74AHC1G04; 74AHCT1G04
Inverter
Product datasheet, Rev. 1.0
Aug 08, 2024
1.General Description
The 74AHC1G04 and 74AHCT1G04 are single inverters. Inputs are overvoltage tolerant.This
feature allows the use of these devices as translators in mixed voltage environments.
The AHC device has CMOS input switching levels and supply voltage range 2 V to 5.5 V.
The AHCT device has TTL input switching levels and supply voltage range 4.5 V to 5.5 V.
2.Features and Benefits
Wide supply voltage range from 2.0 V to 5.5 V
Overvoltage tolerant inputs to 5.5 V
High noise immunity
CMOS low power dissipation
Latch-up performance exceeds 200 mA
Symmetrical output impedance
Balanced propagation delays
Input levels:
For 74AHC1G04: CMOS level
For 74AHCT1G04: TTL level
ESD protection:
HBM ANSI/ESDA/JEDEC JS-001 Class 3A exceeds 7000 V
CDM ANSI/ESDA/JEDEC JS-002 Class C3 exceeds 2000 V
Multiple package options
Rev. 1.0 – Aug 08, 2024
1
Inverter
3.Ordering Information
Table 1. Ordering information
Type number
74AHC1G04GV
74AHCT1G04GV
74AHC1G04GW
74AHCT1G04GW
74AHC1G04DRL
74AHCT1G04DRL
Package
Name
Description
Quantity
SOT23-5L
SOT23 package, 5 pins 2.92 mm × 1.6 mm; 1.25 mm
(Max) height
3000
SOT353
SOT353 package, 5 pins 2.1 mm × 1.25 mm; 1.1 mm
(Max) height
3000
SOT553
SOT553 package, 5 pins
1.6 mm × 1.2 mm; 0.6 mm (Max) height
3000
4.Function Diagram
Fig. 1. Logic symbol
Fig. 2. IEC logic symbol
Fig. 3. Logic diagram
2
Inverter
5.Pinning Information
5.1. Pinning
Fig. 4. Top view pin configuration SOT23-5L, SOT353 and SOT553
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
n.c.
1
Not connected
A
2
Data input
GND
3
Ground (0V)
Y
4
Data output
VCC
5
Supply voltage
6.Functional Description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level.
Input
Output
A
Y
L
H
H
L
3
Inverter
7.Absolute Maximum Ratings
Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be
operable above the recommended operating conditions and stressing the parts to these levels is not
recommended. In addition, extended exposure to stresses above the recommended operating conditions may
affect device reliability. The absolute maximum ratings are stress ratings only.
Table 4. Absolute Maximum Ratings
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND.
Symbol
Parameter
VCC
Conditions
Min
Max
Unit
supply voltage
-0.5
7.0
V
VI
input voltage
-0.5
7.0
V
IIK
input clamping current
IOK
output clamping current
IO
output current
ICC
supply current
IGND
ground current
Ptot
total power dissipation
Tstg
storage temperature
VI < -0.5 V
VO < -0.5 V or VO > VCC + 0.5 V
[1]
-0.5 V < VO < VCC + 0.5 V
-20
mA
±20
mA
±25
mA
75
mA
-75
mA
Tamb = -40 °C to + 125 °C
-65
250
mW
150
°C
[1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
8.Recommended Operating Conditions
The Recommended Operating Conditions table defines the conditions for actual device operation. Recommended
operating conditions are specified to ensure optimal performance to the datasheet specifications. MDD does not
recommend exceeding them or designing to Absolute Maximum Ratings.
