74HCT259D
74HCT259D
    MDD(辰达半导体)
    SOP-16
    通用逻辑门芯片
74HCT259D 数据手册
74HC259; 74HCT259 8-bit addressable latch Product datasheet, Rev. 1.0 Aug 08, 2024 1.General Description The 74HC259; 74HCT259 is an 8-bit addressable latch. The device features four modes of operation. In the addressable latch mode, data on the D input is written into the latch addressed by the inputs A0 to A3. The addressed latch will follow the data input, non-addressed latches will retain their previous states. In memory mode, all latches retain their previous states and are unaffected by the data or address inputs. In the 3-to-8 decoding or demultiplexing mode, the addressed output follows the D input and all other outputs are LOW. In the reset mode, all outputs are forced LOW and unaffected by the data or address inputs. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2.Features and Benefits  Wide supply voltage range from 2.0 V to 6.0 V  Latch-up performance exceeds 250 mA  Complies with JEDEC standards: • JESD8C (2.7 V to 3.6 V) • JESD7A (2.0 V to 6.0 V)  Combined demultiplexer and 8-bit latch  Serial-to-parallel capability  Output from each storage bit available  Random (addressable) data entry  Easily expandable  Common reset input  Useful as a 3-to-8 active HIGH decoder  Input levels: • For 74HC259: CMOS level • For 74HCT259: TTL level Rev. 1.0 – Aug 08, 2024 74HC259; 74HCT259 8-bit addressable latch Product datasheet, Rev. 1.0 Aug 08, 2024  ESD protection: • HBM: ANSI/ESDA/JEDEC JS-001 class 2 exceeds 3500 V • CDM: ANSI/ESDA/JEDEC JS-002 class C3 exceeds 2000 V  Multiple package options  Specified from -40 °C to +85 °C and from -40 °C to +125 °C 3.Ordering Information Table 1. Ordering information Type number 74HC259D 74HCT259D 74HC259PW 74HCT259PW Rev. 1.0 – Aug 08, 2024 Package Name Description Quantity SOP-16L plastic small outline package; 16 leads; body width 3.9 mm 2500 TSSOP-16L plastic thin shrink small outline package; 16 leads; body width 4.4 mm 2500 74HC259; 74HCT259 8-bit addressable latch 4.Function Diagram Fig. 1. Logic symbol Fig. 2. IEC logic symbol Fig. 3. Functional diagram Rev. 1.0 – Aug 08, 2024 74HC259; 74HCT259 8-bit addressable latch 5.Pinning Information 5.1. Pinning Fig. 4. Top view pin configuration SOP and TSSOP 5.2. Pin description Table 2. Pin description Symbol Pin Description A0, A1, A2 1, 2, 3 Address input Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7 4, 5, 6, 7, 9, 10, 11, 12 Latch output GND 8 Ground (0 V) D 13 Data input LE 14 Latch enable input (active LOW) MR 15 Conditional reset input (active LOW) VCC 16 Supply voltage Rev. 1.0 – Aug 08, 2024 74HC259; 74HCT259 8-bit addressable latch 6.Functional Description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; d = HIGH or LOW data one set-up time prior to the LOW-to-HIGH LE transition; q = lower case letter indicates the state of the referenced input one set-up time prior to the LOW-toHIGH transition. Operating mode Reset(clear) Demultiplexer (active HIGH 8-channel) decoder (when D = H) Memory (no action) Addressable latch Input MR L L L L L L L L L A2 X L L L L H H H H Output Q0 Q1 L L Q=d L L Q=d L L L L L L L L L L L L LE H L L L L L L L L D X d d d d d d d d A0 X L H L H L H L H A1 X L L H H L L H H Q2 L L L Q=d L L L L L Q3 L L L L Q=d L L L L Q4 L L L L L Q=d L L L Q5 L L L L L L Q=d L L Q6 L L L L L L L Q=d L Q7 L L L L L L L L Q=d H H X X X X q0 q1 q2 q3 q4 q5 q6 q7 H H H H H H H H L L L L L L L L d d d d d d d d L H L H L H L H L L H H L L H H L L L L H H H H Q=d q0 q0 q0 q0 q0 q0 q0 q1 Q=d q1 q1 q1 q1 q1 q1 q2 q2 Q=d q2 q2 q2 q2 q2 q3 q3 q3 Q=d q3 q3 q3 q3 q4 q4 q4 q4 Q=d q4 q4 q4 q5 q5 q5 q5 q5 Q=d q5 q5 q6 q6 q6 q6 q6 q6 Q=d q6 q7 q7 q7 q7 q7 q7 q7 Q=d Table 4. Operating mode select table H = HIGH voltage level; L = LOW voltage level. LE L H L H Rev. 1.0 – Aug 08, 2024 MR H H L L Mode Addressable latch mode Memory