74HC138; 74HCT138
3-to-8 line decoder/demultiplexer; inverting
Draft datasheet, Rev. 1.0
Aug 08, 2024
1.General Description
The 74HC138 and 74HCT138 decode three binary weighted address inputs (A0, A1 and A2) to
eight mutually exclusive outputs (Y0 to Y7). The device features three enable inputs (E1, E2 and
E3). Every output will be HIGH unless E1 and E2 are LOW and E3 is HIGH. This multiple enable
function allows easy parallel expansion to a 1-of-32 (5 to 32 lines) decoder with just four '138
ICs and one inverter. The '138 can be used as an eight output demultiplexer by using one of the
active LOW enable inputs as the data input and the remaining enable inputs as strobes. Inputs
include clamp diodes. This enables the use of current limiting resistors to interface inputs to
voltages in excess of VCC.
2.Features and Benefits
Wide operating voltage 2.0 V to 6.0 V
High noise immunity
CMOS low power dissipation
Latch-up performance exceeds 250 mA
Demultiplexing capability
Multiple input enable for easy expansion
Ideal for memory chip select decoding
Active LOW mutually exclusive outputs
Input levels:
For 74HC138: CMOS level
For 74HCT138: TTL level
ESD protection:
HBM: ANSI/ESDA/JEDEC JS-001 class 2 exceeds 3500 V
CDM: ANSI/ESDA/JEDEC JS-002 class C3 exceeds 2000 V
Multiple package options
Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Rev. 1.0 – Aug 08, 2024
1
74HC138; 74HCT138
3.Ordering Information
Table 1. Ordering information
Type number
74HC138D
74HCT138D
74HC138PW
74HCT138PW
Package
Name
Description
Quantity
SOP-16L
plastic small outline package; 16 leads;
body width 3.9 mm
2500
TSSOP-16L
plastic thin shrink small outline package;
16 leads; body width 4.4 mm
2500
2
74HC138; 74HCT138
4.Functional diagram
Fig. 1. Logic symbol
Fig. 2. Functional diagram
Fig. 3. Logic diagram
3
74HC138; 74HCT138
5.Pinning Information
5.1. Pinning
Fig. 4. Top view pin configuration SOP-20L and TSSOP-20L
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
A0, A1, A2
1, 2, 3
address input
E1, E2
4, 5
enable input (active LOW)
E3
6
enable input (active HIGH)
Y0, Y1, Y2, Y3, Y4, Y5, Y6, Y7
15, 14, 13, 12, 11, 10, 9, 7
output
GND
8
ground (0 V)
VCC
16
supply voltage
4
74HC138; 74HCT138
6.Functional Description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
Control
E1
H
X
X
L
Input
E2
X
H
X
L
Output
E3
A2
A1
A0
Y7
Y6
Y5
Y4
Y3
Y2
Y1
Y0
X
X
L
X
X
X
H
H
H
H
H
H
H
H
H
L
L
L
L
H
H
H
H
L
L
H
H
L
L
H
H
L
H
L
H
L
H
L
H
H
H
H
H
H
H
H
L
H
H
H
H
H
H
L
H
H
H
H
H
H
L
H
H
H
H
H
H
L
H
H
H
H
H
H
L
H
H
H
H
H
H
L
H
H
H
H
H
H
L
H
H
H
H
H
H
L
H
H
H
H
H
H
H
5
74HC138; 74HCT138
7.Absolute Maximum Ratings
Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be
operable above the recommended operating conditions and stressing the parts to these levels is not
recommended. In addition, extended exposure to stresses above the recommended operating conditions may
affect device reliability. The absolute maximum ratings are stress ratings only.
Table 4. Absolute Maximum Ratings
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND.
