74HCT132D
74HCT132D
    MDD(辰达半导体)
    SOP-14
    通用逻辑门芯片
74HCT132D 数据手册
74HC132; 74HCT132 Quad 2-input NAND Schmitt trigger Product datasheet, Rev. 1.0 Aug 08, 2024 1.General Description The 74HC132; 74HCT132 is a quad 2-input NAND gate with Schmitt-trigger inputs. Schmitt trigger inputs transform slowly changing input signals into sharply defined jitter-free output signals. 2.Features and Benefits  Wide supply voltage range from 2.0 V to 6.0 V  High noise immunity  CMOS low power dissipation  Latch-up performance exceeds 250 mA  Unlimited rise and fall times  Complies with JEDEC standards: • JESD8C (2.7 V to 3.6 V) • JESD7A (2.0 V to 6.0 V)  ESD protection:  • HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 3500 V • CDM ANSI/ESDA/JEDEC JS-002 Class C3 exceeds 2000 V Multiple package options Rev. 1.0 – Aug 08, 2024 1 74HC132; 74HCT132 Quad 2-input NAND Schmitt trigger 3.Ordering Information Table 1. Ordering information Type number 74HC132D 74HCT132D 74HC132PW 74HCT132PW Package Name Description Quantity SOP-14L plastic small outline package; 14 leads; body width 3.9 mm 2500 TSSOP-14L plastic thin shrink small outline package; 14 leads; body width 4.4 mm 2500 4.Function Diagram Fig. 1. Logic symbol Rev. 1.0 – Aug 08, 2024 Fig. 2. IEC logic symbol Fig. 3. Logic diagram for one Schmitt trigger 2 74HC132; 74HCT132 Quad 2-input NAND Schmitt trigger 5.Pinning Information 5.1. Pinning Fig. 4. Top view pin configuration SOP and TSSOP 5.2. Pin description Table 2. Pin description Symbol Pin Description 1A, 2A, 3A, 4A 1, 4, 9, 12 Data input 1B, 2B, 3B, 4B 2, 5, 10, 13 Data input 1Y, 2Y, 3Y, 4Y 3, 6, 8, 11 Data output GND 7 Ground (0V) VCC 14 Supply voltage 6.Functional Description Table 3. Function table H = HIGH voltage level; L = LOW voltage level. Control Output nA nB nY L L H L H H H L H H H L Rev. 1.0 – Aug 08, 2024 3 74HC132; 74HCT132 Quad 2-input NAND Schmitt trigger 7.Absolute Maximum Ratings Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be operable above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. Table 4. Absolute Maximum Ratings In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND. Symbol Parameter Conditions VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V IO output current VO = -0.5 V to (VCC + 0.5 V) ICC supply current IGND ground current Ptot total power dissipation Tstg storage temperature Min Max Unit -0.5 7.0 V [1] ±20 mA [1] ±20 mA ±25 mA 50 mA -50 mA -65 500 mW 150 °C [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. 8.Recommended Operating Conditions The Recommended Operating Conditions table defines the conditions for actual device operation. Recommended operating conditions are specified to ensure optimal performance to the datasheet specifications. MDD does not recommend exceeding them or designing to Absolute Maximum Ratings. Table 5. Recommended Operating Conditions Symbol Parameter VCC Conditions 74HC132 74HCT132 Unit Min Typ Max Min Typ Max supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 VCC 0 VCC V VO output voltage 0 VCC 0 VCC V Tamb ambient temperature -40 125 -40 125 °C 9.Static Characteristics Table 6. Static characteristics Rev. 1.0 – Aug 08, 2024 4 74HC132; 74HCT132 Quad 2-input NAND Schmitt trigger At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Typical values measured at Tamb = 25°C (unless otherwise noted). Symbol Parameter Conditions -40 °C to +85 °C Min Typ Max -40 °C to +125 °C Min Max Unit 74HC132 VI = VT+ or VT- VOH HIGH-level output voltage IO = -20 μA; VCC = 2.0 V 1.9 1.9 V IO = -20 μA; VCC = 4.5 V 4.4 4.4 V IO = -20 μA; VCC = 6.0 V 5.9 5.9 V IO = -4.0 mA; VCC = 4.5 V 3.84 3.7 V IO = -5.2 mA; VCC = 6.0 V 5.34 5.2 V VI = VT+ or VT- VOL II ICC CI LOW-level output voltage input leakage current supply current input capacitance Rev. 1.0 – Aug 08, 2024 IO = 20 μA; VCC = 2.0 V 0.1 0.1 V IO = 20 μA; VCC = 4.5 V 0.1 0.1 V IO = 20 μA; VCC = 6.0 V 0.1 0.1 V IO = 4.0 mA; VCC = 4.5 V 0.33 0.4 V IO = 5.2 mA; VCC = 6.0 V 0.33 0.4 V VI = VCC or GND ; VCC = 6.0 V ±1 ±1 μA VI = VCC or GND ; IO = 0 A ; VCC = 6.0 V 20 40 μA 7 pF 5 74HC132; 74HCT132 Quad 2-input NAND Schmitt trigger Symbol Parameter Conditions -40 °C to +85 °C Min Typ Max -40 °C to +125 °C Min Max Unit 74HCT132 VOH VOL II ICC ΔICC CI HIGH-level output voltage LOW-level output voltage input leakage current supply current additional supply current input capacitance Rev. 1.0 – Aug 08, 2024 VI = VT+ or VT-; VCC = 4.5 V IO = -20 μA; 4.4 4.4 V IO = -4.0 mA; 3.84 3.7 V VI = VT+ or VT-; VCC = 4.5 V IO = 20 μA; 0.1 0.1 V IO = 4.0 mA; 0.33 0.4 V ±1 ±1 μA 20 40 μA 1.55 1.85 mA VI = VCC or GND ; VCC = 5.5 V VI = VCC or GND; IO = 0 A; VCC = 5.5 V per pin ; VI = VCC - 2.1 V; IO = 0 A; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V 10 pF 6 74HC132; 74HCT132 Quad 2-input NAND Schmitt trigger 10. Dynamic Characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 6. Typical values measured at Tamb = 25°C (unless otherwise noted). Symbol Parameter -40 °C to +85 °C Conditions Min Typ -40 °C to +125 °C Max Min Max Unit 74HC132 nA, nB to nY; see Fig. 5 tpd propagation delay VCC = 2.0 V 35 40 ns VCC = 4.5 V 20 25 ns VCC = 6.0 V 15 20 ns VCC = 2.0 V 9 11 ns VCC = 4.5 V 6 8 ns VCC = 6.0 V 4 5 ns see Fig. 5 tt CPD transition time power dissipation capacitance [1] [2] CL = 15 pF; f = 1 MHz; VI = GND to VCC [3] nA, nB to nY; VCC = 4.5 V; see Fig. 5 [1] VCC = 4.5 V; see Fig. 5 [2] CL = 15 pF; f = 1 MHz; VI = GND to (VCC -1.5 V) [3] 18 pF 74HCT132 tpd tt CPD propagation delay transition time power dissipation capacitance 37 16 19 ns 6 8 ns pF [1] tpd is the same as tPHL and tPLH. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in μW). PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; Σ(CL × VCC2 × fo) = sum of outputs. Rev. 1.0 – Aug 08, 2024 7 74HC132; 74HCT132 Quad 2-input NAND Schmitt trigger 10.1. Waveforms and test circuit Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 5. The input to output propagation delays Table 8. Measurement points Input Output VM VM VX VY 74HC132 0.5VCC 0.5VCC 0.1VCC 0.9VCC 74HCT132 1.3 V 1.3 V 0.1VCC 0.9VCC Type Rev. 1.0 – Aug 08, 2024 8 74HC132; 74HCT132 Quad 2-input NAND Schmitt trigger Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 6. Test circuit for measuring switching times Table 9. Test data Type Input Load VEXT VI tr = tf CL RL tPLH, tPHL 74HC132 VCC ≤ 2.5 ns 15 pF 500Ω open 74HCT132 3V ≤ 2.5 ns 15 pF 500Ω open Rev. 1.0 – Aug 08, 2024 9 74HC132; 74HCT132 Quad 2-input NAND Schmitt trigger 11. Transfer Characteristics Table 10. Transfer characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Typical values are measured at Tamb = 25C. Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max VCC = 2.0 V 0.7 1.21 1.5 0.7 1.5 V VCC = 4.5 V 1.7 2.39 3.15 1.7 3.15 V VCC = 6.0 V 2.1 3.05 4.2 2.1 4.2 V VCC = 2.0 V 0.3 0.6 0.9 0.3 0.9 V VCC = 4.5 V 0.9 1.41 2.0 0.9 2.0 V VCC = 6.0 V 1.2 1.9 2.6 1.2 2.6 V VCC = 2.0 V 0.2 0.61 1.0 0.2 1.0 V VCC = 4.5 V 0.4 0.97 1.4 0.4 1.4 V VCC = 6.0 V 0.6 1.16 1.6 0.6 1.6 V VCC = 4.5 V 1.2 1.45 1.9 1.2 1.9 V VCC = 5.5 V 1.4 1.6 2.1 1.4 2.1 V VCC = 4.5 V 0.5 0.88 1.2 0.5 1.2 V VCC = 5.5 V 0.6 1.05 1.4 0.6 1.4 V VCC = 4.5 V 0.4 0.57 0.4 V VCC = 5.5 V 0.4 0.55 0.4 V 74HC132 VT+ VT- positivegoing threshold voltage negativegoing threshold voltage see Fig. 7 and Fig. 8 see Fig. 7 and Fig. 8 see Fig. 7 and Fig. 8 VH hysteresis voltage 74HCT132 VT+ VT- VH positivegoing threshold voltage see Fig. 7 and Fig. 8 negativegoing threshold voltage see Fig. 7 and Fig. 8 hysteresis voltage Rev. 1.0 – Aug 08, 2024 see Fig. 7 and Fig. 8 10 74HC132; 74HCT132 Quad 2-input NAND Schmitt trigger 11.1. Waveforms transfer characteristics VT+ and VT- limits at 70% and 20%. Fig. 7. Transfer characteristic Rev. 1.0 – Aug 08, 2024 Fig. 8. Definition of VT+, VT- and VH 11 74HC132; 74HCT132 Quad 2-input NAND Schmitt trigger 12. Package Outline SOP-14L Rev. 1.0 – Aug 08, 2024 12 74HC132; 74HCT132 Quad 2-input NAND Schmitt trigger TSSOP-14L Rev. 1.0 – Aug 08, 2024 13 74HC132; 74HCT132 Quad 2-input NAND Schmitt trigger 13. Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model CDM Charged Device Model TTL Transistor-Transistor Logic 14. Revision History Table 12. Revision history Document ID Release Date Data sheet status 74HC_HCT132 Rev. 1.0 Mar 28, 2024 Product datasheet Rev. 1.0 – Aug 08, 2024 Change notice Supersedes 14
74HCT132D 价格&库存
很抱歉,暂时无法提供与“74HCT132D”相匹配的价格&库存,您可以联系我们找货
