74AHC1G09; 74AHCT1G09
2-inut AND with open-drain output
Product datasheet, Rev. 1.0
Aug 08, 2024
1.General Description
74AHC1G09 and 74AHCT1G09 are single 2-input AND gates with open-drain outputs. Inputs are
overvoltage tolerant. This feature allows the use of these devices as translators in mixed
voltage environments.
2.Features and Benefits
Wide supply voltage range from 2.0 V to 5.5 V
Overvoltage tolerant inputs to 5.5 V
High noise immunity
CMOS low power dissipation
Latch-up performance exceeds 200 mA
Input levels:
For 74AHC1G09: CMOS level
For 74AHCT1G09: TTL level
ESD protection:
HBM ANSI/ESDA/JEDEC JS-001 Class 3A exceeds 7000 V
CDM ANSI/ESDA/JEDEC JS-002 Class C3 exceeds 2000 V
Multiple package options
Rev. 1.0 – Aug 08, 2024
1
2-input AND with open-drain output
3.Ordering Information
Table 1. Ordering information
Type number
74AHC1G09GV
74AHCT1G09GV
74AHC1G09GW
74AHCT1G09GW
74AHC1G09DRL
74AHCT1G09DRL
Package
Name
Description
Quantity
SOT23-5L
SOT23 package, 5 pins 2.92 mm × 1.6 mm; 1.25 mm
(Max) height
3000
SOT353
SOT353 package, 5 pins 2.1 mm × 1.25 mm; 1.1 mm
(Max) height
3000
SOT553
SOT553 package, 5 pins
1.6 mm × 1.2 mm; 0.6 mm (Max) height
3000
4.Function Diagram
Fig. 1. Logic symbol
Fig. 2. IEC logic symbol
Fig. 3. Logic diagram
2
5.Pinning Information
5.1. Pinning
Fig. 4. Top view pin configuration SOT23-5L, SOT353 and SOT553
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
B
1
Data input
A
2
Data input
GND
3
Ground (0V)
Y
4
Data output
VCC
5
Supply voltage
6.Functional Description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state.
Input
Output
A
B
Y
L
L
L
L
H
L
H
L
L
H
H
Z
3
7.Absolute Maximum Ratings
Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be
operable above the recommended operating conditions and stressing the parts to these levels is not
recommended. In addition, extended exposure to stresses above the recommended operating conditions may
affect device reliability. The absolute maximum ratings are stress ratings only.
Table 4. Absolute Maximum Ratings
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND.
Symbol
Parameter
VCC
Min
Max
Unit
supply voltage
-0.5
7.0
V
VI
input voltage
-0.5
7.0
V
IIK
input clamping current
IOK
output clamping current
IO
output current
VO
output voltage
ICC
supply current
IGND
ground current
Ptot
total power dissipation
Tstg
storage temperature
Conditions
VI < -0.5 V
VO
[1]
VO > - 0.5 V
active
[1]
high-impedance
[1]
-20
-0.5
mA
V
mode
mode
±20
mA
±25
mA
-0.5
7.0
V
-0.5
7.0
V
75
mA
-75
mA
Tamb = -40 °C to + 125 °C
-65
250
mW
150
°C
[1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
8.Recommended Operating Conditions
The Recommended Operating Conditions table defines the conditions for actual device operation. Recommended
operating conditions are specified to ensure optimal performance to the datasheet specifications. MDD does not
recommend exceeding them or designing to Absolute Maximum Ratings.
