SD4V5TC
Single Line Bi-directional Transient Voltage Suppressor
SOD-323 Plastic-Encapsulate ESD Protection Diodes
DESCRIPTION
The SD4V5TC TVS diode is designed to replace multilayer varistors (MLVs) in portable
applications such as cell phones, notebooks, and PDA's. It offers superior electrical characteristics
such as low clamping voltage, low leakage current and high surge capability. It is designed to
protect sensitive electronic components which are connected to power lines, from over-stress
caused by ESD (Electrostatic Discharge), EFT (Electrical Fast Transients) and Lighting.
The SD4V5TC is in a SOD-323 package and will protect one unidirectional line. It may be
used to provide ESD protection up to ±30kV (Contact and air discharge) according to
IEC61000-4-2 ,and withstand peak pulse current up to 160A (8/20μs) according to IEC61000-4-5.
Features
Peak power dissipation: 3200W (8/20μs)
Transient protection for high-speed data lines
IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact)
Low clamping voltage
Low leakage current
Working voltages : 4.5V
Solid-state silicon-avalanche technology
Applications
Pin Configuration
Circuit Diagram
Power lines
Personal digital assistants (PDA's)
Microprocessors based equipment
Notebooks, Desktops, and Servers
Cell phone Handsets and Accessories
Portable Electronics
Peripherals
Mechanical Characteristics
Device: SD4V5TC
Package: SOD-323
Marking: D4
Material: Halogen free and RoHS compliant
Flammability Rating: UL 94V-0
http://www.microdiode.com
High temperature soldering guaranted:
260℃/ 10s
Packaging: Tape and Reel
Reel size: 7 inch
Quantity per reel: 3,000pcs
Rev:2024A2
Page :1
SD4V5TC
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
VESD
± 30
± 30
KV
Peak Pulse Power(tp=8/20us waveform)
PPP
3200
W
Operating Temperature
TOPT
−55 to +125
°C
Storage Temperature
TSTG
−55 to +150
°C
TL
260(10 sec.)
°C
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
Lead Solder Temperature – Maximum (10 Second
Duration)
Electrical Characteristics (TA=25°C unless otherwise specified)
Symbol
bol
Param
VRWM
Reverse Working Voltage
VBR
Reverse Breakdown Voltage
IR
Reverse Leakage Current
IPP
VC
CJ
Peak Pulse Current
Clamping Voltage
Junction Capacitance
Test Condition
Max
Units
4.5
V
6.4
V
VRWM = 4.5V
1
uA
tp = 8/20μs
160
A
IT = 1mA
Min
4.6
Typ
5.2
IPP =50A, tp = 8/20μs
8.5
11
V
IPP = 100A, tp = 8/20μs
12
14
V
IPP = 160A, tp = 8/20μs
17
V
300
500
pF
VR = 0V, f = 1MHz
The above data are for reference only.
Rev:2024A2
Page :2
SD4V5TC
ELECTRICAL CHARACTERISTICS CURVE
The curve above is for reference only.
Rev:2024A2
Page :3
SD4V5TC
Outlitne Drawing
SOD-323 Package Outline Dimensions
Suggested Pad Layout
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
PACKAGE SPECIFICATIONS
Package Reel Size
SOD-323
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
178
3000
183×188×80
45,000
386×265×215
180,000
7'
Rev:2024A2
Page :4
很抱歉,暂时无法提供与“SD4V5TC”相匹配的价格&库存,您可以联系我们找货
