74LVC2G06
Inverters with open-drain outputs
Product datasheet, Rev1.0
Aug 08, 2024
1.General Description
The 74LVC2G06 is a dual inverter with open-drain outputs. Inputs can be driven from either 3.3
V or 5 V devices. This feature allows the use of these devices as translators in mixed 3.3 V and 5
V environments. Schmitt-trigger action at all inputs makes the circuit tolerant of slower input
rise and fall times. This device is fully specified for partial power down applications using IOFF.
The IOFF circuitry disables the output, preventing the potentially damaging backflow current
through the device when it is powered down.
2.Features and Benefits
Wide supply voltage range from 1.65 V to 5.5 V
Overvoltage tolerant inputs to 5.5 V
High noise immunity
CMOS low power dissipation
IOFF circuitry provides partial Power-down mode operation
-24 mA output drive (VCC = 3.0 V)
Latch-up performance exceeds 100 mA
Direct interface with TTL levels
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8C (2.7 V to 3.6 V)
JESD36 (4.5 V to 5.5 V)
ESD protection:
HBM ANSI/ESDA/JEDEC JS-001 Class 3B exceeds 8000 V
MM JESD22-A115C Class C exceeds 550 V
CDM ANSI/ESDA/JEDEC JS-002 Class C3 exceeds 2000 V
Multiple package options
Rev. 1.0 – Aug 08, 2024
1
74LVC2G06
2
74LVC2G06
3.Ordering Information
Table 1. Ordering information
Package
Type number
Name
Description
Quantity
74LVC2G06GV
SOT23-6L
SOT23 package, 6 pins
2.92 mm × 1.6 mm; 1.25 mm (Max) height
3000
74LVC2G06GW
SOT363
SOT363 package, 6 pins
2.1 mm × 1.25 mm; 1.1 mm (Max) height
3000
74LVC2G06GS
DFN1x1-6L
DFN1×1 package, 6 pins
1 mm × 1 mm; 0.42 mm (Max) height
3000
74LVC2G06GM
DFN1x1.45-6L
DFN1.45×1 package, 6 pins
1.45 mm × 1 mm; 0.6 mm (Max) height
3000
4.Function Diagram
Fig 1.
Logic symbol
Fig 2.
IEC logic symbol
Fig 3.
Logic diagram(one
inverter)
3
74LVC2G06
5.Pinning Information
5.1. Pin map
Fig 4. Top view pin configuration SOT23-5 and SOT353
Fig 5. Top view pin configuration DFN6L
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1A
1
Data input
GND
2
Ground (0V)
2A
3
Data input
2Y
4
Data output
VCC
5
Supply voltage
1Y
6
Data output
6.Functional Description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state.
Input nA
Output nY
L
Z
H
L
4
74LVC2G06
7.Absolute Maximum Ratings
Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be
operable above the recommended operating conditions and stressing the parts to these levels is not
recommended. In addition, extended exposure to stresses above the recommended operating conditions may
affect device reliability. The absolute maximum ratings are stress ratings only.
Table 4. Absolute Maximum Ratings
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND.
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO
output voltage
IO
output current
ICC
supply current
IGND
ground current
Ptot
total power dissipation
Tstg
storage temperature
Conditions
VI < 0 V
Max
Unit
-0.5
6.5
V
-50
[1]
VO < 0 V
-0.5
mA
6.5
-50
Active
[1]
Power-down
[1]
Min
mode
mode;
VCC
V
V
mA
-0.5
6.5
V
-0.5
6.5
V
50
mA
100
mA
VO = 0 V to 6.5V
-100
Tamb = -40 °C to + 125 °C
-65
mA
250
mW
150
°C
[1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
5
74LVC1G06
Inverter with open-drain output
8.Recommended Operating Conditions
The Recommended Operating Conditions table defines the conditions for actual device operation.
Recommended operating conditions are specified to ensure optimal performance to the datasheet
specifications. MDD does not recommend exceeding them or designing to Absolute Maximum Ratings.