Table 5. Recommended Operating Conditions
Symbol
Parameter
VCC
Conditions
74AHC1G09
74AHCT1G09
Unit
Min
Typ
Max
Min
Typ
Max
supply voltage
2.0
5.0
5.5
4.5
5.0
5.5
V
VI
input voltage
V
VO
output voltage
active mode
VCC
VCC
V
high-impedance mode
V
Tamb
ambient temperature
125
-40
125
°C
-40
25
25
4
Δt/ΔV
input transition rise and fall
rate
VCC = 3.3 V ± 0.3 V
100
VCC = 5.0 V ± 0.5 V
ns/V
ns/V
9.Static Characteristics
Table 6. Static characteristics
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
-40 °C to +85 °C
Min
Typ[1]
-40 °C to +125 °C
Max
Min
Max
Unit
74AHC1G09
VIH
VIL
HIGH-level
input voltage
LOW-level
input voltage
VCC = 2.0 V
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
V
VCC = 2.0 V
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
V
VI = VIH or VIL
VOL
II
IOZ
ICC
CI
LOW-level
output
voltage
input
leakage
current
OFF-state
output
current
supply
current
input
capacitance
IO = 50 μA; VCC = 2.0 V
0.1
V
IO = 50 μA; VCC = 3.0 V
0.1
V
IO = 50 μA; VCC = 4.5 V
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.05
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.07
0.44
0.55
V
VI = 5.5 V or GND ;
VCC = 0 V to 5.5 V
±0.01
±1.0
±2.0
μA
VI = VIH or VIL; VO = VCC or GND;
VCC = 5.5 V
±0.01
±2.5
±10.0
μA
VI = VCC or GND ; IO = 0 A ;
VCC = 5.5 V
0.01
10
μA
3.5
pF
5
Symbol
Parameter
Conditions
-40 °C to +85 °C
Min
Typ[1]
-40 °C to +125 °C
Max
Min
Max
Unit
74AHCT1G09
VIH
VIL
VOL
II
IOZ
ICC
ΔICC
CI
HIGH-level
input voltage
LOW-level
input voltage
LOW-level
output
voltage
input
leakage
current
OFF-state
output
current
supply
current
additional
supply
current
input
capacitance
VCC = 4.5 V to 5.5 V
2.0
2.0
V
0.8
0.8
V
VI = VIH or VIL; VCC = 4.5 V
IO = 50 μA;
0.1
V
IO = 8.0 mA;
0.07
0.44
0.55
V
VI = 5.5 V or GND ;
VCC = 0 V to 5.5 V
±0.01
±1.0
±2.0
μA
VCC = 5.5 V
±0.01
±2.5
±10.0
μA
0.01
10
μA
0.23
1.35
1.35
mA
VCC = 5.5 V
per input pin ; VI = 3.4 V;
other inputs at VCC or GND;
IO = 0 A; VCC = 5.5 V
3.5
pF
[1]All typical values are measured at Tamb = 25°C.
6
10. Dynamic Characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 6.
Symbol
Parameter
-40 °C to +85 °C
Conditions
-40 °C to +125 °C
Unit
Min
Typ[1]
Max
Min
Max
VCC = 3.0 V to 3.6 V, CL = 15 pF
2.5
5.3
8.5
2.5
9.5
ns
VCC = 4.5 V to 5.5 V, CL = 15 pF
1.5
3.5
5.5
1.5
6.0
ns
2.5
5.8
9.0
2.5
10.0
ns
1.5
4.1
6.0
1.5
6.5
ns
74AHC1G09
tPZL
tPLZ
CPD
OFF-state to
LOW
propagation
delay
A and B to Y; see Fig. 5
LOW to OFFstate
propagation
delay
power
dissipation
capacitance
CL = 15 pF ; f = 1MHz ;
VI = GND to VCC ;
4
[2]
pF
74AHCT1G09
tPZL
tPLZ
CPD
OFF-state to
LOW
propagation
delay
LOW to OFFstate
propagation
delay
power
dissipation
capacitance
1.5
5.0
7.0
1.5
7.5
ns
1.5
5.1
7.0
1.5
7.5
ns
VI
GND
to
[2]
VCC
4
pF
[1] Typical values are measured at Tamb = 25 °C and VCC = 3.3 V and 5.0 V respectively.
[2] CPD is used to determine the dynamic power dissipation (PD in μW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of outputs.
7
10.1. Waveforms and test circuit
Measurement points are given in Table 8.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 5. The input A, B to output Y propagation delays
Table 8. Measurement points
Type
Input
Output
VI
VM
VM
VX
74AHC1G09
GND to VCC
0.5 x VCC
0.5 x VCC
VOL + 0.3V
74AHCT1G09
GND to 3.0 V
1.5 V
0.5 x VCC
VOL + 0.3V
8
Test data is given in Table 9.
Definitions for test circuit:
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
RL = Load resistance.
VEXT = External voltage for measuring switching times.
Fig. 6. Test circuit for measuring switching times
Table 9. Test data
Type
Input
Load
VI
tr = tf
CL
RL
tPZL, tPLZ
74AHC1G09
GND to VCC
≤ 2.5 ns
15 pF
500 Ω
VCC
74AHCT1G09
GND to 3.0 V
≤ 2.5 ns
15 pF
500 Ω
VCC
9
11. Package Outline
SOT23-5L
10
SOT353
11
SOT553
12
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
CDM
Charged Device Model
TTL
Transistor-Transistor Logic
13. Revision History
Table 11. Revision history
Document ID
Release Date
Data sheet status
74AHC_AHCT1G09 Rev. 1.0
Apr 20, 2024
Product datasheet
Change notice
Supersedes
13
很抱歉,暂时无法提供与“74AHCT1G09GV”相匹配的价格&库存,您可以联系我们找货
