MDDG04R06Q
40V N-Channel Enhancement Mode MOSFET
1. Description
This N-Channel MOSFET is produced using MDD Semiconductor's advanced Power Trench process that
incorporates Shielded Gate technology. This process has been optimized to minimize on-state resistance and yet
maintain superior switching performance with best in class soft body diode.
2. Features
• Max RDS(on) = 5.5 mΩ at VGS = 10 V, ID = 20A
• 100% UIS Tested
• 100% dVDS Tested
3. Application
• Synchronous Rectification for ATX / Server / Telecom PSU
• Motor Drives and Uninterruptible Power Supplies
• Micro Solar Inverter
• DC to DC converters
4. Absolute Maximum Ratings(TA=25°C unless otherwise noted)
Symbol
Value
Unit
Drain-Source Voltage
VDS
40
V
Gate-Source Voltage
VGS
±20
V
Parameter
Continuous Drain Current (Note 1)
ID
60
A
Pulsed Drain Current (Note 2)
IDM
240
A
Single Pulsed Avalanche Energy (Note 3)
EAS
26
mJ
Thermal Resistance, steady-state
RθJA
45
°C/W
PD
40
W
TJ
-55~+150
°C
Tstg
-55~+150
°C
Power Dissipation
Junction Temperature
Storage Temperature
Note:
1)Calculated continuous current based on maximum allowable junction temperature.
2)Repetitive rating, pulse width limited by max. junction temperature.
3)EAS condition:TJ=25°C, VDD=20V, VGS=10V, L= 0.1mH, Rg= 25Ω, ID=23A
Rev: 2025A1
MDDG04R06Q
5. Pinning information
Pin
Symbol
Description
4
G
Gate
5-8
D
Drain
1-3
S
Simplified outline
Equivalent Circuit
6. TA=25°C unless otherwise specified
Parameter
V(BR)DSS
Drain-Source Breakdown Voltage
IGSS
Gate-Source Leakage Current
Package
MDD
G04R06Q
Source
Symbol
Marking
Condition
Min
PDFN3*3-8L
Typ
Max
40
Forward
VGS=20V
100
nA
Reverse
VGS=-20V
-100
nA
1
μA
V
Drain-Source Leakage Current
VDS =40V, V GS=0V
VGS(TH)
Gate Threshold Voltage
VDS=VGS, I D=250μA
1.0
1.35
2.5
V
RDS(ON)
Drain-Source On-State Resistance
VGS=10V, ID=20A
4.5
5.5
mΩ
VGS=4.5V, ID=15A
5.9
8.5
mΩ
Min
Typ
Max
Unit
VGS=0V
VDS =20V
f=1MHz
875
pF
VGS=0 to 10V
VDS=20V
ID=20A
IDSS
7. Dynamic Electrical Characteristics
Symbol
Parameter
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Qg
Total Gate Charge
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
8. Switching Characteristics
Symbol
td(on)
tr
td(off)
tf
Parameter
Condition
Turn on Delay Time
VGS=10V
VDD =20V
ID=30A
RG=6Ω
Turn on Rise Time
Turn Off Delay Time
Turn Off Fall Time
9. Source Drain Diode Characteristics
Symbol
VSD
Parameter
trr
Body Diode Reverse Recovery Time
Qrr
Body Diode Reverse Recovery Charge
Craftsman-Made Consciention Chip
Condition
IS=10A, VGS=0V
Drain-Source Diode Forward Voltage
Rev: 2025A1
Condition
IF=20A
di/dt=100A/μs
2/5
Unit
VGS=0V, ID=250μA
524
16
17
5
pF
pF
nC
nC
nC
2
Min
Typ
Max
Unit
6.5
ns
56
26
ns
ns
84
ns
Min
Typ
Max
Unit
0.8
V
ns
9.6
nC
25
www.microdiode.com
MDDG04R06Q
10.Test Circuits And Waveforms
Figure 1. Gate charge testcircuit & waveform
Figure 2.Switching time testcircuit & waveforms
Figure 3.Unclamped inductive switching (UIS)test circuit & waveforms
Figure 4. Diode reverse recoverytest circuit& waveforms
Rev: 2025A1
3/5
www.microdiode.com
MDDG04R06Q
11.Electrical Characteristics Diagrams
120
VGS = 10V
VGS = 8.0V
VGS = 6.0V
VDS = 5.0V
12
ID (A)
ID (A)
16
VGS = 5.5V
90
VGS = 5.0V
60
8
VGS = 4.8V
30
TJ = 25°C
TJ = 125°C
VGS = 4.5V
4
VGS = 4.2V
0.8
1.2
1.6
2
2
3
VDS (V)
Figure 1. Typ. output characteristics
6
2.5
2
Normalized RDS(ON)
8
RDS(ON) (mΩ)
5
Figure 2. Typ. transfer characteristics
10
6
VGS = 10V
4
VGS = 10V
ID = 20A
1.5
1
0.5
2
VGS(V)
60
90
120
150
-50
100
150
Temperature (°C)
ID (A)
Figure 4. RDS(ON) vs. Junction Temperature
Figure 3. On-Resistance vs. Drain Current
100
4
VGS = VDS
3.5
10
ID = 1.0mA
2.5
IS (A)
VGS(th) (V)
3
ID = 250μA
1
TJ = 25°C
TJ = 125°C
0.1
2
0.01
1.5
1
-50
100
150
0.001
TJ(℃) Junction Temperature
Figure 5. Normalized Breakdown Voltage vs.
Rev: 2025A1
0.0
0.2
0.4
0.6
0.8
1.0
1.2
VSD(V)
Figure 6. Forward characteristic of body diode
4/5
www.microdiode.com
MDDG04R06Q
1000
500
Limited by
RDS(ON)
100
1.0μs
300
10μs
10
100μs
1
10ms
ID
(A)
PD (W)
400
200
1.0ms
100
TJ_Max = 150°C
DC
TC = 25°C
0.001
0.01
0.1
1
10
0.1
100
0.1
1
10
100
1000
VDS(V)
Pulse Width (s)
Figure 7. Single Pulse Power Rating
Figure 8. Maximun Safe Operating Area
12. Outline Drawing
PDFN3*3-8L Package Outline Dimensions
Symbol
A
b
C
D
D1
D2/D3
d
E
E1
E2
e
H1
H2
K
L1/L2
θ
N
O
mm
Min
Nom
Max
0.700
0.250
0.150
3.050
2.400
1.000
0.300
3.200
2.900
1.720
0.800
0.325
0.200
3.150
2.500
1.050
0.400
3.300
3.000
1.820
0.65 BSC.
0.415
0.400
0.770
0.150
12°
0.2 REF.
0.900
0.400
0.250
3.250
2.600
1.100
0.500
3.400
3.100
1.920
0.315
0.300
0.670
0.100
11°
0.000
0.515
0.500
0.870
0.200
13°
0.150
13. Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and
specifications at any time without notice. Customers should obtain and confirm the latest product information
and specifications before final design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its
products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for
application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept
any liability with products which are purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics
(Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support
devices or systems without express written approval of Microdiode Electronics (Shenzhen).
Rev: 2025A1
5/5
www.microdiode.com
很抱歉,暂时无法提供与“MDDG04R06Q”相匹配的价格&库存,您可以联系我们找货
