74AHC1G17GW
74AHC1G17GW
    MDD(辰达半导体)
    SOT-353
    通用逻辑门芯片
74AHC1G17GW 数据手册
74LVC1G17 Single Schmitt trigger buffer Product datasheet, Rev1.0 Aug 08, 2024 1.General Description The 74LVC1G17 is a single buffer Schmitt-trigger. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these devices as translators in mixed 3.3 V and 5 V environments. This device is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. 2.Features and Benefits  Wide supply voltage range from 1.65 V to 5.5 V  Overvoltage tolerant inputs to 5.5 V  High noise immunity  ±24 mA output drive (VCC = 3.0 V)  CMOS low power dissipation  Latch-up performance exceeds 100 mA  Direct interface with TTL levels  IOFF circuitry provides partial Power-down mode operation  Unlimited rise and fall times  Complies with JEDEC standard: • JESD8-7 (1.65 V to 1.95 V) • JESD8-5 (2.3 V to 2.7 V) • JESD8B/JESD36 (2.7 V to 3.6 V)  ESD protection: • HBM ANSI/ESDA/JEDEC JS-001 Class 3B exceeds 8000 V • MM JESD22-A115C Class C exceeds 550 V • CDM ANSI/ESDA/JEDEC JS-002 Class C3 exceeds 2000 V  Multiple package options Rev. 1.0 – Aug 08, 2024 1 74LVC1G17 Single Schmitt trigger buffer 3.Ordering Information Table 1. Ordering information Package Type number Name Description Quantity 74LVC1G17GV SOT23-5L SOT23 package, 5 pins 2.92 mm × 1.6 mm; 1.25 mm (Max) height 3000 74LVC1G17GW SOT353 SOT353 package, 5 pins 2.1 mm × 1.25 mm; 1.1 mm (Max) height 3000 74LVC1G17GS DFN1x1-6L DFN1×1 package, 6 pins 1 mm × 1 mm; 0.42 mm (Max) height 3000 74LVC1G17GM DFN1x1.456L DFN1.45×1 package, 6 pins 1.45 mm × 1 mm; 0.6 mm (Max) height 3000 74LVC1G17GX DFN0.8x0.84L DFN0.8×0.8 package, 5pins 0.8 mm × 0.8 mm; 0.4 mm (Max) height 3000 74LVC1G17YZV DFN-4L DFN package, 4pins 0.888 mm × 0.888 mm; 0.4 mm (Max) height 3000 4.Function Diagram Fig 1. Logic symbol Rev. 1.0 – Aug 08, 2024 Fig 2. IEC logic symbol Fig 3. Logic diagram 2 74LVC1G17 Single Schmitt trigger buffer 5.Pinning Information 5.1. Pin map Fig 4. Top view pin configuration SOT23-5 and SOT353 Fig 5. Top view pin configuration DFN6L Fig 6. Top view pin configuration DFN0.8x0.8-4L Fig 7. Top view pin configuration DFN-4L 5.2. Pin description Table 2. Pin description Pin Symbol SOT23-5, SOT353 and DFN0.8x0.8-4L DFN-6L DFN-4L NC 1 1, 5 - Not connected A 2 2 1 Data input GND 3 3 2 Ground (0V) Y 4 4 3 Data output VCC 5 6 4 Supply voltage Rev. 1.0 – Aug 08, 2024 Description 3 74LVC1G17 Single Schmitt trigger buffer 6.Functional Description Table 3. Function table H = HIGH voltage level; L = LOW voltage level. Input Output A Y L L H H 7.Absolute Maximum Ratings Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be operable above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. Table 4. Absolute Maximum Ratings In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND. Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO output voltage IO output current ICC supply current IGND ground current Ptot total power dissipation Tstg storage temperature Conditions VI < 0 V Min Max Unit -0.5 6.5 V -50 [1] -0.5 6.5 V ±50 mA -0.5 VCC + 0.5 V -0.5 6.5 V ±50 mA 100 mA VO >VCC or VO < 0 V Active [1] Power-down [1] mode mode; VCC = 0 V mA VO = 0 V to VCC -100 Tamb = -40 °C to + 125 °C -65 mA 250 mW 150 °C [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. Rev. 1.0 – Aug 08, 2024 4 74LVC1G17 Single Schmitt