SD20
SD20
    MDD(辰达半导体)
    SOD-323
    350W 22.3V ESD管
SD20 数据手册
SDxx Series Uni-directional TVS Diodes SOD-323 Plastic-Encapsulate ESD Protection Diodes DESCRIPTION The SDxx Series is designed for applications requiring transient overvoltage protection capability. They are intended for use in voltage and ESD sensitive equipment such as computers, printers, business machines, communication systems, medical equipment and other applications. These devices are ideal for situations where board space is at a premium. This series has been specifically designed to protect sensitive components which are connected to power 、 data and transmission lines from overvoltage caused by ESD(electrostatic discharge), CDE (Cable Discharge Events),and EFT (electrical fast transients). Features Pin Configuration  350 Watts Peak Pulse Power per (8/20μs)  IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact)  IEC61000-4-4 (EFT) 40A (5/50ns)  Protects one I/O line (unidirectional)  Low clamping voltage  Low leakage current  Working voltages : 3V, 5V, 8V,12V, 15V, 18V, 20V,24V,36V  Meets MSL 1 Requirements Applications         Cell Phone Handsets and Accessories Microprocessor based equipment Personal Digital Assistants (PDA’s) Notebooks, Desktops, and Servers Portable Instrumentation Networking and Telecom Serial and Parallel Ports Peripherals Circuit Diagram 1 2 Mechanical Characteristics  Package: SOD-323  Flammability Rating: UL 94V-0  Terminal: Matte tin plated.  High temperature soldering guaranted: 260℃/10s  Packaging: Tape and Reel Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit VESD ± 30 ± 30 KV Peak Pulse Power(tp=8/20us waveform) PPP 350 W Operating Temperature TOPT −55 to +150 °C Storage Temperature TSTG −55 to +150 °C TL 260(10 sec.) °C ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) Lead Solder Temperature – Maximum (10 Second Duration) The above data are for reference only. http://www.microdiode.com Rev:2024A3 Page :1 SDxx Series Uni-directional TVS Diodes Electrical Characteristics (TA=25°C unless otherwise specified) VRWM (V) VB IT VC@1A VC IR (V) (mA) (V) (V) (max.) (min.) (max.) 03W 3.3 4 SD05 05W 5 SD08 08W SD12 PART NUMBER DEVICE MARKING SD03 CT (max.) (max.) (@A) (µA) (max.) (pF) 1 6.5 14 20 40 450 6 1 9.8 18 17 10 300 8 8.5 1 10.5 24 15 1 240 12W 12 13.3 1 19 32 11 1 130 SD15 15W 15 16.7 1 24 38 10 1 120 SD18 18W 18 20.0 1 29 45 9 1 100 SD20 20W 20 22.3 1 35 50 8 1 90 SD24 24W 24 26.7 1 43 52 7 1 80 SD36 36W 36 40 1 60 75 5 1 60 The above data are for reference only. http://www.microdiode.com Rev:2024A3 Page :2 SDxx Series Uni-directional TVS Diodes ELECTRICAL CHARACTERISTICS CURVE The curve above is for reference only. http://www.microdiode.com Rev:2024A3 Page :3 SDxx Series Uni-directional TVS Diodes Outlitne Drawing SOD-323 Package Outline Dimensions Suggested Pad Layout Note: 1.Controlling dimension:in/millimeters. 2.General tolerance: ±0.05mm. 3.The pad layout is for reference purposes only. PACKAGE SPECIFICATIONS Package Reel Size SOD-323 Reel DIA. (mm) Q'TY/Reel (pcs) Box Size (mm) QTY/Box (pcs) Carton Size (mm) Q'TY/Carton (pcs) 178 3000 183×188×80 45,000 386×265×215 180,000 7' http://www.microdiode.com Rev:2024A3 Page :4
很抱歉,暂时无法提供与“SD20”相匹配的价格&库存,您可以联系我们找货