mode Demultiplexer mode Reset mode 74HC259; 74HCT259 8-bit addressable latch 7.Absolute Maximum Ratings Stresses exceeding the absolut`e maximum ratings may damage the device. The device may not function or be operable above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. Table 4. Absolute Maximum Ratings In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND. Symbol Parameter VCC supply voltage IIK input clamping current IOK Conditions Min Max Unit -0.5 7 V VI < -0.5 V or VI > VCC + 0.5 V ±20 mA output clamping current VO < -0.5 V or VO > VCC + 0.5 V ±20 mA IO output current VO = -0.5 V to (VCC + 0.5 V) ±25 mA ICC supply current 70 mA IGND ground current Ptot total power dissipation Tstg storage temperature -70 mA Tamb = -40 °C to + 125 °C -65 500 mW 150 °C [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. 8.Recommended Operating Conditions The Recommended Operating Conditions table defines the conditions for actual device operation. Recommended operating conditions are specified to ensure optimal performance to the datasheet specifications. MDD does not recommend exceeding them or designing to Absolute Maximum Ratings. Table 5. Recommended Operating Conditions Symbol Parameter VCC Conditions 74HC259 74HCT259 Unit Min Typ Max Min Typ Max supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 VCC 0 VCC V VO output voltage 0 VCC 0 VCC V Tamb ambient temperature 125 -40 125 °C Δt/ΔV Input transition rise and fall rate Rev. 1.0 – Aug 08, 2024 -40 25 VCC = 2.0 V VCC = 4.5 V VCC = 6.0 V 25 625 1.67 139 83 ns/V 1.67 139 ns/V ns/V 74HC259; 74HCT259 8-bit addressable latch 9.Static Characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions -40 °C to +85 °C Min Typ -40 °C to +125 °C Max Min Max Unit 74HC259 VIH VIL HIGH-level input voltage LOW-level input voltage VCC = 2.0 V 1.5 1.5 V VCC = 4.5 V 3.15 3.15 V VCC = 6.0 V 4.2 4.2 V VCC = 2.0 V 0.5 0.5 V VCC = 4.5 V 1.35 1.35 V VCC = 6.0 V 1.8 1.8 V VI = VIH or VIL VOH HIGH-level output voltage IO = -20 μA; VCC = 2.0 V 1.9 1.9 V IO = -20 μA; VCC = 4.5 V 4.4 4.4 V IO = -20 μA; VCC = 6.0 V 5.9 5.9 V IO = -4.0 mA; VCC = 4.5 V 3.84 3.7 V IO = -5.2 mA; VCC = 6.0 V 5.34 5.2 V VI = VIH or VIL VOL LOW-level output voltage IO = 20 μA; VCC = 2.0 V 0.1 0.1 V IO = 20 μA; VCC = 4.5 V 0.1 0.1 V IO = 20 μA; VCC = 6.0 V 0.1 0.1 V IO = 4.0 mA; VCC = 4.5 V 0.33 0.4 V IO = 5.2 mA; VCC = 6.0 V 0.33 0.4 V II input leakage current VI = VCC or GND ; VCC = 6.0 V ±1 ±1 μA ICC supply current VI = VCC or GND ; IO = 0 A; VCC = 6.0 V 20 40 μA CI input capacitance Rev. 1.0 – Aug 08, 2024 6.5 pF 74HC259; 74HCT259 8-bit addressable latch Symbol Parameter Conditions -40 °C to +85 °C Min Typ -40 °C to +125 °C Max Min Max Unit 74HCT259 VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VOL LOW-level output voltage II input leakage current ICC supply current ΔICC additional supply current CI input capacitance Rev. 1.0 – Aug 08, 2024 VCC = 4.5 V to 5.5 V 2.0 2.0 VCC = 4.5 V to 5.5 V 0.8 V 0.8 V VI = VIH or VIL; VCC = 4.5 V IO = -20 μA 4.4 4.4 V IO = -4.0 mA 3.84 3.7 V VI = VIH or VIL; VCC = 4.5 V IO = 20 μA 0.1 0.1 V IO = 4.0 mA 0.33 0.4 V ±1 ±1 μA 20 40 μA 450 490 μA VI = VCC or GND ; VCC = 5.5 V VI = VCC or GND ; IO = 0 A; VCC = 5.5 V VI = VCC - 2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A 6.5 pF 74HC259; 74HCT259 8-bit addressable latch 10. Dynamic Characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 11. Symbol Parameter -40 °C to +85 °C Conditions Min Typ[1] -40 °C to +125 °C Max Min Max Unit 74HC259 D to Qn; see Fig. 5 VCC = 2.0 V 55 60 ns VCC = 4.5 V 17 20 ns VCC = 6.0 V 13 15 ns VCC = 2.0 V 55 60 ns VCC = 4.5 V 17 20 ns VCC = 6.0 V 13 15 ns VCC = 2.0 V 55 60 ns VCC = 4.5 V 17 20 ns VCC = 6.0 V 13 15 ns VCC = 2.0 V 55 60 ns VCC = 4.5 V 17 20 ns VCC = 6.0 V 13 15 ns VCC = 2.0 V 8 10 ns VCC = 4.5 V 7 9 ns VCC = 6.0 V 7 9 ns An [2] tpd propagation delay LE [2] tPHL