trigger buffer 8.Recommended Operating Conditions The Recommended Operating Conditions table defines the conditions for actual device operation. Recommended operating conditions are specified to ensure optimal performance to the datasheet specifications. MDD does not recommend exceeding them or designing to Absolute Maximum Ratings. Table 5. Recommended Operating Conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature Rev. 1.0 – Aug 08, 2024 Conditions Min Typ Max Unit 1.65 5.5 V 0 5.5 V Active mode 0 VCC V Power-down mode; VCC = 0 V 0 5.5 V -40 125 °C 5 74LVC1G17 Single Schmitt trigger buffer 9.Static Characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions -40 °C to +85 °C Min Typ[1] -40 °C to +125 °C Max Min Max Unit VI = VT+ or VTIO = -100μA; VCC = 1.65 V to 5.5 V VOH HIGH-level output voltage VCC - 0.1 VCC - 0.1 V IO = -4 mA; VCC = 1.65 V 1.2 0.95 V IO = -8 mA; VCC = 2.3 V 1.9 1.7 V IO = -12 mA; VCC = 2.7 V 2.2 1.9 V IO = -24 mA; VCC = 3.0 V 2.3 2.0 V IO = -32 mA; VCC = 4.5 V 3.8 3.4 V VI = VT+ or VT- VOL LOW-level output voltage IO = 100μA; VCC = 1.65 V to 5.5 V 0.10 0.10 V IO = 4 mA; VCC = 1.65 V 0.45 0.70 V IO = 8 mA; VCC = 2.3 V 0.30 0.45 V IO = 12 mA; VCC = 2.7 V 0.40 0.60 V IO = 24 mA; VCC = 3.0 V 0.55 0.80 V IO = 32 mA; VCC = 4.5 V 0.55 0.80 V II Input leakage current VI = 5.5 V or GND ; VCC = 5.5 V ±0.1 ±1 ±1 μA IOFF power-off leakage current VCC = 0V ; VI or VO = 5.5 V ±0.1 ±2 ±2 μA ICC supply current VI = 5.5V or GND ; IO = 0A ; VCC = 5.5V 0.1 4 4 μA ΔICC additional supply per pin ; VCC = 2.3V to 5.5V ; current VI = VCC -0.6V ; IO = 0A 5 500 500 μA CI input capacitance 5 VCC = 3.3V ; VI = GND to VCC pF [1]All typical values are measured at VCC = 3.3V and Tamb = 25℃. Rev. 1.0 – Aug 08, 2024 6 74LVC1G17 Single Schmitt trigger buffer 10. Dynamic Characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 9. Symbol Parameter CPD propagation delay power dissipation capacitance -40 °C to +125 °C Unit Min Typ[1] Max Min Max VCC = 1.65 V to 1.95 V 4.0 10.6 19.5 4.0 19.8 ns VCC = 2.3 V to 2.7 V 2.5 5.9 10.6 2.5 10.9 ns VCC = 3.0 V to 3.6 V 2.0 4.3 7 2.0 7.5 ns VCC = 4.5 V to 5.5 V 1.5 2.9 4.8 1.5 5.0 ns nA to nY; see Fig. 8 tpd -40 °C to +85 °C Conditions [2] per buffer ; VI = GND to VCC ; VCC = 3.3V [3] 24 pF [1] Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 3.3 V and 5.0 V respectively. [2] tpd is the same as tPLH and tPHL. [3] CPD is used to determine the dynamic power dissipation (PD in μW). PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; Σ(CL × VCC2 × fo) = sum of outputs. Rev. 1.0 – Aug 08, 2024 7 74LVC1G17 Single Schmitt trigger buffer 10.1. Waveforms and test circuit Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 8. The input nA to output nY propagation delays Table 8. Measurement points Supply voltage Input Output VCC VM VM 1.65 V to 1.95 V 0.5VCC 0.5VCC 2.3 V to 2.7 V 0.5VCC 0.5VCC 3.0 V to 3.6 V 1.5 V 1.5 V 4.5 V to 5.5 V 0.5VCC 0.5VCC Rev. 1.0 – Aug 08, 2024 8 74LVC1G17 Single Schmitt trigger buffer Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 9. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VCC VI tr = tf CL RL tPLH, tPHL 1.65 V to 1.95 V VCC ≤ 2.0 ns 30 pF 1 kΩ open 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 3.0 V to 3.6 V 3V ≤ 2.5 ns 50 pF 500 Ω open 4.5 V to 5.5 V VCC ≤ 2.5 ns 50 pF 500 Ω open Rev. 1.0 – Aug 08, 2024 Load VEXT 9 74LVC1G17 Single Schmitt trigger buffer 11. Transfer Characteristics Table 10. Transfer characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ[1] Max Min Max VCC = 1.8 V 0.82 1.0 1.14 0.79 1.14 V VCC = 2.3 V 1.03 1.2 1.40 1.00 1.40 V VCC = 3.0 V 1.29 1.5 1.71 1.26 1.71 V VCC = 4.5 V 1.84 2.2 2.36 1.81 2.36 V VCC = 5.5 V 2.19 2.6 2.79 2.16 2.79 V VCC = 1.8 V 0.46 0.6 0.75 0.46 0.78 V VCC = 2.3 V 0.65 0.7 0.96 0.65 0.99 V VCC = 3.0 V 0.88 1.0 1.24 0.88 1.27 V VCC = 4.5 V 1.32 1.6 1.84 1.32 1.87 V VCC = 5.5 V 1.58 1.9 2.24 1.58 2.27 V VCC = 1.8 V 0.26 0.5 0.62 0.19 0.62 V VCC = 2.3 V 0.28 0.5 0.65 0.22 0.65 V VCC = 3.0 V 0.31 0.6 0.7 0.25 0.7 V VCC = 4.5 V 0.40 0.6 0.77 0.34 0.77 V VCC = 5.5 V 0.47 0.6 0.88 0.41 0.88 V see Fig. 10 and Fig. 11 VT+ positive-going threshold voltage see Fig. 10 and Fig. 11 VT- negative-going threshold voltage see Fig. 10 and Fig. 11 VH hysteresis voltage [1] Typical values are measured at Tamb = 25 °C. Rev. 1.0 – Aug 08, 2024 10 74LVC1G17 Single Schmitt trigger buffer 11.1. Waveforms transfer characteristics VT+ and VT- limits at 70% and 20%. Fig 10. Transfer characteristic Fig 11. Definition of VT+, VT- and VH 12. Package Outline SOT23-5L Rev. 1.0 – Aug 08, 2024 11 74LVC1G17 Single Schmitt trigger buffer SOT353 Rev. 1.0 – Aug 08, 2024 12 74LVC1G17 Single Schmitt trigger buffer DFN1x1-6L Rev. 1.0 – Aug 08, 2024 13 74LVC1G17 Single Schmitt trigger buffer Rev. 1.0 – Aug 08, 2024 14 74LVC1G17 Single Schmitt trigger buffer DFN1x1.45-6L Rev. 1.0 – Aug 08, 2024 15 74LVC1G17 Single Schmitt trigger buffer DFN0.8x0.8-4L Rev. 1.0 – Aug 08, 2024 16 74LVC1G17 Single Schmitt trigger buffer DFN-4L Symbol A A1 D E e ф Rev. 1.0 – Aug 08, 2024 Dimensions in Millimeters Min. 0.34 0 0.858 0.858 Max. 0.4 0.05 0.918 0.918 0.5TYP 0.21 0.25 17 74LVC1G17 Single Schmitt trigger buffer 13. Tape and Reel Information 13.1. Carrier tape dimensions Direction of feed Table 11. Carrier tape dimensions Package version A0(mm) B0(mm) DFN1x1.45-6L 1.15 1.6 DFN1x1-6L 1.16 1.16 DFN0.8x0.8-4L 0.91 0.91 SOT353 2.55 2.55 SOT363 2.55 2.55 SOT23-5L/6L 3.23 3.17 Rev. 1.0 – Aug 08, 2024 K0(mm) 0.75 0.5 0.5 1.2 1.2 1.37 T(mm) 0.2 0.23 0.2 0.2 0.2 0.25 P1(mm) 4 4 2 4 4 4 W(mm) 8 8 8 8 8 8 P0(mm) 4 4 4 4 4 4 PIN 1 Q1 Q1 Q1 Q3 Q3 Q3 18 74LVC1G17 Single Schmitt trigger buffer 13.2. Reel and box dimensions Table 12. Dimensions and quantities Reel Package Type NO. Dimension version ending A (mm) DFN1x1.45-6L 1R 180 DFN1x1-6L 1R 180 DFN0.8x0.8-4L 1R 180 SOT353 1R 180 SOT363 1R 180 SOT23-5L/6L 1R 180 Reel Width W1 (mm) 12.2 12.2 12.2 12.2 12.2 12.2 SPQ (pcs)[1] Reels per box Outer box dimensions L×W×H(mm)[2] 3000 3000 3000 3000 3000 3000 1 1 1 1 1 1 210x200x40 210x200x40 210x200x40 210x200x40 210x200x40 210x200x40 [1] Packing quantity dependent on specific product type. Please contact your local MDD representative for ordering. [2] Dimensions for reference only. Rev. 1.0 – Aug 08, 2024 19 74LVC1G17 Single Schmitt trigger buffer 14. Abbreviations Table 13. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 15. Revision History Table 14. Revision history Document ID Release Date Data sheet status 74LVC1G17 Rev1.0 Oct 30, 2023 Product datasheet Rev. 1.0 – Aug 08, 2024 Change notice Supersedes 20
74AHC1G17GW 价格&库存
很抱歉,暂时无法提供与“74AHC1G17GW”相匹配的价格&库存,您可以联系我们找货
