GBLCxxCI Series
Bi-directional Ultra Low Capacitance TVS Array
SOD-323 Plastic-Encapsulate ESD Protection Diodes
DESCRIPTION
The GBLCxxCI Series are ultra low capacitance transient voltage suppressor arrays, designed to
protect applications such as portable electronics and SMART phones. This series is available in both
unidirectional and bidirectional configurations and is rated at 350 Watts for an 8/20μs wave shape.
The GBLCxxCI and Series meets IEC 61000-4-2 (ESD) and IEC 61000-4-4 (EFT) requirements. At
higher operating frequencies or faster edge rates, insertion loss and signal integrity are a major concern.
This series offers a ultra low capacitance and low leakage current in a miniature SOD-323 package.
Features
Pin Configuration
Peak Power Dissipation 350 W (8/20μs)
IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
Protects one I/O line (bidirectional)
Low clamping voltage
Working voltages : 3V, 5V, 8V, 12V, 15V, 18V,
20V,24V,36V
Circuit Diagram
Response Time is < 1 ns
Meets MSL 1 Requirements
Applications
Cell Phone Handsets and Accessories
Microprocessor based equipment
Personal Digital Assistants (PDA’s)
Notebooks, Desktops, and Servers
Portable Instrumentation
Peripherals
USB Interface
Mechanical Characteristics
Package: SOD-323
Flammability Rating: UL 94V-0
High temperature soldering guaranted:
260℃/10s
Packaging: Tape and Reel
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
VESD
± 30
± 30
kV
Peak Pulse Power(tp=8/20us waveform)
PPP
350
W
Operating Temperature
TOPT
−55 to +150
°C
Storage Temperature
TSTG
−55 to +150
°C
TL
260(10 sec.)
°C
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
Lead Solder Temperature – Maximum (10 Second
Duration)
The above data are for reference only.
http://www.microdiode.com
Rev:2025A3
Page :1
GBLCxxCI Series
Electrical Characteristics (TA=25°C unless otherwise specified)
VRWM
VB@1mA
VC@1A
VC@Ipp
VC@Ipp
IR
CT
(V)
(V)
(V)
(V)
(V)
(µA)
(pF)
Max
Min
Max
Max
Ipp
(A)
Max
Ipp
(A)
Max
Typ.
PART
NUMBER
DEVICE
MARKING
GBLC03CI
CC
3.3
4.0
7.0
13.9
8
20.0
0.8
GBLC05CI
AC
5.0
6.0
9.8
18.3
8
20.0
18
1
0.8
GBLC08CI
BC
8.0
8.5
13.4
18.5
8
24.0
18
1
0.8
GBLC12CI
DC
12.0
13.3
19.0
24.0
6
28.6
12
1
0.8
GBLC15CI
EC
15.0
16.7
24.0
29.0
5
31.8
10
1
0.8
GBLC18CI
FC
18.0
20.0
35.0
45.0
5
53.0
7
1
0.8
GBLC20CI
GC
20.0
22.0
38.0
45.0
4
55.0
7
1
0.8
GBLC24CI
HC
24.0
26.7
43.0
45.0
3
56.0
6
1
0.8
GBLC36CI
IC
36.0
40.0
60.0
65.0
2
75.0
4.5
1
0.8
Rev:2025A3
Page :2
GBLCxxCI Series
ELECTRICAL CHARACTERISTICS CURVE
Rev:2025A3
Page :3
GBLCxxCI Series
Outlitne Drawing
SOD-323 Package Outline Dimensions
Suggested Pad Layout
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
PACKAGE SPECIFICATIONS
Package Reel Size
SOD-323
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
178
3000
183×188×80
45,000
386×265×215
180,000
7'
Rev:2025A3
Page :4
很抱歉,暂时无法提供与“GBLC05CI”相匹配的价格&库存,您可以联系我们找货
