SD07T
SD07T
    MDD(辰达半导体)
    SOD-323
    单线路单向瞬态电压抑制器,用于ESD、EFT和雷电保护,采用固态硅雪崩技术,低钳位电压和低漏电流
SD07T 数据手册
SD07T Single Line Uni-directional Transient Voltage Suppressor SOD-323 Plastic-Encapsulate ESD Protection Diodes DESCRIPTION The SD07T TVS diode is designed to replace multilayer varistors (MLVs) in portable applications such as cell phones, notebooks, and PDA's. It offers superior electrical characteristics such as low clamping voltage, low leakage current and high surge capability. It is designed to protect sensitive electronic components which are connected to power lines, from over-stress caused by ESD (Electrostatic Discharge), EFT (Electrical Fast Transients) and Lighting. The SD07T is in a SOD-323 package and will protect one unidirectional line. It may be used to provide ESD protection up to ±30kV (Contact and air discharge) according to IEC61000-4-2 , and used to protect USB voltage bus pin (8/20 us) according to IEC61000-4-5. Features        Peak power dissipation: 2625W (8/20μs) Transient protection for high-speed data lines IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact) Low clamping voltage Low leakage current Working voltages : 7V Solid-state silicon-avalanche technology Applications        Pin Configuration Power lines Personal digital assistants (PDA's) Microprocessors based equipment Notebooks, Desktops, and Servers Cell phone Handsets and Accessories Portable Electronics Peripherals Circuit Diagram 1 2 Mechanical Characteristics      Device: SD07T Package: SOD-323 Marking: H7 Material: Halogen free and RoHS compliant Flammability Rating: UL 94V-0 http://www.microdiode.com  High temperature soldering guaranted: 260℃/ 10s  Packaging: Tape and Reel  Reel size: 7 inch  Quantity per reel: 3,000pcs Rev:2024A2 Page :1 SD07T Single Line Uni-directional Transient Voltage Suppressor Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit VESD ± 30 ± 30 KV Peak Pulse Power(tp=8/20us waveform) PPP 2625 W Operating Temperature TOPT −55 to +125 °C Storage Temperature TSTG −55 to +150 °C TL 260(10 sec.) °C ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) Lead Solder Temperature – Maximum (10 Second Duration) Electrical Characteristics (TA=25°C unless otherwise specified) Symbol bol Parameter VRWM Reverse Working Voltage VBR Reverse Breakdown Voltage IT = 1mA IR Reverse Leakage Current IPP Peak Pulse Current VC Clamping Voltage CJ Junction Capacitance Test Condition Min Max Units 7.0 V 9.0 V VRWM = 7V 1 uA tp = 8/20μs 105 A 7.5 Typ 8.0 IPP = 70A, tp = 8/20μs 17 19 V IPP = 105A, tp = 8/20μs 20 25 V 600 700 pF VR = 0V, f = 1MHz The above data are for reference only. http://www.microdiode.com Rev:2024A2 Page :2 SD07T Single Line Uni-directional Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS CURVE The curve above is for reference only. http://www.microdiode.com Rev:2024A2 Page :3 SD07T Single Line Uni-directional Transient Voltage Suppressor Outlitne Drawing SOD-323 Package Outline Dimensions Suggested Pad Layout Note: 1.Controlling dimension:in/millimeters. 2.General tolerance: ±0.05mm. 3.The pad layout is for reference purposes only. PACKAGE SPECIFICATIONS Package Reel Size SOD-323 Reel DIA. (mm) Q'TY/Reel (pcs) Box Size (mm) QTY/Box (pcs) Carton Size (mm) Q'TY/Carton (pcs) 178 3000 183×188×80 45,000 386×265×215 180,000 7' http://www.microdiode.com Rev:2024A2 Page :4
SD07T 价格&库存
很抱歉,暂时无法提供与“SD07T”相匹配的价格&库存,您可以联系我们找货