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
IOK
Conditions
Min
Max
Unit
-0.5
7
V
VI < -0.5 V or VI > VCC + 0.5 V
±20
mA
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
±20
mA
IO
output current
-0.5V < VO < VCC + 0.5 V
±25
mA
ICC
supply current
50
mA
IGND
ground current
Ptot
total power dissipation
Tstg
storage temperature
-50
mA
Tamb = -40 °C to + 125 °C
-65
500
mW
+150
°C
8.Recommended Operating Conditions
The Recommended Operating Conditions table defines the conditions for actual device operation. Recommended
operating conditions are specified to ensure optimal performance to the datasheet specifications. MDD does not
recommend exceeding them or designing to Absolute Maximum Ratings.
Table 5. Recommended Operating Conditions
Symbol
Parameter
VCC
Conditions
74HC138
74HCT138
Unit
Min
Min
Typ
Min
Min
Typ
supply voltage
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
+125
-40
+125
°C
Δt/ΔV
input transition rise and
fall rate
-40
+25
VCC = 2.0 V
VCC = 4.5 V
VCC = 6.0 V
+25
625
1.67
139
83
ns/V
1.67
139
ns/V
ns/V
6
74HC138; 74HCT138
9.Static Characteristics
Table 6. Static characteristics
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Typical values measured at
Tamb = 25°C (unless otherwise noted).
Symbol
Parameter
Conditions
-40 °C to +85 °C
Min
Typ
Max
-40 °C to +125 °C
Min
Max
Unit
74HC138
VIH
VIL
HIGH-level
input voltage
LOW-level
input voltage
VCC = 2.0 V
1.5
1.5
V
VCC = 4.5 V
3.15
3.15
V
VCC = 6.0 V
4.2
4.2
V
VCC = 2.0 V
0.5
0.5
V
VCC = 4.5 V
1.35
1.35
V
VCC = 6.0 V
1.8
1.8
V
VI = VIH or VIL
VOH
HIGH-level
output voltage
IO = -20 μA; VCC = 2.0 V
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
5.9
V
IO = -4.0 mA; VCC = 4.5 V
3.84
3.7
V
IO = -5.2 mA; VCC = 6.0 V
5.34
5.2
V
VI = VIH or VIL
VOL
LOW-level
output voltage
II
input leakage
current
ICC
supply current
CI
input
capacitance
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.33
0.4
V
±1
±1
μA
μA
VI = VCC or GND ;
VCC = 6.0 V
VI = VCC or GND ; IO = 0 A ;
VCC = 6.0 V
4.0
pF
7
74HC138; 74HCT138
Symbol
Parameter
Conditions
-40 °C to +85 °C
Min
Typ
Max
-40 °C to +125 °C
Min
Max
Unit
74HCT138
VIH
VIL
VOH
VOL
II
ICC
ΔICC
CI
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output
voltage
LOW-level
output
voltage
input leakage
current
supply
current
additional
supply
current
input
capacitance
VCC = 4.5 V to 5.5 V
2.0
2.0
0.8
V
0.8
V
VI = VIH or VIL;
4.4
4.4
V
3.84
3.7
V
VI = VIH or VIL;
0.1
0.1
V
0.33
0.4
V
±1
±1
μA
μA
400
490
μA
VI = VCC or GND ;
VCC = 5.5 V
VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
per pin ; VI = VCC - 2.1 V; IO = 0
A; other inputs at VCC or GND;
4.0
pF
8
74HC138; 74HCT138
10. Dynamic Characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 7. Typical values measured at Tamb = 25°C
Symbol
Parameter
-40 °C to +85 °C
Conditions
Min
Typ
-40 °C to +125 °C
Max
Min
Max
Unit
74HC138
An to Yn; see Fig. 5
VCC = 2.0 V
35
40
ns
VCC = 4.5 V
ns
VCC = 6.0 V
15
ns
VCC = 2.0 V
35
40
ns
VCC = 4.5 V
ns
VCC = 6.0 V
15
ns
VCC = 2.0 V
35
40
ns
VCC = 4.5 V
ns
VCC = 6.0 V
15
ns
VCC = 2.0 V
9
11
ns
VCC = 4.5 V
6
8
ns
VCC = 6.0 V
4
5
ns
E3 to Yn; see Fig. 5
tpd
propagation
delay
En to Yn; see Fig. 6
Yn; see Fig. 5 and Fig. 6
tt
transition
time
CPD
power
dissipation
capacitance
[1]
CL = 50pF ; f = 1 MHz ;
VI
GND
to
[3]
[1]
[1]
[2]
VCC
67
pF
9
74HC138; 74HCT138
Symbol
Parameter
-40 °C to +85 °C
Conditions
Min
Typ
-40 °C to +125 °C
Max
Min
Max
Unit
74HCT138
tpd
propagation
delay
tt
transition
time
CPD
power
dissipation
capacitance
An to Yn; VCC = 4.5V;
see
Fig.