Table 5. Recommended Operating Conditions
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Δt/ΔV
Input transition rise and
fall rate
Conditions
Min
Typ
Max
Unit
1.65
5.5
V
V
Active mode
V
Power-down mode; VCC = 0 V
V
-40
125
°C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
6
74LVC1G06
9.Static Characteristics
Table 6. Static characteristics
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
VCC = 1.65 V to 1.95 V
VIH
HIGH-level input VCC = 2.3 V to 2.7 V
voltage
VCC = 2.7 V to 3.6 V
VCC = 4.5 V to 5.5 V
-40 °C to +85 °C
Min
Typ[1]
LOW-level input
voltage
Max
Min
Max
Unit
0.65VCC
0.65VCC
V
1.7
1.7
V
2.0
2.0
V
0.7VCC
0.7VCC
V
VIL
-40 °C to +125 °C
0.35VCC
0.35VCC
V
0.7
0.7
V
0.8
0.8
V
0.3VCC
0.3VCC
V
IO = 100μA;
VCC = 1.65 V to 5.5 V
0.10
0.10
V
IO = 4 mA; VCC = 1.65 V
0.45
0.70
V
IO = 8 mA; VCC = 2.3 V
0.30
0.45
V
IO = 12 mA; VCC = 2.7 V
0.40
0.60
V
IO = 24 mA; VCC = 3.0 V
0.55
0.80
V
IO = 32 mA; VCC = 4.5 V
0.55
0.80
V
±0.1
±1
±1
μA
VI = VIH or VIL
VOL
LOW-level
output voltage
VI = 5.5 V or GND ;
VCC = 0 V to 5.5 V
II
Input leakage
current
IOZ
OFF-state output VI = VIH or VIL; VO = VCC or
current
GND; VCC = 5.5 V
±0.1
±2
±2
μA
IOFF
power-off
leakage current
VCC = 0V ; VI or VO = 5.5 V
±0.1
±2
±2
μA
ICC
supply current
VI = 5.5V or GND ; IO = 0A ;
VCC = 1.65V to 5.5V
0.1
4
4
μA
ΔICC
additional supply per pin ; VCC = 2.3V to 5.5V ;
current
VI = VCC -0.6V ; IO = 0A
5
500
500
μA
CI
input
capacitance
5
VCC = 3.3V ; VI = GND to VCC
pF
7
74LVC1G06
[1]All typical values are measured at VCC = 3.3V and Tamb = 25℃.
10. Dynamic Characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 8.
Symbol Parameter
CPD
propagation delay
power dissipation
capacitance
-40 °C to +125 °C
Unit
Min
Typ[1]
Max
Min
Max
2.6
7.4
12.6
2.6
12.9
ns
1.7
3.9
6.6
1.7
7.0
ns
VCC = 3.0 V to 3.6 V
1.4
2.5
4.0
1.4
4.2
ns
1.2
2.0
2.9
1.2
3.0
ns
A to Y; see Fig. 7
tpd
-40 °C to +85 °C
Conditions
[2]
VI = GND to VCC ; VCC = 3.3V [3]
3.5
pF
[1] Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 3.3 V and 5.0 V respectively.
[2] tpd is the same as tPLH and tPHL.
[3] CPD is used to determine the dynamic power dissipation (PD in μW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of outputs.
8
74LVC1G06
10.1. Waveforms and test circuit
Measurement points are given in Table 8.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig 6. The input nA to output nY propagation delays
Table 8. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
VX
1.65 V to 1.95 V
0.5VCC
0.5VCC
VOL + 0.15V
2.3 V to 2.7 V
0.5VCC
0.5VCC
VOL + 0.15V
3.0 V to 3.6 V
1.5 V
1.5 V
VOL + 0.3V
4.5 V to 5.5 V
0.5VCC
0.5VCC
VOL + 0.3V
9
74LVC1G06
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig 7. Test circuit for measuring switching times
Table 9. Test data
Supply voltage
Input
VCC
VI
tr = tf
CL
RL
tPZL, tPLZ
1.65 V to 1.95 V
VCC
≤ 2.0 ns
30 pF
1 kΩ
2 x VCC
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
2 x VCC
3.0 V to 3.6 V
3V
≤ 2.5 ns
50 pF
500 Ω
6V
4.5 V to 5.5 V
VCC
≤ 2.5 ns
50 pF
500 Ω
2 x VCC
Load
VEXT
10
74LVC1G06
11. Package Outline
SOT23-6L
11
74LVC1G06
SOT363
12
74LVC1G06
DFN1x1-6L
13
74LVC1G06
DFN1x1.45-6L
14
74LVC1G06
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision History
Table 11. Revision history
Document ID
Release Date
Data sheet status
74LVC2G06 Rev1.0
Oct 30, 2023
Product datasheet
Change notice
Supersedes
15
很抱歉,暂时无法提供与“74LVC2G06GV”相匹配的价格&库存,您可以联系我们找货
