024A3 Page :4
P0300DM 价格&库存
很抱歉,暂时无法提供与“P0300DM”相匹配的价格&库存,您可以联系我们找货