[1]
E3 to Yn; VCC = 4.5V;
see
Fig.
[1]
En to Yn; VCC = 4.5V
see
Fig.
[1]
Yn; VCC=4.5V;
see Fig. 5 and
[2]
Fig.
VI = GND to VCC – 1.5 V
[1] tpd is the same as tPHL and tPLH.
[2] tt is the same as tTHL and tTLH.
[3] CPD is used to determine the dynamic power dissipation (PD in μW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of outputs.
10
5
ns
5
ns
6
ns
6;
6
8
ns
[3]
67
pF
74HC138; 74HCT138
10.1. Waveforms and test circuit
Measurement points are given in Table 8.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 5. Propagation delay input (An) and enable input (E3) to output (Yn) and transition time output
(Yn)
Fig. 6. Propagation delay enable input (En) to output (Yn) and transition time output (Yn)
Table 8. Measurement points
Type
74HC245
11
Input
Output
VM
VM
VX
VY
0.5VCC
0.5VCC
0.1VCC
0.9VCC
74HC138; 74HCT138
74HCT245
1.3 V
1.3 V
0.1VCC
0.9VCC
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 7. Test circuit for measuring switching times
Table 9. Test data
Type
Input
Load
VEXT
VI
tr = tf
CL
RL
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
74HC245
VCC
≤ 2.5 ns
50 pF
500Ω
open
GND
2VCC
74HCT245
3V
≤ 2.5 ns
50 pF
500Ω
open
GND
2VCC
12
74HC138; 74HCT138
11. Package Outline
SOP-16L
Symbol
A
A1
A2
b
c
D
e
E
E1
L
θ
13
Dimensions In Millimeters
Min.
Max.
1.750
0.150
0.250
1.400
1.500
0.330
0.510
0.170
0.250
9.800
10.000
1.270(BSC)
5.900
6.100
3.800
4.000
0.400
1.270
0°
8°
Dimensions In Inches
Min.
Max.
0.069
0.006
0.010
0.055
0.059
0.013
0.020
0.007
0.010
0.386
0.394
0.050(BSC)
0.232
0.240
0.150
0.157
0.016
0.050
0°
8°
74HC138; 74HCT138
TSSOP-16L
Symbol
A
A1
A2
b
c
D
e
E
E1
L
θ
14
Min.
Max.
1.200
0.020
0.100
0.800
1.000
0.190
0.300
0.090
0.200
4.900
5.100
0.650(BSC)
6.250
6.550
4.300
4.500
0.500
0.700
1°
7°
Min.
Max.
0.047
0.001
0.004
0.031
0.039
0.007
0.012
0.004
0.008
0.193
0.201
0.026(BSC)
0.252(BSC)
0.169
0.177
0.020
0.028
1°
7°
74HC138; 74HCT138
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
CDM
Charged Device Model
TTL
Transistor-Transistor Logic
13. Revision History
Table 11. Revision history
Document ID
Release Date
Data sheet status
74AHC_HCT138 Rev. 1.0
Apr 24, 2024
Draft datasheet
15
Change notice
Supersedes
很抱歉,暂时无法提供与“74HCT138D”相匹配的价格&库存,您可以联系我们找货
