74HCT574PW
74HCT574PW
    MDD(辰达半导体)
    TSSOP-20
    通用逻辑门芯片
74HCT574PW 数据手册
74HC574; 74HCT574 Octal D-type flip-flop; positive edge-trigger; 3-state Draft datasheet, Rev. 1.0 Aug 08, 2024 1.General Description The 74HC574 and 74HCT574 are 8-bit D-type transparent latches with 3-state outputs. The device features a clock (CP) and output enable (OE) inputs. The flip-flops will store the state of their individual D-inputs that meet the set-up and hold time requirements on the LOW-to-HIGH clock (CP) transition. A HIGH on OE causes the outputs to assume a high-impedance OFF-state. Operation of the OE input does not affect the state of the flip-flops. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2.Features and Benefits  Wide operating voltage 2.7 V to 6.0 V  High noise immunity  CMOS low power dissipation  Latch-up performance exceeds 250 mA  Input levels: • For 74HC574: CMOS level • For 74HCT574: TTL level  Inputs and outputs on opposite sides of package allowing easy interface with microprocessors  Useful as input or output port for microprocessors and microcomputers  3-state non-inverting outputs for bus-oriented applications  Common 3-state output enable input  Complies with JEDEC standards: • JESD8C (2.7 V to 3.6 V) • JESD7A (2.7 V to 6.0 V)  ESD protection: • HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 3500 V • CDM ANSI/ESDA/JEDEC JS-002 Class C3 exceeds 2000 V  Multiple package options  Specified from -40 °C to +85 °C and from -40 °C to +125 °C Rev. 1.0 – Aug 08, 2024 1 74HC574; 74HCT574 Octal D-type flip-flop; positive edge-trigger; 3-state 3.Ordering Information Table 1. Ordering information Type number 74HC574D 74HCT574D 74HC574PW 74HCT574PW Package Name Description Quantity SOP-20L plastic small outline package; 20 leads; body width 7.5 mm 2000 TSSOP-20L plastic thin shrink small outline package; 20 leads; body width 4.4 mm 2000 4.Function Diagram Fig. 1. Functional diagram Rev. 1.0 – Aug 08, 2024 2 74HC574; 74HCT574 Octal D-type flip-flop; positive edge-trigger; 3-state Fig. 2. Logic diagram Fig. 3. Logic symbol Rev. 1.0 – Aug 08, 2024 Fig. 4. IEC logic symbol 3 74HC574; 74HCT574 Octal D-type flip-flop; positive edge-trigger; 3-state 5.Pinning Information 5.1. Pinning Fig. 5. Top view pin configuration SOP-20L and TSSOP-20L 5.2. Pin description Table 2. Pin description Symbol Pin Description OE 1 3-state output enable input (active LOW) Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7 19,18,17,16,15,14,13,12 3-state flip-flop outputs D0, D1, D2, D3, D4, D5, D6, D7 2, 3, 4, 5, 6, 7, 8, 9 data inputs GND 10 ground (0 V) CP 11 clock input (LOW-to-HIGH, edge triggered) VCC 20 supply voltage Rev. 1.0 – Aug 08, 2024 4 74HC574; 74HCT574 Octal D-type flip-flop; positive edge-trigger; 3-state 6.Functional Description Table 3. Function table H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition; L = LOW voltage level; l = LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition; Z = high-impedance OFF-state; ↑ = LOW-to-HIGH clock transition. Operating modes Load and read register Load register and disable output Rev. 1.0 – Aug 08, 2024 Input Outputs OE CP Dn Internal flip-flop L ↑ I L L L ↑ h H H H ↑ l L Z H ↑ h H Z Qn 5 74HC574; 74HCT574 Octal D-type flip-flop; positive edge-trigger; 3-state 7.Absolute Maximum Ratings Stresses exceeding the absolut`e maximum ratings may damage the device. The device may not function or be operable above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. Table 5. Absolute Maximum Ratings In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND. Symbol Parameter VCC supply voltage IIK input clamping current IOK Conditions Min Max Unit -0.5 7 V VI < -0.5 V or VI > VCC + 0.5 V ±20 mA output clamping current VO < -0.5 V or VO > VCC + 0.5 V ±20 mA IO output current -0.5V < VO < VCC + 0.5 V ±35 mA ICC supply current 70 mA IGND