HIGH to LOW propagation delay to to transition time Rev. 1.0 – Aug 08, 2024 Qn; Qn; see see Fig. Fig. 6 7 MR to Qn; see Fig. 8 see Fig. 7 tt [2] [3] 74HC259; 74HCT259 8-bit addressable latch Symbol Parameter -40 °C to +125 °C -40 °C to +85 °C Conditions Min Typ[1] Max Min Max Unit LE HIGH or LOW; see Fig. 7 tW pulse width VCC = 2.0 V 100 120 ns VCC = 4.5 V 20 24 ns VCC = 6.0 V 17 20 ns VCC = 2.0 V 75 90 ns VCC = 4.5 V 15 18 ns VCC = 6.0 V 13 15 ns VCC = 2.0 V 75 90 ns VCC = 4.5 V 15 18 ns VCC = 6.0 V 13 15 ns VCC = 2.0 V 5 5 ns VCC = 4.5 V 5 5 ns VCC = 6.0 V 5 5 ns VCC = 2.0 V 5 5 ns VCC = 4.5 V 5 5 ns VCC = 6.0 V 5 5 ns MR LOW; see Fig. 8 D, An to LE; see Fig. 9 and Fig. 10 tSU set-up time D to LE; see Fig. 9 and Fig. 10 th CPD hold time power dissipation capacitance An to LE; see Fig. 9 and Fig. 10 f = 1 MHz; VI = GND to VCC [4] 26 pF 74HCT259 D to Qn; see Fig. 5 [2] VCC = 4.5 V tpd propagation delay An to Qn; see Fig. 6 VCC = 4.5 V Rev. 1.0 – Aug 08, 2024 20 ns 17 20 ns 17 20 ns [2] VCC = 4.5 V LE to Qn; see Fig. 7 17 [2] 74HC259; 74HCT259 8-bit addressable latch Symbol Parameter Conditions MR to Qn; see Fig. 8 tPHL HIGH to LOW propagation delay tt transition time see Fig. 7 -40 °C to +85 °C Min Typ VCC = 4.5 V -40 °C to +125 °C Max Min Max Unit 17 20 ns 7 9 ns [3] VCC = 4.5 V LE HIGH or LOW; see Fig. 7 tW pulse width VCC = 4.5 V set-up time 24 ns 31 38 ns 15 18 ns 5 5 ns 5 5 ns MR LOW; see Fig. 8 VCC = 4.5 V tsu 20 D, An to LE; see Fig. 9 and Fig. 10 VCC = 4.5 V D to LE; see Fig. 9 and Fig. 10 th hold time VCC = 4.5 V An to LE; see Fig. 9 and Fig. 10 VCC = 4.5 V CPD power dissipation capacitance f = 1 MHz; VI = GND to VCC - 1.5 V [4] [1] Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V). [2] tpd is the same as tPLH and tPHL. [3] tt is the same as tTHL and tTLH. [4] CPD is used to determine the dynamic power dissipation (PD in μW). PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; Σ(CL × VCC2 × fo) = sum of outputs. Rev. 1.0 – Aug 08, 2024 28 pF 74HC259; 74HCT259 8-bit addressable latch 10.1. Waveforms and test circuit Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 5. Data input to output propagation delays Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 6. Address input to output propagation delays Rev. 1.0 – Aug 08, 2024 74HC259; 74HCT259 8-bit addressable latch Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 7. Enable input to output propagation delays and pulse width Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 8. Master reset input to output propagation delays Rev. 1.0 – Aug 08, 2024 74HC259; 74HCT259 8-bit addressable latch Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 9. Data input to latch enable input set-up and hold times Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 10. Address input to latch enable input set-up and hold times Rev. 1.0 – Aug 08, 2024 74HC259; 74HCT259 8-bit addressable latch Table 8. Measurement points Input Output VM VM VX VY 74HC259 0.5VCC 0.5VCC 0.1VCC 0.9 VCC 74HCT259 1.3 V 1.3 V 0.1 VCC 0.9 VCC Type Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 11. Test circuit for measuring switching times Table 9. Test data Type Input Load VEXT VI tr = tf CL RL tPLH, tPHL 74HC259 VCC 2.0 ns 50 pF 500 Ω open 74HCT259 3V 2.0 ns 50 pF 500 Ω open Rev. 1.0 – Aug 08, 2024 74HC259; 74HCT259 8-bit addressable latch 11. Package Outline SOP-16L Rev. 1.0 – Aug 08, 2024 74HC259; 74HCT259 8-bit addressable latch TSSOP-16L Rev. 1.0 – Aug 08, 2024 74HC259; 74HCT259 8-bit addressable latch 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model CDM Charged Device Model TTL Transistor-Transistor Logic 13. Revision History Table 11. Revision history Document ID Release Date Data sheet status 74HC_HCT259 Rev. 1.0 Apr 28, 2025 Product datasheet Rev. 1.0 – Aug 08, 2024 Change notice Supersedes
74HCT259D 价格&库存
很抱歉,暂时无法提供与“74HCT259D”相匹配的价格&库存,您可以联系我们找货