Table 5. Recommended Operating Conditions
Symbol
Parameter
VCC
Conditions
74AHC1G04
74AHCT1G04
Unit
Min
Typ
Max
Min
Typ
Max
supply voltage
2.0
5.0
5.5
4.5
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
125
-40
125
°C
Δt/ΔV
input transition rise and fall
rate
-40
25
VCC = 3.3 V ± 0.3 V
100
VCC = 5.0 V ± 0.5 V
ns/V
ns/V
4
Inverter
9.Static Characteristics
Table 6. Static characteristics
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
-40 °C to +85 °C
Min
Typ[1]
-40 °C to +125 °C
Max
Min
Max
Unit
74AHC1G04
VIH
VIL
HIGH-level
input
voltage
LOW-level
input voltage
VCC = 2.0 V
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
V
VCC = 2.0 V
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
V
VI = VIH or VIL
VOH
HIGH-level
output
voltage
IO = -50 μA; VCC = 2.0 V
1.9
2.0
1.9
V
IO = -50 μA; VCC = 3.0 V
2.9
3.0
2.9
V
IO = -50 μA; VCC = 4.5 V
4.4
4.5
4.4
V
IO = -4.0 mA; VCC = 3.0 V
2.48
2.93
2.40
V
IO = -8.0 mA; VCC = 4.5 V
3.80
4.39
3.70
V
VI = VIH or VIL
VOL
II
ICC
CI
LOW-level
output
voltage
input
leakage
current
supply
current
input
capacitance
IO = 50 μA; VCC = 2.0 V
0.1
V
IO = 50 μA; VCC = 3.0 V
0.1
V
IO = 50 μA; VCC = 4.5 V
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.05
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.07
0.44
0.55
V
VI = 5.5 V or GND ;
VCC = 0 V to 5.5 V
±0.01
±1.0
±2.0
μA
VI = VCC or GND ; IO = 0 A ;
VCC = 5.5 V
0.01
10
40
μA
3.5
pF
5
Inverter
Symbol
Parameter
Conditions
-40 °C to +85 °C
Min
Typ[1]
-40 °C to +125 °C
Max
Min
Max
Unit
74AHCT1G04
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
II
input leakage
current
ICC
supply current
ΔICC
additional
supply current
CI
input
capacitance
VCC = 4.5 V to 5.5 V
2.0
2.0
0.8
V
0.8
V
VI = VIH or VIL; VCC = 4.5 V
IO = -50 μA;
4.4
4.5
4.4
V
IO = -8.0 mA;
3.80
4.39
3.70
V
IO = 50 μA;
0.1
V
IO = 8.0 mA;
0.07
0.44
0.55
V
±0.01
±1.0
±2.0
μA
0.01
10
40
μA
0.23
1.35
1.35
mA
VI = 5.5 V or GND ;
VCC = 0 V to 5.5 V
VCC = 5.5 V
per input pin ; VI = 3.4 V;
other inputs at VCC or
GND;
IO = 0 A; VCC = 5.5 V
3.5
pF
[1]All typical values are measured at Tamb = 25°C.
6
Inverter
10. Dynamic Characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 6.
Symbol
Parameter
-40 °C to +85 °C
Conditions
-40 °C to +125 °C
Unit
Min
Typ[1]
Max
Min
Max
VCC = 3.0 V to 3.6 V, CL = 15 pF
1.0
4.3
9.5
1.0
10.0
ns
VCC = 4.5 V to 5.5 V, CL = 15 pF
1.0
3.1
6.5
1.0
7.0
ns
74AHC1G04
tpd
CPD
propagation
delay
power
dissipation
capacitance
A to Y; see Fig. 5
[2]
CL = 15 pF ; f = 1MHz ;
VI = GND to VCC
[3]
pF
74AHCT1G04
tpd
propagation
delay
CPD
power
dissipation
capacitance
A to
[2]
Y;
see
Fig.
5
VI = GND to VCC
[3]
1.0
4.3
21
8.0
1.0
8.5
ns
pF
[1] Typical values are measured at Tamb = 25 °C and VCC = 3.3 V and 5.0 V respectively.
[2] tpd is the same as tPLH and tPHL.
[3] CPD is used to determine the dynamic power dissipation (PD in μW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of outputs.
7
Inverter
10.1. Waveforms and test circuit
Measurement points are given in Table 8.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 5. The input A to output Y propagation delays
Table 8. Measurement points
Type
Input
Output
VI
VM
VM
74AHC1G04
GND to VCC
0.5 x VCC
0.5 x VCC
74AHCT1G04
GND to 3.0 V
1.5 V
0.5 x VCC
8
Inverter
Test data is given in Table 9.
Definitions for test circuit:
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
Fig. 6. Test circuit for measuring switching times
Table 9. Test data
Input
Load
tr = tf
CL
74AHC1G04
≤ 2.5 ns
15 pF
74AHCT1G04
≤ 2.5 ns
15 pF
Type
9
Inverter
11. Package Outline
SOT23-5L
10
Inverter
SOT353
11
Inverter
SOT553
12
Inverter
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
CDM
Charged Device Model
TTL
Transistor-Transistor Logic
13. Revision History
Table 11. Revision history
Document ID
Release Date
Data sheet status
74AHC_AHCT1G04 Rev. 1.0
Apr 20, 2024
Product datasheet
Change notice
Supersedes
13
很抱歉,暂时无法提供与“74AHCT1G04GW”相匹配的价格&库存,您可以联系我们找货