ground current Ptot total power dissipation Tstg storage temperature -70 mA Tamb = -40 °C to + 125 °C -65 500 mW +150 °C 8.Recommended Operating Conditions The Recommended Operating Conditions table defines the conditions for actual device operation. Recommended operating conditions are specified to ensure optimal performance to the datasheet specifications. MDD does not recommend exceeding them or designing to Absolute Maximum Ratings. Table 6. Recommended Operating Conditions Symbol Parameter VCC Conditions 74HC574 74HCT574 Unit Min Min Typ Min Min Typ supply voltage 2.7 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 VCC 0 VCC V VO output voltage 0 VCC 0 VCC V Tamb ambient temperature +125 -40 +125 °C △t/△V input transition rise and fall rate Rev. 1.0 – Aug 08, 2024 -40 +25 VCC = 2.0 V VCC = 4.5 V VCC = 6.0 V +25 625 1.67 139 83 ns/V 1.67 139 ns/V ns/V 6 74HC574; 74HCT574 Octal D-type flip-flop; positive edge-trigger; 3-state 9.Static Characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions -40 °C to +85 °C Min Typ[1] -40 °C to +125 °C Max Min Max Unit 74HC574 VIH VIL HIGH-level input voltage LOW-level input voltage VCC = 3.0 V 2.0 2.0 V VCC = 4.5 V 3.15 3.15 V VCC = 6.0 V 4.2 4.2 V VCC = 3.0 V 0.6 0.6 V VCC = 4.5 V 1.35 1.35 V VCC = 6.0 V 1.8 1.8 V VI = VIH or VIL VOH HIGH-level output voltage IO = -20μA; VCC = 3.0 V 2.9 2.9 V IO = -20μA; VCC = 4.5 V 4.4 4.4 V IO = -20μA; VCC = 6.0 V 5.9 5.9 V IO = -6.0 mA; VCC = 4.5 V 3.84 3.7 V IO = -7.8 mA; VCC = 6.0 V 5.34 5.2 V VI = VIH or VIL VOL II IOZ ICC CI LOW-level output voltage input leakage current OFF-state output current supply current input capacitance Rev. 1.0 – Aug 08, 2024 IO = 20μA; VCC = 3.0 V 0.1 0.1 V IO = 20μA; VCC = 4.5 V 0.1 0.1 V IO = 20μA; VCC = 6.0 V 0.1 0.1 V IO = 6.0 mA; VCC = 4.5 V 0.33 0.4 V IO = 7.8 mA; VCC = 6.0 V 0.33 0.4 V VI = VCC or GND ; VCC = 6.0 V ±1 ±1 μA VI = VIH or VIL ; VCC = 6.0V ; VO = VCC or GND ±5 ±10 μA VI = VCC or GND ; IO = 0A ; VCC = 6.0 V 20 40 μA 6.5 pF 7 74HC574; 74HCT574 Octal D-type flip-flop; positive edge-trigger; 3-state Symbol 74HCT574 VIH VIL VOH VOL II IOZ Parameter HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage input leakage current OFF-state output current ICC supply current ΔICC additional supply current CI input capacitance Conditions VCC = 4.5 V to 5.5 V -40 °C to +85 °C Min Typ[1] -40 °C to +125 °C Max 2.0 Min Max 2.0 VCC = 4.5 V to 5.5 V 0.8 Unit V 0.8 V VI = VIH or VIL; VCC = 4.5 V IO = -20μA 4.4 4.4 V IO = -6.0 mA 3.84 3.7 V VI = VIH or VIL; VCC = 4.5 V IO = 20μA 0.1 0.1 V IO = 6.0 mA 0.33 0.4 V VI = VCC or GND ; VCC = 5.5 V ±1 ±1 μA VI = VIH or VIL ; VCC = 5.5 V ; VO = VCC or GND ±5 ±10 μA 20 40 μA 450 490 μA VI = VCC or GND ; IO = 0 A ; VCC = 5.5 V per pin ; VI = VCC – 2.1 V ; IO = 0 A ; other inputs at VCC or GND ; VCC = 4.5 V to 5.5 V 6.5 pF [1]All typical values are measured at Tamb = 25°C. Rev. 1.0 – Aug 08, 2024 8 74HC574; 74HCT574 Octal D-type flip-flop; positive edge-trigger; 3-state 10. Dynamic Characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 9. Symbol Parameter -40 °C to +85 °C Conditions Min Typ[1] -40 °C to +125 °C Max Min Max Unit 74HC574 CP to Qn; see Fig. 6 tpd propagation delay VCC = 3.0 V 30 35 ns VCC = 4.5 V 20 25 ns VCC = 6.0 V 15 18 ns VCC = 3.0 V 22 25 ns VCC = 4.5 V 14 17 ns VCC = 6.0 V 13 16 ns VCC = 3.0 V 22 25 ns VCC = 4.5 V 15 18 ns VCC = 6.0 V 13 15 ns VCC = 3.0 V 8 10 ns VCC = 4.5 V 7 9 ns VCC = 6.0 V 7 9 ns OE to Qn; see Fig. 8 ten enable time [2] [3] OE to Qn; see Fig. 8 tdis disable time [4] Qn; see Fig. 6 tt transition time CP HIGH or LOW; see Fig. 7 tW pulse width VCC = 3.0 V 25 30 ns VCC = 4.5 V 20 24 ns VCC = 6.0 V 17 20 ns VCC = 3.0 V 16 20 ns VCC = 4.5 V 15 18 ns VCC = 6.0 V 13 15 ns VCC = 3.0 V 5 5 ns VCC = 4.5 V 5 5 ns VCC = 6.0 V 5 5 ns Dn to CP; see Fig.7 tSU set up time Dn to CP; see Fig.7 th hold time