SMxxC Series
Bi-directional TVS Diodes Array
SOT-23 Plastic-Encapsulate ESD Protection Diodes
DESCRIPTION
The SMxxC Series is designed for applications requiring transient overvoltage protection capability.
They are intended for use in voltage and ESD sensitive equipment such as computers, printers,
business machines, communication systems, medical equipment and other applications. These devices
are ideal for situations where board space is at a premium.
This series has been specifically designed to protect sensitive components which are connected to
power 、 data and transmission lines from overvoltage caused by ESD(electrostatic discharge), CDE
(Cable Discharge Events),and EFT (electrical fast transients).
Features
Pin Configuration
350 Watts Peak Pulse Power per (8/20μs)
IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
Protects two bidirectional line
Low clamping voltage
Low leakage current
Working voltages : 3V, 5V, 8V, 12V, 15V, 18V,
20V,24V,36V
Circuit Diagram
Meets MSL 1 Requirements
Applications
Cell Phone Handsets and Accessories
Microprocessor based equipment
Personal Digital Assistants (PDA’s)
Notebooks, Desktops, and Servers
Portable Instrumentation
Networking and Telecom
Serial and Parallel Ports
Peripherals
Mechanical Characteristics
Package: SOT-23
Flammability Rating: UL 94V-0
Terminal: Matte tin plated.
High temperature soldering guaranted:
260℃/10s
Packaging: Tape and Reel
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
VESD
± 30
± 30
KV
Peak Pulse Power(tp=8/20us waveform)
PPP
350
W
Operating Temperature
TOPT
−55 to +150
°C
Storage Temperature
TSTG
−55 to +150
°C
TL
260(10 sec.)
°C
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
Lead Solder Temperature – Maximum (10 Second
Duration)
The above data are for reference only.
http://www.microdiode.com
Rev:2024A3
Page :1
SMxxC Series
Electrical Characteristics (TA=25°C unless otherwise specified)
PART
NUMBER
DEVICE
MARKING
VRWM
(V)
VB
IT
VC@1A
VC
IR
(V)
(mA)
(V)
(V)
(max.)
(min.)
(max.)
(max.)
(max.)
(@A)
(µA)
(max.)
CT
(pF)
SM03C
C03
3.3
4
1
7.5
16
450
SM05C
C05
5
6
1
9.8
18
17
10
200
SM08C
C08
8
8.5
1
13.4
24
15
2
120
SM12C
C12
12
13.3
1
19
32
11
1
75
SM15C
C15
15
16.7
1
24
38
10
1
68
SM18C
C18
18
20.0
1
29
45
9
1
57
SM20C
C20
1
35
50
8
1
52
SM24C
C24
24
26.7
1
43
52
7
1
50
SM36C
C36
36
40
1
60
75
4.5
1
35
Rev:2024A3
Page :2
SMxxC Series
ELECTRICAL CHARACTERISTICS CURVE
The curve above is for reference only.
Rev:2024A3
Page :3
SMxxC Series
Outlitne Drawing
SOT-23 Package Outline Dimensions
L
L1
E
E1
Symbol
A
A1
e
Suggested Pad Layout
0.037
0.95
0.037
0.95
A
A1
b
c
D
E
E1
e
L
L1
θ
Dimensions In Millimeters
Min
Typ
Max
0.65
1.40
0.20
0.00
0.30
0.55
0.20
0.08
2.70
3.10
1.15
1.65
2.80
2.10
1.70
2.10
0.15
0.50
0.35
0°
0.70
12°
Note:
1. Controlling dimension:in/millimeters.
2. General tolerance: ±0.05mm.
3. The pad layout is for reference purposes only.
0.079
2.0
0.035
0.9
0.031
0.8
inches
mm
Rev:2024A3
Page :4
SMxxC Series
SOT-23 Tape and Reel
Packaging Description:
SOT-23 parts are shipped in tape. The carrier
tape is made from a dissipative (carbon filled)
polycarbonate resin. The cover tape is a multilayer
film (Heat Activated Adhesive in nature) primarily
composed of polyester film,adhesive laye,sealant,
and anti-static sprayed agent.These reeled parts In
standard option are shipped with 3,000 units per 7"
or 17.8cm diameter reel. The reels are clear in color
and is made of polystyrene plastic (anti-static
coated).
3000 pcs
7 Inch
45,000 pcs
203×203×195
180,000 pcs
438×438×220
Rev:2024A3
Page :5
很抱歉,暂时无法提供与“SM36C”相匹配的价格&库存,您可以联系我们找货