Rev. 1.0 – Aug 08, 2024 9 74HC574; 74HCT574 Octal D-type flip-flop; positive edge-trigger; 3-state Symbol Parameter -40 °C to +85 °C Conditions Min Typ[1] -40 °C to +125 °C Unit Max CP; see Fig. 6 fmax CPD maximum frequency power dissipation capacitance VCC = 3.0 V 20 16 MHz VCC = 4.5 V 24 20 MHz VCC = 6.0 V 28 24 MHz fi = 1 MHz; VI = GND to VCC ; [6] [2] 30 pF 74HCT574 tpd propagation delay CP to Qn; see Fig. 6 tt transition time Qn; see Fig. 6 ten enable time tdis disable time tW pulse width tSU set up time th hold time fmax maximum frequency CPD power dissipation capacitance VCC = 4.5 V 7 9 ns 20 25 ns 20 25 ns [4] VCC = 4.5 V CP HIGH or LOW; see Fig. 7 VCC = 4.5 V 20 24 ns 15 18 ns 5 5 ns 24 20 ns Dn to CP; see Fig.7 VCC = 4.5 V Dn to CP; see Fig.7 VCC = 4.5 V CP; see Fig.6 VCC = 4.5 V fi = 1 MHz; VI = GND to VCC – 1.5 V ; [6] [1] Typical values are measured at Tamb = 25 °C. [2] tpd is the same as tPLH and tPHL. [3] ten is the same as tPZL and tPZH. [4] tdis is the same as tPLZ and tPHZ. [5] tt is the same as tTHL and tTLH. [6] CPD is used to determine the dynamic power dissipation (PD in μW). PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; Σ(CL × VCC2 × fo) = sum of outputs. Rev. 1.0 – Aug 08, 2024 10 ns [3] VCC = 4.5 V OE to Qn; see Fig. 8 30 [5] VCC = 4.5 V OE to Qn; see Fig. 8 25 30 pF 74HC574; 74HCT574 Octal D-type flip-flop; positive edge-trigger; 3-state 10.1. Waveforms and test circuit Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 6. Propagation delay input (CP) to output (Qn), output transition time, clock input (CP) pulse width and the maximum frequency (CP) Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 7. The data input (D) to clock input (CP) set-up times and clock input (CP) to data input (D) hold times Rev. 1.0 – Aug 08, 2024 11 74HC574; 74HCT574 Octal D-type flip-flop; positive edge-trigger; 3-state Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 8. Enable and disable times Table 8. Measurement points Input Output VM VM VX VY 74HC574 0.5VCC 0.5VCC 0.1VCC 0.9VCC 74HCT574 1.3 V 1.3 V 0.1VCC 0.9VCC Type Rev. 1.0 – Aug 08, 2024 12 74HC574; 74HCT574 Octal D-type flip-flop; positive edge-trigger; 3-state Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 9. Test circuit for measuring switching times Table 9. Test data Type Input Load VEXT VI tr = tf CL RL tPZL, tPLZ tPHL, tPLH tPZH, tPHZ 74HC574 VCC 2.5 ns 50 pF 500Ω VCC Open GND 74HCT574 3V 2.5 ns 50 pF 500Ω VCC Open GND Rev. 1.0 – Aug 08, 2024 13 74HC574; 74HCT574 Octal D-type flip-flop; positive edge-trigger; 3-state Rev. 1.0 – Aug 08, 2024 14 74HC574; 74HCT574 Octal D-type flip-flop; positive edge-trigger; 3-state 11. Package Outline SOP-20L Symbol A A1 A2 A3 B B1 C C1 C2 C3 Dimensions In Millimeters Min. Max. 12.600 12.900 0.381 0.431 1.240 1.300 0.450 0.460 7.400 7.600 10.206 10.406 2.150 2.300 0.938 1.038 0.938 1.2038 0.145 0.205 Rev. 1.0 – Aug 08, 2024 15 Symbol C4 D D1 D2 R1 R2 θ1 θ2 θ3 Dimensions In Millimeters Min. Max. 0.246 0.262 1.353 1.453 0.764 0.964 0.18TYP 0.30TYP 0.20TYP 12° TYP 12° TYP 0° ~ 8° 74HC574; 74HCT574 Octal D-type flip-flop; positive edge-trigger; 3-state TSSOP-20L Symbol A A1 A2 A3 b b1 c c1 D E1 Dimensions In Millimeters Min. Max. 1.20 0.05 0.15 0.80 1.05 0.39 0.49 0.20 0.28 0.19 0.25 0.13 0.17 0.12 0.14 6.40 6.60 4.30 4.50 Rev. 1.0 – Aug 08, 2024 16 Symbol E e L L1 θ Dimensions In Millimeters Min. Max. 6.20 6.60 0.65BSC 0.45 0.75 1.00REF 0° 8° 74HC574; 74HCT574 Octal D-type flip-flop; positive edge-trigger; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model CDM Charged Device Model TTL Transistor-Transistor Logic 13. Revision History Table 11. Revision history Document ID Release Date Data sheet status 74HC_HCT574 Rev. 1.0 Apr 24, 2025 Draft datasheet Rev. 1.0 – Aug 08, 2024 17 Change notice Supersedes
74HCT574PW 价格&库存
很抱歉,暂时无法提供与“74HCT574PW”相匹配的价格&库存,您可以联系我们找货
